[postgis-tickets] r17203 - remove docker hub image (geos seems broken at moment)
Regina Obe
lr at pcorp.us
Mon Jan 21 03:18:14 PST 2019
Author: robe
Date: 2019-01-21 15:18:14 -0800 (Mon, 21 Jan 2019)
New Revision: 17203
trunk/.drone-1.0.yml
Modified: trunk/.drone-1.0.yml
--- trunk/.drone-1.0.yml 2019-01-21 22:25:00 UTC (rev 17202)
+++ trunk/.drone-1.0.yml 2019-01-21 23:18:14 UTC (rev 17203)
@@ -72,15 +72,4 @@
- make install
- utils/check_all_upgrades.sh
`grep '^POSTGIS_' Version.config | cut -d= -f2 | paste -sd '.'`
-test-image: &test-image postgis/postgis-build-env:pg11-geosmaster-gdal23-proj51
-kind: pipeline
-name: pg-11-geosmaster-gdal23-proj51
-steps:
- - name: build
- image: *test-image
- pull: true
- commands:
- - bash ci/travis/run_tests.sh
