[postgis-tickets] [PostGIS] #4445: geometry_le: Is not working properly
trac at osgeo.org
Mon Jul 1 09:09:30 PDT 2019
Reporter: Algunenano | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.8
Component: postgis | Version: 2.4.x
Keywords: |
template_postgis=# Select geometry_lt('Point(0 0)'::geometry, 'Point(1
1)'::geometry);
geometry_lt
t
(1 row)
template_postgis=# Select geometry_eq('Point(0 0)'::geometry, 'Point(1
1)'::geometry);
geometry_eq
f
(1 row)
template_postgis=# Select geometry_le('Point(0 0)'::geometry, 'Point(1
1)'::geometry);
geometry_le
f
(1 row)
(0 0) < (1 1) == T
(0 0) == (1 1) == F
(0 0) <= (1 1) == F <<<< Should be true
The bug seems to have been introduced in 2.4.
PR: https://github.com/postgis/postgis/pull/428
I'll add a test fixing the one above.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4445>
