[postgis-tickets] r17576 - get rid of -e in packaging (causing error to be thrown if tries to remove zip not present), minor adjustments to packaging.
Regina Obe lr at pcorp.us
Mon Jul 1 12:01:42 PDT 2019
Author: robe
Date: 2019-07-01 12:01:42 -0700 (Mon, 01 Jul 2019)
New Revision: 17576
   trunk/ci/winnie/build_postgis.sh
   trunk/ci/winnie/package_postgis.sh
Modified: trunk/ci/winnie/build_postgis.sh
--- trunk/ci/winnie/build_postgis.sh	2019-07-01 18:15:25 UTC (rev 17575)
+++ trunk/ci/winnie/build_postgis.sh	2019-07-01 19:01:42 UTC (rev 17576)
@@ -8,7 +8,7 @@
 	export CGAL_VER=4.11
 	export ICON_VER=1.15
 	export ZLIB_VER=1.2.11
-  	export PROTOBUF_VER=3.2.0
+  export PROTOBUF_VER=3.2.0
 	export PROTOBUFC_VER=1.2.1
 	export JSON_VER=0.12
 	export PROJSO=libproj-12.dll
@@ -170,7 +170,6 @@
   --prefix=${PROJECTS}/postgis/liblwgeom-${POSTGIS_VER}w${OS_BUILD}${GCC_TYPE}
 fi;
 make clean
 #patch liblwgeom generated make to get rid of dynamic linking
Modified: trunk/ci/winnie/package_postgis.sh
--- trunk/ci/winnie/package_postgis.sh	2019-07-01 18:15:25 UTC (rev 17575)
+++ trunk/ci/winnie/package_postgis.sh	2019-07-01 19:01:42 UTC (rev 17576)
@@ -15,8 +15,6 @@
 #if no override is set - use these values
 #otherwise use the ones jenkins passes thru
 #!/bin/bash
-#!/bin/bash
-set -e
 if  [[ "${OVERRIDE}" == '' ]] ; then
 	export GEOS_VER=3.8
 	export GDAL_VER=2.2.4
@@ -64,7 +62,7 @@
 echo "CGAL_VER $CGAL_VER"
 export PROJECTS=/projects
-export MINGPROJECTS=/projects
+export PROJECTS=/projects
 export PATHOLD=$PATH
@@ -115,7 +113,7 @@
 export RELVERDIR=postgis-pg${REL_PGVER}-binaries-${POSTGIS_MICRO_VER}w${OS_BUILD}${GCC_TYPE}
 export PATH="${PATHOLD}:${PGPATH}/bin:${PGPATH}/lib"
 export PCRE_VER=8.33
-#PATH="${PGPATH}/bin:${PGPATH}/lib:${MINGPROJECTS}/xsltproc:${MINGPROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gtkw${OS_BUILD}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/bin:${PATH}"
+#PATH="${PGPATH}/bin:${PGPATH}/lib:${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gtkw${OS_BUILD}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/bin:${PATH}"
 #echo PATH AFTER: $PATH
 outdir="${RELDIR}/${RELVERDIR}"
 package="${RELDIR}/${RELVERDIR}.zip"
@@ -137,11 +135,11 @@
 # it seems 9.2 and 9.3 doesn't come with its own libiconv good grief
 # and trying to use their libiconv2.dll makes shp2pgsql crash
 if [[ "$PG_VER" == *9.2* || "$PG_VER" == *9.3* ]]; then
-	cp ${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/bin/*.dll  $outdir/bin
+	cp ${PROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/bin/*.dll  $outdir/bin
 fi;
 cp ${PGPATHEDB}/bin/libpq.dll  $outdir/bin/postgisgui
 #cp ${PGPATHEDB}/bin/libiconv2.dll  $outdir/bin/postgisgui
-cp ${MINGPROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin/libicon*.dll $outdir/bin/postgisgui
+cp ${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin/libicon*.dll $outdir/bin/postgisgui
 cp ${PGPATHEDB}/bin/libintl*.dll $outdir/bin/postgisgui
 cp ${PGPATHEDB}/bin/ssleay32.dll $outdir/bin/postgisgui
@@ -159,11 +157,11 @@
 cp -r ${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/gdk-pixbuf-2.0 $outdir/bin/postgisgui/lib
-cp ${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/share/proj/* $outdir/share/contrib/postgis-${POSTGIS_MINOR_VER}/proj
-cp ${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin
+cp ${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/share/proj/* $outdir/share/contrib/postgis-${POSTGIS_MINOR_VER}/proj
+cp ${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin
 cp -p ${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin
-cp ${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin/postgisgui
+cp ${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin/postgisgui
 cp -p ${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin/postgisgui
 #for protobuf
@@ -203,8 +201,8 @@
 echo "PROTOBUF VERSION: ${PROTOBUF_VER} https://github.com/google/protobuf" >> $verfile
 echo "PROTOBUF-C VERSION: ${PROTOBUFC_VER} https://github.com/protobuf-c/protobuf-c"  >> $verfile
-#cp ${MINGPROJECTS}/libxml/rel-libxml2-2.7.8w${OS_BUILD}/bin/*.dll  $outdir/bin/
-cp ${PGPATHEDB}/bin/libxml2-2.dll   $outdir/bin/
+cp ${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}/bin/*.dll  $outdir/bin/
+#cp ${PGPATHEDB}/bin/libxml2-2.dll   $outdir/bin/
 cd ${POSTGIS_SRC}
 strip postgis/*.dll
