[postgis-tickets] r17601 - _ST_OrderingEquals: Avoid deserialization
Raul raul at rmr.ninja
Mon Jul 15 03:07:04 PDT 2019
Author: algunenano
Date: 2019-07-15 03:07:03 -0700 (Mon, 15 Jul 2019)
New Revision: 17601
   trunk/NEWS
   trunk/postgis/lwgeom_functions_basic.c
Closes #4454
Closes https://github.com/postgis/postgis/pull/444
Modified: trunk/NEWS
--- trunk/NEWS	2019-07-14 14:24:18 UTC (rev 17600)
+++ trunk/NEWS	2019-07-15 10:07:03 UTC (rev 17601)
@@ -5,7 +5,7 @@
 Additional features enabled if you are running Proj6+ and PostgreSQL 12
 * Major highlights *
-  - #4433 32-bit hash fix (requires reindexing hash(geometry) indexes) (Raúl Marín)
+  - #4433, 32-bit hash fix (requires reindexing hash(geometry) indexes) (Raúl Marín)
   - #4445, Fix a bug in geometry_le (Raúl Marín)
   - #4451, Fix the calculation of gserialized_max_header_size (Raúl Marín)
   - #4450, Speed up ST_GeometryType (Raúl Marín)
@@ -13,6 +13,7 @@
   - #4417, Update spatial_ref_sys with new entries (Paul Ramsey)
   - #4449, Speed up ST_X, ST_Y, ST_Z and ST_M (Raúl Marín)
   - #4456, add Rasbery Pi 32-bit jenkins bot for testing (Bruce Rindahl)
+  - #4454, Speed up _ST_OrderingEquals (Raúl Marín)
 PostGIS 3.0.0alpha3
 2019/07/01
Modified: trunk/postgis/lwgeom_functions_basic.c
--- trunk/postgis/lwgeom_functions_basic.c	2019-07-14 14:24:18 UTC (rev 17600)
+++ trunk/postgis/lwgeom_functions_basic.c	2019-07-15 10:07:03 UTC (rev 17601)
@@ -2010,32 +2010,8 @@
 	GSERIALIZED *g1 = PG_GETARG_GSERIALIZED_P(0);
 	GSERIALIZED *g2 = PG_GETARG_GSERIALIZED_P(1);
-	LWGEOM *lwg1, *lwg2;
-	bool result;
-	if ((gserialized_get_type(g1) != gserialized_get_type(g2)) ||
-		(gserialized_has_z(g1) != gserialized_has_z(g2)) ||
-		(gserialized_has_m(g1) != gserialized_has_m(g2)))
-		PG_FREE_IF_COPY(g1, 0);
-		PG_FREE_IF_COPY(g2, 1);
-		PG_RETURN_BOOL(false); /* different type or dimensionality */
-	/* ok, deserialize. */
-	lwg1 = lwgeom_from_gserialized(g1);
-	lwg2 = lwgeom_from_gserialized(g2);
-	/* invoke appropriate function */
-	result = lwgeom_same(lwg1, lwg2);
-	/* Release memory */
-	lwgeom_free(lwg1);
-	lwgeom_free(lwg2);
-	PG_RETURN_BOOL(result);
+	PG_RETURN_BOOL(gserialized_cmp(g1, g2) == 0);
 PG_FUNCTION_INFO_V1(ST_MakeEnvelope);
