[postgis-tickets] r17616 - Re-enable gdal tests
Raul
raul at rmr.ninja
Fri Jul 19 06:02:56 PDT 2019
Author: algunenano
Date: 2019-07-19 06:02:56 -0700 (Fri, 19 Jul 2019)
New Revision: 17616
trunk/raster/test/regress/rt_gdalwarp.sql
trunk/raster/test/regress/rt_gdalwarp_expected
Reverts r16688
Closes #4104
Closes https://github.com/postgis/postgis/pull/450
Modified: trunk/raster/test/regress/rt_gdalwarp.sql
--- trunk/raster/test/regress/rt_gdalwarp.sql 2019-07-19 05:47:19 UTC (rev 17615)
+++ trunk/raster/test/regress/rt_gdalwarp.sql 2019-07-19 13:02:56 UTC (rev 17616)
@@ -50,8 +50,6 @@
INSERT INTO "spatial_ref_sys" ("srid","auth_name","srtext","proj4text") VALUES (984269,'EPSG','GEOGCS["NAD83",DATUM["North_American_Datum_1983",SPHEROID["GRS 1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],AUTHORITY["EPSG","6269"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4269"]]','+proj=longlat +ellps=GRS80 +datum=NAD83 +no_defs ');
INSERT INTO "spatial_ref_sys" ("srid","srtext") VALUES (974269,'GEOGCS["NAD83",DATUM["North_American_Datum_1983",SPHEROID["GRS 1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],AUTHORITY["EPSG","6269"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4269"]]');
--- Take out some testing of srid 993309 since it fails on Proj.5 with GDAL 2.2.4, GDAL 2.3.0
--- See #4104. Put back after we start testing proj.5 and issue is fixed in proj.
-- _st_gdalwarp
INSERT INTO raster_gdalwarp_dst (rid, rast) VALUES (
0.0, (SELECT _st_gdalwarp(
@@ -63,13 +61,13 @@
'NearestNeighbour', 0.125,
993310
) FROM raster_gdalwarp_src)
0.2, (SELECT _st_gdalwarp(
rast,
993309
0.3, (SELECT _st_gdalwarp(
rast,
@@ -205,7 +203,7 @@
NULL, NULL,
3, 3
0.20, (SELECT _st_gdalwarp(
rast,
'Bilinear', 0.125,
@@ -214,7 +212,7 @@
NULL, NULL,
1, 3
0.21, (SELECT _st_gdalwarp(
rast,
'Cubic', 0,
@@ -446,12 +444,12 @@
rast,
993310
2.2, (SELECT ST_Transform(
rast,
993309
2.3, (SELECT ST_Transform(
rast,
994269
@@ -491,12 +489,12 @@
rast,
993310, 'NearestNeighbor', 0.125, 500, 500
2.11, (SELECT ST_Transform(
rast,
993309, 'Cubic', 0., 100, 100
2.12, (SELECT ST_Transform(
rast,
993310, 'CubicSpline', 0., 2000, 2000
Modified: trunk/raster/test/regress/rt_gdalwarp_expected
--- trunk/raster/test/regress/rt_gdalwarp_expected 2019-07-19 05:47:19 UTC (rev 17615)
+++ trunk/raster/test/regress/rt_gdalwarp_expected 2019-07-19 13:02:56 UTC (rev 17616)
@@ -19,6 +19,8 @@
0.17|993309|243|243|1|50.000|50.000|0.000|0.000|950760.000|1396957.000|t|t|t
0.18|992163|10|10|1|1000.000|-1000.000|3.000|3.000|-500030.000|600000.000|t|t|t
0.19|993310|12|12|1|1009.894|-1009.894|3.000|3.000|950691.792|1409281.783|t|t|t
+0.2|993309|12|12|1|1009.916|-1009.916|0.000|0.000|950762.305|1409088.896|t|t|t
+0.20|993309|12|12|1|1009.916|-1009.916|1.000|3.000|950742.107|1409088.896|t|t|t
0.21|993310|24|24|1|500.000|500.000|3.000|3.000|950657.188|1397356.783|t|t|t
0.22|993310|26|26|1|500.000|500.000|0.000|6.000|950452.000|1396632.000|t|t|t
0.23|984269|12|8|1|0.012|-0.012|0.000|0.000|-107.029|50.206|t|t|t
@@ -61,10 +63,12 @@
1.9|992163|11|10|1|1000.000|-1000.000|0.000|0.000|-500001.000|600000.000|t|t|t
2.1|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
2.10|993310|24|24|1|500.000|500.000|0.000|0.000|950732.188|1397281.783|t|t|t
+2.11|993309|121|121|1|100.000|100.000|0.000|0.000|950762.305|1396988.896|t|t|t
2.12|993310|6|6|1|2000.000|2000.000|0.000|0.000|950732.188|1397281.783|t|t|t
2.13|993310|8|8|1|1500.000|1500.000|0.000|0.000|950732.188|1397281.783|t|t|t
2.14|993310|24|24|1|500.000|500.000|0.000|0.000|950732.188|1397281.783|t|t|t
2.15|993310|16|16|1|750.000|750.000|0.000|0.000|950732.188|1397281.783|t|t|t
+2.2|993309|12|12|1|1009.916|-1009.916|0.000|0.000|950762.305|1409088.896|t|t|t
2.3|994269|12|8|1|0.012|-0.012|0.000|0.000|-107.029|50.206|t|t|t
2.4|||||||||||||
2.5|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
