[postgis-tickets] [PostGIS] #4104: PostGIS 2.4.4 rt_gdalwrap test fails with GDAL 2.3.0 & PROJ 5.1.0 on Debian unstable
trac at osgeo.org
Mon Jul 22 04:33:47 PDT 2019
unstable
Reporter: Bas Couwenberg | Owner: Bborie Park
Type: defect | Status: reopened
Priority: high | Milestone: PostGIS 3.0.0
Component: raster | Version: 2.5.x
Resolution: | Keywords:
Changes (by Algunenano):
* priority: blocker => high
Comment:
I've tried changing the definition for 993309 in several ways without any
luck.
My local installation all CIs except for Gitlab (which uses Debian buster
packages) work fine, and they cover multiple releases of both gdal and
proj, so I don't know where this error might be coming from.
I'm going to disable again these tests and leave it be for now.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4104#comment:19>
