[postgis-tickets] [PostGIS] #4271: postgis_extensions_upgrade() does nothing when upgrading from same version of Postgis different PostgreSQL
trac at osgeo.org
Mon Jul 22 06:27:47 PDT 2019
Reporter: robe | Owner: robe
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 3.0.0
Component: build/upgrade/install | Version: 2.5.x
Resolution: fixed | Keywords:
Changes (by Raul Marin):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"17620" 17620]:
#!CommitTicketReference repository="" revision="17620"
postgis_extensions_upgrade() also updates after pg_upgrade
Closes #4271
Closes https://github.com/postgis/postgis/pull/449
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4271#comment:8>
