[postgis-tickets] [PostGIS] #4463: PostGIS raster ST_Intersects regression with pg12
trac at osgeo.org
Fri Jul 26 16:19:11 PDT 2019
Reporter: robe | Owner: Bborie Park
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.0.0
Component: raster | Version: trunk
Keywords: |
Our PostGIS raster still relies on inlining, so the costing we added to
functions in PostgreSQL 12 is making raster performance poor as many uses
of ST_Intersects (raster variant are no longer inlining)
Need to change raster ST_Intersects functions to be support function aware
Example from Paul's data:
DEMS https://pub.data.gov.bc.ca/datasets/175624/92g/092g06_e.dem.zip
https://pub.data.gov.bc.ca/datasets/175624/92g/092g06_w.dem.zip
buildings https://data.vancouver.ca/datacatalogue/buildingFootprints.htm>
raster2pgsql -I -F -s 4269 -t 56x56 092g06_e.dem dem092g06e | psql
yvr_raster
shp2pgsql -s 26910 -D building_footprints_2009 buildings
ALTER TABLE buildings
ALTER COLUMN geom
TYPE geometry(MultiPolygon, 4269)
USING ST_Transform(ST_Force2D(geom), 4269);
CREATE INDEX ix_buildings_geom_centroid ON buildings USING
gist(ST_Centroid(geom));
--this doesn't use an index on PostgreSQL 12 (though it has option of a
centroid functional index and a raster ST_ConvexHull(rast) index
-- TODO: test on 11, we suspect it will be able to use the indexes
SELECT b.*
FROM buildings b
JOIN dem092g06e d
ON ST_Intersects(ST_Centroid(b.geom), rast)
WHERE ST_Value(d.rast, ST_Centroid(b.geom)) <= 30
The issue as RhodiumToad explained on IRC is the
ST_Intersects(raster,geometry), geometry,raster is still relying on
_ST_Intersects which doesn't use the fancy function costing so is
suffering from the high costs we've put in place.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4463>
