[postgis-tickets] r17639 - Handle NULL geometry values in pgsql2shp
Paul Ramsey pramsey at cleverelephant.ca
Mon Jul 29 09:32:03 PDT 2019
Author: pramsey
Date: 2019-07-29 09:32:03 -0700 (Mon, 29 Jul 2019)
New Revision: 17639
   trunk/NEWS
   trunk/loader/pgsql2shp-core.c
   trunk/postgis/postgis.sql.in
References #4209
Modified: trunk/NEWS
--- trunk/NEWS	2019-07-29 16:30:25 UTC (rev 17638)
+++ trunk/NEWS	2019-07-29 16:32:03 UTC (rev 17639)
@@ -18,6 +18,7 @@
   - #4271, postgis_extensions_upgrade() also updates after pg_upgrade (Raúl Marín)
   - #4403, Support for shp2pgsql ability to reproject with copy mode (-D) (Regina Obe)
   - #4466, Fix undefined behaviour in _postgis_gserialized_stats (Raúl Marín)
+  - #4209, Handle NULL geometry values in pgsql2shp (Paul Ramsey)
 PostGIS 3.0.0alpha3
 2019/07/01
Modified: trunk/loader/pgsql2shp-core.c
--- trunk/loader/pgsql2shp-core.c	2019-07-29 16:30:25 UTC (rev 17638)
+++ trunk/loader/pgsql2shp-core.c	2019-07-29 16:32:03 UTC (rev 17639)
@@ -887,15 +887,15 @@
 			query = malloc(150 + 4 * strlen(state->geo_col_name) + strlen(state->schema) + strlen(state->table));
-			sprintf(query, "SELECT count(\"%s\"), max(ST_zmflag(\"%s\"::geometry)), geometrytype(\"%s\"::geometry) FROM \"%s\".\"%s\" GROUP BY geometrytype(\"%s\"::geometry)",
-			state->geo_col_name, state->geo_col_name, state->geo_col_name, state->schema, state->table, state->geo_col_name);
+			sprintf(query, "SELECT count(1), max(ST_zmflag(\"%s\"::geometry)), geometrytype(\"%s\"::geometry) FROM \"%s\".\"%s\" GROUP BY 3",
+			state->geo_col_name, state->geo_col_name, state->schema, state->table);
 		else
 			query = malloc(150 + 4 * strlen(state->geo_col_name) + strlen(state->table));
-			sprintf(query, "SELECT count(\"%s\"), max(ST_zmflag(\"%s\"::geometry)), geometrytype(\"%s\"::geometry) FROM \"%s\" GROUP BY geometrytype(\"%s\"::geometry)",
-			state->geo_col_name, state->geo_col_name, state->geo_col_name, state->table, state->geo_col_name);
+			sprintf(query, "SELECT count(1), max(ST_zmflag(\"%s\"::geometry)), geometrytype(\"%s\"::geometry) FROM \"%s\" GROUP BY 3",
+			state->geo_col_name, state->geo_col_name, state->table);
 	else
@@ -955,10 +955,15 @@
 		for (i = 0; i < PQntuples(res); i++)
+			/* skip null geometries */
+			if (PQgetisnull(res, i, 2))
+				state->rowcount += atoi(PQgetvalue(res, i, 0));
+				continue;
 			geometry_type_from_string(PQgetvalue(res, i, 2), &type, &dummy, &dummy);
-			if (!type) continue; /* skip null geometries */
 			/* We can always set typefound to that of the first column found */
 			if (!typefound)
 				typefound = type;
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in	2019-07-29 16:30:25 UTC (rev 17638)
+++ trunk/postgis/postgis.sql.in	2019-07-29 16:32:03 UTC (rev 17639)
@@ -4608,7 +4608,7 @@
 	_COST_LOW;
 -- Availability: 3.0.0
-CREATE OR REPLACE FUNCTION ST_AsGeoJson(r record, geom_column text DEFAULT '', maxdecimaldigits int4 DEFAULT 15, pretty_print bool DEFAULT false)
+CREATE OR REPLACE FUNCTION ST_AsGeoJson(r record, geom_column text DEFAULT '', maxdecimaldigits int4 DEFAULT 15, pretty_bool bool DEFAULT false)
 	RETURNS text
 	AS 'MODULE_PATHNAME','ST_AsGeoJsonRow'
 	LANGUAGE 'c' STABLE STRICT _PARALLEL
