[postgis-tickets] r17640 - Match JSON pretty print param name to	one used in pgsql
    Paul Ramsey
    pramsey at cleverelephant.ca
    Mon Jul 29 09:33:57 PDT 2019
Author: pramsey
Date: 2019-07-29 09:33:57 -0700 (Mon, 29 Jul 2019)
New Revision: 17640
   trunk/doc/reference_output.xml
Modified: trunk/doc/reference_output.xml
--- trunk/doc/reference_output.xml	2019-07-29 16:32:03 UTC (rev 17639)
+++ trunk/doc/reference_output.xml	2019-07-29 16:33:57 UTC (rev 17640)
@@ -549,7 +549,7 @@
 				<paramdef><type>record </type> <parameter>feature</parameter></paramdef>
 				<paramdef choice="opt"><type>text </type> <parameter>geomcolumnname</parameter></paramdef>
 				<paramdef choice="opt"><type>integer </type> <parameter>maxdecimaldigits=15</parameter></paramdef>
-				<paramdef choice="opt"><type>boolean </type> <parameter>prettyprint=false</parameter></paramdef>
+				<paramdef choice="opt"><type>boolean </type> <parameter>pretty_bool=false</parameter></paramdef>
 			</funcprototype>
 			<funcprototype>
 				<funcdef>text <function>ST_AsGeoJSON</function></funcdef>
