[postgis-tickets] r17644 - add in -d transform into enhancements list, move bug fixes into a separate section from enhancements.
Regina Obe
lr at pcorp.us
Mon Jul 29 09:58:16 PDT 2019
Author: robe
Date: 2019-07-29 09:58:16 -0700 (Mon, 29 Jul 2019)
New Revision: 17644
trunk/NEWS
This is to make it easier to spot and drop bug fixes if they are backported to older versions of PostGIS (as they won't be new things in PostGIS 3.0)
Modified: trunk/NEWS
--- trunk/NEWS 2019-07-29 16:45:24 UTC (rev 17643)
+++ trunk/NEWS 2019-07-29 16:58:16 UTC (rev 17644)
@@ -133,9 +133,10 @@
- #1833, ST_AsGeoJSON(row) generates full GeoJSON Features (Joe Conway)
- #3687, Casts json(geometry) and jsonb(geometry) for implicit GeoJSON
generation (Paul Ramsey)
+ - #4198, Add ST_ConstrainedDelaunayTriangles SFCGAL function (Darafei
+ Praliaskouski)
-* Enhancements and fixes *
- - #4342, Move deprecated functions into legacy.sql file
+* Enhancements *
- #4341, Using "support function" API in PgSQL 12+ to replace SQL inlining
as the mechanism for providing index support under ST_Intersects, et al
- #4330, postgis_restore OOM when output piped to an intermediate process
@@ -151,22 +152,10 @@
- #4176, ST_Intersects supports GEOMETRYCOLLECTION (Darafei Praliaskouski)
- #4181, ST_AsMVTGeom: Avoid type changes due to validation (Raúl Marín)
- #4183, ST_AsMVTGeom: Drop invalid geometries after simplification (Raúl Marín)
- - #4188, Avoid division by zero in KMeans (Raúl Marín)
- - #4189, Fix undefined behaviour in SADFWrite (Raúl Marín)
- - #4191, Fix undefined behaviour in ptarray_clone_deep (Raúl Marín)
- - #4211, Fix ST_Subdivide for minimal exterior ring with minimal hole (Darafei
- Praliaskouski)
- - #3457, Fix raster envelope shortcut in ST_Clip (Sai-bot)
- #4215, Use floating point compare in ST_DumpAsPolygons (Darafei Praliaskouski)
- #4155, Support for GEOMETRYCOLLECTION, POLYGON, TIN, TRIANGLE in
ST_LocateBetween and ST_LocateBetweenElevations (Darafei Praliaskouski)
- #2767, Documentation for AddRasterConstraint optional parameters (Sunveer Singh)
- - #4326, Allocate enough memory in gidx_to_string (Raúl Marín)
- - #4190, Avoid undefined behaviour in gserialized_estimate (Raúl Marín)
- - #4233, Fix undefined behaviour in gserialized_spgist_picksplit_nd (Raúl Marín)
- - #4247, Avoid undefined behaviour in next_float functions (Raúl Marín)
- - #4249, Fix undefined behaviour in raster intersection (Raúl Marín)
- - #4246, Fix undefined behaviour in ST_3DDistance (Raúl Marín)
- #4244, Avoid unaligned memory access in BOX2D_out (Raúl Marín)
- #4139, Make mixed-dimension ND index build tree correctly (Darafei Praliaskouski,
Arthur Lesuisse, Andrew Gierth, Raúl Marín)
@@ -177,10 +166,7 @@
- #4301, ST_Subdivide: fix endless loop on coordinates near coincident to bounds
- #4289, ST_AsMVTGeom: Transform coordinates space before clipping (Raúl Marín)
- - #4275, Avoid passing a NULL pointer to GEOSisEmpty (Raúl Marín)
- - #4296, Use `server_version_num` instead of parsing `version()` (Raúl Marín)
- #4272, Improve notice message when unable to compute stats (Raúl Marín)
- - #4314, ST_ClipByBox2D: Do not throw when the geometry is invalid (Raúl Marín)
- #4313, #4307, PostgreSQL 12 compatibility (Laurenz Albe, Raúl Marín)
- #4299, #4304, ST_GeneratePoints is now VOLATILE. IMMUTABLE version with
seed parameter added. (Mike Taves)
@@ -187,7 +173,6 @@
- #4278, ST_3DDistance and ST_3DIntersects now support Solid TIN and Solid
POLYHEDRALSURFACE (Darafei Praliaskouski)
- #4348, ST_AsMVTGeom (GEOS): Enforce validation at all times (Raúl Marín)
- - #4361, Fix postgis_type_name with (GEOMETRYM,3) (Matt Bretl)
- #4295, Allow GEOMETRYCOLLECTION in ST_Overlaps, ST_Contains, ST_ContainsProperly,
ST_Covers, ST_CoveredBy, ST_Crosses, ST_Touches, ST_Disjoint, ST_Relate,
ST_Equals (Esteban Zimányi)
@@ -198,24 +183,42 @@
- #4368, Reorder LWGEOM struct members to minimize extra padding (Raúl Marín)
- #4141, Use uint64 to handle row counts in the topology extension (Raúl Marín)
- #4225, Upgrade tiger to use tiger 2018 census files
- - #4198, Add ST_ConstrainedDelaunayTriangles SFCGAL function (Darafei
- Praliaskouski)
- #4412, Support ingesting rasters with NODATA=NaN (Darafei Praliaskouski)
- #4413, Raster tile size follows GeoTIFF block size on raster2pgsql -t auto
- #4422, Modernize Python 2 code to get ready for Python 3 (Christian Clauss)
+ - #4352, Use CREATE OR REPLACE AGGREGATE for PG12+ (Raúl Marín)
+ - #4394, Allow FULL OUTER JOIN on geometry equality operator (Darafei Praliaskouski)
+ - #4441, Make GiST penalty friendly to multi-column indexes and build single-column
+ ones faster. (Darafei Praliaskouski)
+ - #4403, Support for shp2pgsql ability to reproject with copy mode (-D) (Regina Obe)
+* Fixes *
+ - #4342, Move deprecated functions into legacy.sql file
+ - #4445, Fix a bug in geometry_le (Raúl Marín)
+ - #4189, Fix undefined behaviour in SADFWrite (Raúl Marín)
+ - #4191, Fix undefined behaviour in ptarray_clone_deep (Raúl Marín)
+ - #4211, Fix ST_Subdivide for minimal exterior ring with minimal hole (Darafei
+ Praliaskouski)
+ - #4326, Allocate enough memory in gidx_to_string (Raúl Marín)
+ - #4190, Avoid undefined behaviour in gserialized_estimate (Raúl Marín)
+ - #4233, Fix undefined behaviour in gserialized_spgist_picksplit_nd (Raúl Marín)
+ - #4247, Avoid undefined behaviour in next_float functions (Raúl Marín)
+ - #4249, Fix undefined behaviour in raster intersection (Raúl Marín)
+ - #4246, Fix undefined behaviour in ST_3DDistance (Raúl Marín)
+ - #4188, Avoid division by zero in KMeans (Raúl Marín)
+ - #3457, Fix raster envelope shortcut in ST_Clip (Sai-bot)
+ - #4361, Fix postgis_type_name with (GEOMETRYM,3) (Matt Bretl)
+ - #4275, Avoid passing a NULL pointer to GEOSisEmpty (Raúl Marín)
+ - #4296, Use `server_version_num` instead of parsing `version()` (Raúl Marín)
+ - #4314, ST_ClipByBox2D: Do not throw when the geometry is invalid (Raúl Marín)
- #4383, Fix undefined behaviour in implicit conversions (Raúl Marín)
- - #4352, Use CREATE OR REPLACE AGGREGATE for PG12+ (Raúl Marín)
- #4334, Fix upgrade issues related to renamed function parameters (Raúl Marín)
- #4388, AddRasterConstraints: Ignore NULLs when generating constraints (Raúl Marín)
- #4327, Avoid pfree'ing the result of getenv (Raúl Marín)
- #4406, Throw on invalid characters when decoding geohash (Raúl Marín)
- - #4394, Allow FULL OUTER JOIN on geometry equality operator (Darafei Praliaskouski)
- - #4441, Make GiST penalty friendly to multi-column indexes and build single-column
- ones faster. (Darafei Praliaskouski)
- - #4445, Fix a bug in geometry_le (Raúl Marín)
PostGIS 2.5.0
2018/09/23
WARNING: If compiling with PostgreSQL+JIT, LLVM >= 6 is required
