[postgis-tickets] r17646 - Use protobuf version to enable/disable mvt/geobuf
Paul Ramsey pramsey at cleverelephant.ca
Tue Jul 30 03:27:06 PDT 2019
Author: pramsey
Date: 2019-07-30 15:27:06 -0700 (Tue, 30 Jul 2019)
New Revision: 17646
   branches/2.4/NEWS
   branches/2.4/configure.ac
   branches/2.4/postgis/Makefile.in
   branches/2.4/postgis/geobuf.c
   branches/2.4/postgis/geobuf.h
   branches/2.4/postgis/lwgeom_out_geobuf.c
   branches/2.4/postgis_config.h.in
   branches/2.4/regress/Makefile.in
References #4419
Modified: branches/2.4/NEWS
--- branches/2.4/NEWS	2019-07-29 17:36:47 UTC (rev 17645)
+++ branches/2.4/NEWS	2019-07-30 22:27:06 UTC (rev 17646)
@@ -12,6 +12,7 @@
   - #4445, Fix bug in lwgeom_le (Raúl Marín)
   - #4466, Fix undefined behaviour in _postgis_gserialized_stats (Raúl Marín)
   - #4209, Handle NULL geometry values in pgsql2shp (Paul Ramsey)
+  - #4419, Use protobuf version to enable/disable mvt/geobuf (Paul Ramsey)
 PostGIS 2.4.7
Modified: branches/2.4/configure.ac
--- branches/2.4/configure.ac	2019-07-29 17:36:47 UTC (rev 17645)
+++ branches/2.4/configure.ac	2019-07-30 22:27:06 UTC (rev 17646)
@@ -995,6 +995,21 @@
     	fi
     fi
+    dnl Get version number for protoc-c
+    if test "$HAVE_PROTOBUF" = "yes"; then
+        AC_PATH_PROG(PROTOCC, protoc-c)
+        PROTOCC_SEMVER=$($PROTOCC --version | grep protobuf-c | awk '{print $2}')
+        AC_MSG_RESULT([checking protoc-c version... $PROTOCC_SEMVER])
+        PROTOCC_VERSION_MAJOR=$(echo "$PROTOCC_SEMVER" | tr '.' ' ' | awk '{print $1}')
+        PROTOCC_VERSION_MINOR=$(echo "$PROTOCC_SEMVER" | tr '.' ' ' | awk '{print $2}')
+        PROTOCC_VERSION_PATCH=$(echo "$PROTOCC_SEMVER" | tr '.' ' ' | awk '{print $3}')
+        PROTOCC_VERSION=$(expr 10000 \* $PROTOCC_VERSION_MAJOR + 100 \* $PROTOCC_VERSION_MINOR + $PROTOCC_VERSION_PATCH)
+        if test $PROTOCC_VERSION -ge 10100; then
+            AC_DEFINE([HAVE_GEOBUF], [1], [Define to 1 if libprotobuf-c is >= 1.1])
+        fi
+    fi
+    AC_SUBST([PROTOCC_VERSION])
     AC_SUBST([PROTOBUF_CPPFLAGS])
     AC_SUBST([PROTOBUF_LDFLAGS])
     AC_SUBST([HAVE_PROTOBUF])
@@ -1497,7 +1512,12 @@
 AC_MSG_RESULT([  Libxml2 config:       ${XML2CONFIG}])
 AC_MSG_RESULT([  Libxml2 version:      ${POSTGIS_LIBXML2_VERSION}])
 AC_MSG_RESULT([  JSON-C support:       ${HAVE_JSON}])
 AC_MSG_RESULT([  protobuf-c support:   ${HAVE_PROTOBUF}])
+if test "x$HAVE_PROTOBUF" = "xyes"; then
+  AC_MSG_RESULT([  protobuf-c version:   ${PROTOCC_SEMVER}])
+fi
 AC_MSG_RESULT([  PCRE support:         ${HAVE_PCRE}])
 AC_MSG_RESULT([  Perl:                 ${PERL}])
 AC_MSG_RESULT()
Modified: branches/2.4/postgis/Makefile.in
--- branches/2.4/postgis/Makefile.in	2019-07-29 17:36:47 UTC (rev 17645)
+++ branches/2.4/postgis/Makefile.in	2019-07-30 22:27:06 UTC (rev 17646)
@@ -51,8 +51,11 @@
 endif
 ifeq (@HAVE_PROTOBUF@,yes)
-PROTOBUF_OBJ=vector_tile.pb-c.o geobuf.pb-c.o
+PROTOBUF_OBJ = vector_tile.pb-c.o
+ifeq ($(shell expr @PROTOCC_VERSION@ ">=" 10100),1)
+PROTOBUF_OBJ += geobuf.pb-c.o
 endif
+endif
 # SQL preprocessor
 SQLPP = @SQLPP@
@@ -197,9 +200,11 @@
 lwgeom_out_mvt.o: vector_tile.pb-c.h
+ifeq ($(shell expr $(PROTOCC_VERSION) ">=" 10100),1)
 lwgeom_out_geobuf.o: geobuf.pb-c.h
 endif
+endif
 # Borrow the $libdir substitution from PGXS but customise by running the preprocessor
 # and adding the version number
Modified: branches/2.4/postgis/geobuf.c
--- branches/2.4/postgis/geobuf.c	2019-07-29 17:36:47 UTC (rev 17645)
+++ branches/2.4/postgis/geobuf.c	2019-07-30 22:27:06 UTC (rev 17646)
@@ -25,7 +25,7 @@
 #include <math.h>
 #include "geobuf.h"
-#ifdef HAVE_LIBPROTOBUF
+#if defined HAVE_LIBPROTOBUF && defined HAVE_GEOBUF
 #define FEATURES_CAPACITY_INITIAL 50
 #define MAX_PRECISION 1e6
Modified: branches/2.4/postgis/geobuf.h
--- branches/2.4/postgis/geobuf.h	2019-07-29 17:36:47 UTC (rev 17645)
+++ branches/2.4/postgis/geobuf.h	2019-07-30 22:27:06 UTC (rev 17646)
@@ -42,7 +42,7 @@
 #include "lwgeom_pg.h"
 #include "lwgeom_log.h"
 #include "geobuf.pb-c.h"
Modified: branches/2.4/postgis/lwgeom_out_geobuf.c
--- branches/2.4/postgis/lwgeom_out_geobuf.c	2019-07-29 17:36:47 UTC (rev 17645)
+++ branches/2.4/postgis/lwgeom_out_geobuf.c	2019-07-30 22:27:06 UTC (rev 17646)
@@ -45,8 +45,8 @@
 PG_FUNCTION_INFO_V1(pgis_asgeobuf_transfn);
 Datum pgis_asgeobuf_transfn(PG_FUNCTION_ARGS)
-#ifndef HAVE_LIBPROTOBUF
-	elog(ERROR, "Missing libprotobuf-c");
+#if ! (defined HAVE_LIBPROTOBUF && defined HAVE_GEOBUF)
+	elog(ERROR, "Missing libprotobuf-c >= version 1.1");
 	PG_RETURN_NULL();
 #else
 	MemoryContext aggcontext;
@@ -82,8 +82,8 @@
 PG_FUNCTION_INFO_V1(pgis_asgeobuf_finalfn);
 Datum pgis_asgeobuf_finalfn(PG_FUNCTION_ARGS)
 	PG_RETURN_NULL();
 #else
 	uint8_t *buf;
Modified: branches/2.4/postgis_config.h.in
--- branches/2.4/postgis_config.h.in	2019-07-29 17:36:47 UTC (rev 17645)
+++ branches/2.4/postgis_config.h.in	2019-07-30 22:27:06 UTC (rev 17646)
@@ -61,6 +61,9 @@
 /* Define to 1 if libprotobuf-c is present */
 #undef HAVE_LIBPROTOBUF
+/* Define to 1 if libprotobuf-c is >= version 1.1 */
+#undef HAVE_GEOBUF
 /* Define to 1 if libjson is present */
 #undef HAVE_LIBJSON
Modified: branches/2.4/regress/Makefile.in
--- branches/2.4/regress/Makefile.in	2019-07-29 17:36:47 UTC (rev 17645)
+++ branches/2.4/regress/Makefile.in	2019-07-30 22:27:06 UTC (rev 17646)
@@ -23,6 +23,7 @@
 POSTGIS_MINOR_VERSION=@POSTGIS_MINOR_VERSION@
 HAVE_JSON=@HAVE_JSON@
 HAVE_PROTOBUF=@HAVE_PROTOBUF@
+PROTOCC_VERSION=@PROTOCC_VERSION@
 HAVE_SFCGAL=@HAVE_SFCGAL@
 HAVE_BRIN=@HAVE_BRIN@
 MINGWBUILD=@MINGWBUILD@
@@ -251,8 +252,11 @@
 	# protobuf-c adds:
 	# ST_AsMVT, ST_AsGeobuf
 	TESTS += \
-		mvt \
+		mvt
+	TESTS += \
 		geobuf
+endif
 ifeq ($(shell expr $(POSTGIS_PGSQL_VERSION) ">=" 94),1)
 	TESTS += \
 		mvt_jsonb
