[postgis-tickets] r17649 - Travis: Use PG12 image by default
Raul
raul at rmr.ninja
Wed Jul 31 08:22:20 PDT 2019
Author: algunenano
Date: 2019-07-31 08:22:19 -0700 (Wed, 31 Jul 2019)
New Revision: 17649
trunk/.travis.yml
Closes #4446
Modified: trunk/.travis.yml
--- trunk/.travis.yml 2019-07-30 22:27:22 UTC (rev 17648)
+++ trunk/.travis.yml 2019-07-31 15:22:19 UTC (rev 17649)
@@ -4,13 +4,17 @@
language: c
env:
- - tag=pg11-geos37-gdal24-proj52 mode=garden
+ # Use the last stable release to run more tests
+ - tag=pg12-geos37-gdal30-proj611 mode=garden
+ - tag=pg12-geos37-gdal30-proj611 mode=tests
+ - tag=pg12-geos37-gdal30-proj611 mode=debug
+ - tag=pg12-geos37-gdal30-proj611 mode=coverage
+ - tag=pg12-geos37-gdal30-proj611 mode=usan_gcc
+ - tag=pg12-clang-geos37-gdal30-proj611 mode=usan_clang
+ - tag=pg12-geos37-gdal30-proj611 mode=nowagyu
+ # Run tests with different dependecy combinations
- tag=latest mode=tests
- - tag=pg11-geos37-gdal24-proj52 mode=debug
- - tag=pg11-geos37-gdal24-proj52 mode=coverage
- - tag=pg11-geos37-gdal24-proj52 mode=usan_gcc
- - tag=pg11-clang-geos37-gdal24-proj52 mode=usan_clang
- - tag=pg11-geos37-gdal24-proj52 mode=nowagyu
- tag=pg11-geos37-gdal24-proj52 mode=tests
- tag=pg10-geos36-gdal23-proj49 mode=tests
- tag=pg96-geos36-gdal22-proj49 mode=tests
