[postgis-tickets] [PostGIS] #4446: postgis-build-env: Generate new PG12 docker build
PostGIS trac at osgeo.org
Wed Jul 31 08:22:20 PDT 2019
  Reporter:  Algunenano   |      Owner:  Algunenano
      Type:  enhancement  |     Status:  closed
  Priority:  medium       |  Milestone:  Management 2.0
 Component:  buildbots    |    Version:  trunk
Resolution:  fixed        |   Keywords:
Changes (by Raul Marin):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"17649" 17649]:
 #!CommitTicketReference repository="" revision="17649"
 Travis: Use PG12 image by default
 Closes #4446
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4446#comment:2>
