[postgis-tickets] r17650 - Handle POINT EMPTY in shape loader/dumper
Paul Ramsey pramsey at cleverelephant.ca
Wed Jul 31 02:41:52 PDT 2019
Author: pramsey
Date: 2019-07-31 14:41:51 -0700 (Wed, 31 Jul 2019)
New Revision: 17650
   branches/2.3/NEWS
   branches/2.3/loader/pgsql2shp-core.c
   branches/2.3/loader/shp2pgsql-core.c
References #4437
Modified: branches/2.3/NEWS
--- branches/2.3/NEWS	2019-07-31 15:22:19 UTC (rev 17649)
+++ branches/2.3/NEWS	2019-07-31 21:41:51 UTC (rev 17650)
@@ -10,6 +10,7 @@
   - #4406, Throw on invalid characters when decoding geohash (Raúl Marín)
   - #4466, Fix undefined behaviour in _postgis_gserialized_stats (Raúl Marín)
   - #4209, Handle NULL geometry values in pgsql2shp (Paul Ramsey)
+  - #4437, Handle POINT EMPTY in shape loader/dumper (Paul Ramsey)
 PostGIS 2.3.9
Modified: branches/2.3/loader/pgsql2shp-core.c
--- branches/2.3/loader/pgsql2shp-core.c	2019-07-31 15:22:19 UTC (rev 17649)
+++ branches/2.3/loader/pgsql2shp-core.c	2019-07-31 21:41:51 UTC (rev 17650)
@@ -67,7 +67,18 @@
 /** @brief Binary to hexewkb conversion function */
 char *convert_bytes_to_hex(uint8_t *ewkb, size_t size);
+static SHPObject *
+create_point_empty(SHPDUMPERSTATE *state, LWPOINT *lwpoint)
+	SHPObject *obj;
+	const uint8_t ndr_nan[8] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xf8, 0x7f};
+	double double_nan;
+	memcpy(&double_nan, ndr_nan, 8);
+	obj = SHPCreateObject(state->outshptype, -1, 0, NULL, NULL, 1, &double_nan, &double_nan, &double_nan, &double_nan);
+	return obj;
 static SHPObject *
 create_point(SHPDUMPERSTATE *state, LWPOINT *lwpoint)
@@ -2108,7 +2119,14 @@
 			switch (lwgeom->type)
 			case POINTTYPE:
-				obj = create_point(state, lwgeom_as_lwpoint(lwgeom));
+				if (lwgeom_is_empty(lwgeom))
+					obj = create_point_empty(state, lwgeom_as_lwpoint(lwgeom));
+				else
+					obj = create_point(state, lwgeom_as_lwpoint(lwgeom));
 				break;
 			case MULTIPOINTTYPE:
Modified: branches/2.3/loader/shp2pgsql-core.c
--- branches/2.3/loader/shp2pgsql-core.c	2019-07-31 15:22:19 UTC (rev 17649)
+++ branches/2.3/loader/shp2pgsql-core.c	2019-07-31 21:41:51 UTC (rev 17650)
@@ -240,42 +240,51 @@
 	FLAGS_SET_Z(dims, state->has_z);
 	FLAGS_SET_M(dims, state->has_m);
-	/* Allocate memory for our array of LWPOINTs and our dynptarrays */
-	lwmultipoints = malloc(sizeof(LWPOINT *) * obj->nVertices);
-	/* We need an array of pointers to each of our sub-geometries */
-	for (u = 0; u < obj->nVertices; u++)
+	/* POINT EMPTY encoded as POINT(NaN NaN) */
+	if (obj->nVertices == 1 && isnan(obj->padfX[0]) && isnan(obj->padfY[0]))
-		/* Create a ptarray containing a single point */
-		POINTARRAY *pa = ptarray_construct_empty(state->has_z, state->has_m, 1);
+		lwgeom = lwpoint_as_lwgeom(lwpoint_construct_empty(state->from_srid, state->has_z, state->has_m));
+	/* Not empty */
+	else
+		/* Allocate memory for our array of LWPOINTs and our dynptarrays */
+		lwmultipoints = malloc(sizeof(LWPOINT *) * obj->nVertices);
-		/* Generate the point */
-		point4d.x = obj->padfX[u];
-		point4d.y = obj->padfY[u];
+		/* We need an array of pointers to each of our sub-geometries */
+		for (u = 0; u < obj->nVertices; u++)
+			/* Create a ptarray containing a single point */
+			POINTARRAY *pa = ptarray_construct_empty(state->has_z, state->has_m, 1);
-		if (state->has_z)
-			point4d.z = obj->padfZ[u];
-		if (state->has_m)
-			point4d.m = obj->padfM[u];
+			/* Generate the point */
+			point4d.x = obj->padfX[u];
+			point4d.y = obj->padfY[u];
-		/* Add in the point! */
-		ptarray_append_point(pa, &point4d, LW_TRUE);
+			if (state->has_z)
+				point4d.z = obj->padfZ[u];
+			if (state->has_m)
+				point4d.m = obj->padfM[u];
-		/* Generate the LWPOINT */
-		lwmultipoints[u] = lwpoint_as_lwgeom(lwpoint_construct(state->from_srid, NULL, pa));
+			/* Add in the point! */
+			ptarray_append_point(pa, &point4d, LW_TRUE);
-	/* If we have more than 1 vertex then we are working on a MULTIPOINT and so generate a MULTIPOINT
-	rather than a POINT */
-	if ((obj->nVertices > 1) || force_multi)
-		lwgeom = lwcollection_as_lwgeom(lwcollection_construct(MULTIPOINTTYPE, state->from_srid, NULL, obj->nVertices, lwmultipoints));
+			/* Generate the LWPOINT */
+			lwmultipoints[u] = lwpoint_as_lwgeom(lwpoint_construct(state->from_srid, NULL, pa));
+		/* If we have more than 1 vertex then we are working on a MULTIPOINT and so generate a MULTIPOINT
+		rather than a POINT */
+		if ((obj->nVertices > 1) || force_multi)
+			lwgeom = lwcollection_as_lwgeom(lwcollection_construct(MULTIPOINTTYPE, state->from_srid, NULL, obj->nVertices, lwmultipoints));
+		else
+			lwgeom = lwmultipoints[0];
+			lwfree(lwmultipoints);
-	else
-		lwgeom = lwmultipoints[0];
-		lwfree(lwmultipoints);
 	if (state->config->use_wkt)
