[postgis-tickets] r17470 - [raster] raster2pgsql -t auto tile size follows GeoTIFF Natural Block size
Darafei
komzpa at gmail.com
Tue Jun 4 07:55:40 PDT 2019
Author: komzpa
Date: 2019-06-04 07:55:39 -0700 (Tue, 04 Jun 2019)
New Revision: 17470
Added:
trunk/raster/test/regress/loader/TiledAuto-post.pl
trunk/raster/test/regress/loader/TiledAuto-pre.pl
trunk/raster/test/regress/loader/TiledAuto.opts
trunk/raster/test/regress/loader/TiledAuto.select.expected
trunk/raster/test/regress/loader/TiledAuto.select.sql
trunk/raster/test/regress/loader/testraster2.tif
trunk/NEWS
trunk/raster/loader/raster2pgsql.c
trunk/raster/test/regress/Makefile.in
Commonly found in Cloud Optimized GeoTIFFs.
Closes https://github.com/postgis/postgis/pull/408
Closes #4413
Modified: trunk/NEWS
--- trunk/NEWS 2019-06-04 00:30:38 UTC (rev 17469)
+++ trunk/NEWS 2019-06-04 14:55:39 UTC (rev 17470)
@@ -153,8 +153,11 @@
- #4198, Add ST_ConstrainedDelaunayTriangles SFCGAL function (Darafei
Praliaskouski)
- #4412, Support ingesting rasters with NODATA=NaN (Darafei Praliaskouski)
+ - #4413, Raster tile size follows GeoTIFF block size on raster2pgsql -t auto
+ (Darafei Praliaskouski)
PostGIS 2.5.0
2018/09/23
WARNING: If compiling with PostgreSQL+JIT, LLVM >= 6 is required
Modified: trunk/raster/loader/raster2pgsql.c
--- trunk/raster/loader/raster2pgsql.c 2019-06-04 00:30:38 UTC (rev 17469)
+++ trunk/raster/loader/raster2pgsql.c 2019-06-04 14:55:39 UTC (rev 17470)
@@ -450,60 +450,35 @@
-static void calc_tile_size(
- int dimX, int dimY,
- int *tileX, int *tileY
- int i = 0;
- int j = 0;
- int min = 30;
- int max = 100;
+static void
+calc_tile_size(uint32_t dimX, uint32_t dimY, int *tileX, int *tileY)
+ uint32_t min_tile_size = 30;
+ uint32_t max_tile_size = 300;
- int d = 0;
- double r = 0;
- /*int _d = 0;*/
- double _r = -1;
- int _i = 0;
+ for (uint8_t current_dimension = 0; current_dimension <= 1; current_dimension++)
+ uint32_t img_size = (current_dimension == 0) ? dimX : dimY;
+ uint32_t best_gap = max_tile_size;
+ uint32_t best_size = img_size;
- /* j = 0, X */
- for (j = 0; j < 2; j++) {
- _i = 0;
- /*_d = 0;*/
- _r = -1;
- if (j < 1 && dimX <= max) {
- *tileX = dimX;
- continue;
- else if (dimY <= max) {
- *tileY = dimY;
- continue;
- for (i = max; i >= min; i--) {
- if (j < 1) {
- d = dimX / i;
- r = (double) dimX / (double) i;
- else {
- d = dimY / i;
- r = (double) dimY / (double) i;
- r = r - (double) d;
- if (FLT_EQ(_r, -1.0) || (r < _r) || FLT_EQ(r, _r))
+ if (img_size > max_tile_size)
+ for (uint32_t tile_size = max_tile_size; tile_size >= min_tile_size; tile_size--)
- /*_d = d;*/
- _r = r;
- _i = i;
+ uint32_t gap = img_size % tile_size;
+ if (gap < best_gap)
+ best_gap = gap;
+ best_size = tile_size;
- if (j < 1)
- *tileX = _i;
+ if (current_dimension == 0)
+ *tileX = best_size;
else
- *tileY = _i;
+ *tileY = best_size;
@@ -1569,6 +1544,8 @@
int _tile_size[2] = {0, 0};
int xtile = 0;
int ytile = 0;
+ int naturalx = 1;
+ int naturaly = 1;
double gt[6] = {0.};
const char* pszProjectionRef = NULL;
int tilesize = 0;
@@ -1708,38 +1685,8 @@
info->dim[0] = GDALGetRasterXSize(hdsSrc);
info->dim[1] = GDALGetRasterYSize(hdsSrc);
- /* tile size is "auto" */
- if (
- config->tile_size[0] == -1 &&
- config->tile_size[1] == -1
- calc_tile_size(
- info->dim[0], info->dim[1],
- &(config->tile_size[0]), &(config->tile_size[1])
+ tilesize = 0;
- rtinfo(_("Using computed tile size: %dx%d"), config->tile_size[0], config->tile_size[1]);
- /* decide on tile size */
- if (!config->tile_size[0])
- info->tile_size[0] = info->dim[0];
- else
- info->tile_size[0] = config->tile_size[0];
- if (!config->tile_size[1])
- info->tile_size[1] = info->dim[1];
- else
- info->tile_size[1] = config->tile_size[1];
- /* number of tiles */
- if ((uint32_t)info->tile_size[0] != info->dim[0])
- ntiles[0] = (info->dim[0] + info->tile_size[0] - 1) / info->tile_size[0];
- if ((uint32_t)info->tile_size[1] != info->dim[1])
- ntiles[1] = (info->dim[1] + info->tile_size[1] - 1) / info->tile_size[1];
- /* estimate size of 1 tile */
- tilesize = info->tile_size[0] * info->tile_size[1];
/* go through bands for attributes */
for (i = 0; i < info->nband_count; i++) {
hbandSrc = GDALGetRasterBand(hdsSrc, info->nband[i]);
@@ -1753,6 +1700,7 @@
GDALClose(hdsSrc);
return 0;
+ GDALGetBlockSize(hbandSrc, &naturalx, &naturaly);
/* convert data type to that of postgis raster */
info->bandtype[i] = rt_util_gdal_datatype_to_pixtype(info->gdalbandtype[i]);
@@ -1769,10 +1717,40 @@
info->nodataval[i] = 0;
- /* update estimated size of 1 tile */
- tilesize *= rt_pixtype_size(info->bandtype[i]);
+ /* update estimated byte size of 1 pixel */
+ tilesize += rt_pixtype_size(info->bandtype[i]);
+ /* tile size is "auto" */
+ if (config->tile_size[0] == -1 && config->tile_size[1] == -1)
+ calc_tile_size((naturalx > 1) ? (uint32_t)naturalx : info->dim[0],
+ (naturaly > 1) ? (uint32_t)naturaly : info->dim[1],
+ &(config->tile_size[0]),
+ &(config->tile_size[1]));
+ rtinfo(_("Using computed tile size: %dx%d"), config->tile_size[0], config->tile_size[1]);
+ /* decide on tile size */
+ if (!config->tile_size[0])
+ info->tile_size[0] = info->dim[0];
+ else
+ info->tile_size[0] = config->tile_size[0];
+ if (!config->tile_size[1])
+ info->tile_size[1] = info->dim[1];
+ else
+ info->tile_size[1] = config->tile_size[1];
+ /* number of tiles */
+ if ((uint32_t)info->tile_size[0] != info->dim[0])
+ ntiles[0] = (info->dim[0] + info->tile_size[0] - 1) / info->tile_size[0];
+ if ((uint32_t)info->tile_size[1] != info->dim[1])
+ ntiles[1] = (info->dim[1] + info->tile_size[1] - 1) / info->tile_size[1];
+ /* estimate size of 1 tile */
+ tilesize *= info->tile_size[0] * info->tile_size[1];
/* roughly estimate size of one tile and all bands */
tilesize *= 1.1;
if (tilesize > MAXTILESIZE)
Modified: trunk/raster/test/regress/Makefile.in
--- trunk/raster/test/regress/Makefile.in 2019-06-04 00:30:38 UTC (rev 17469)
+++ trunk/raster/test/regress/Makefile.in 2019-06-04 14:55:39 UTC (rev 17470)
@@ -154,7 +154,8 @@
loader/BasicOutDB \
loader/Tiled10x10 \
loader/Tiled10x10Copy \
- loader/Tiled8x8
+ loader/Tiled8x8 \
+ loader/TiledAuto
TESTS = $(TEST_FIRST) \
$(TEST_METADATA) $(TEST_IO) $(TEST_BASIC_FUNC) \
Added: trunk/raster/test/regress/loader/TiledAuto-post.pl
--- trunk/raster/test/regress/loader/TiledAuto-post.pl (rev 0)
+++ trunk/raster/test/regress/loader/TiledAuto-post.pl 2019-06-04 14:55:39 UTC (rev 17470)
@@ -0,0 +1 @@
+unlink "loader/TiledAuto.tif";
Property changes on: trunk/raster/test/regress/loader/TiledAuto-post.pl
___________________________________________________________________
Added: svn:executable
## -0,0 +1 ##
\ No newline at end of property
Added: trunk/raster/test/regress/loader/TiledAuto-pre.pl
--- trunk/raster/test/regress/loader/TiledAuto-pre.pl (rev 0)
+++ trunk/raster/test/regress/loader/TiledAuto-pre.pl 2019-06-04 14:55:39 UTC (rev 17470)
@@ -0,0 +1 @@
+link "loader/testraster2.tif", "loader/TiledAuto.tif";
Property changes on: trunk/raster/test/regress/loader/TiledAuto-pre.pl
## -0,0 +1 ##
Added: trunk/raster/test/regress/loader/TiledAuto.opts
--- trunk/raster/test/regress/loader/TiledAuto.opts (rev 0)
+++ trunk/raster/test/regress/loader/TiledAuto.opts 2019-06-04 14:55:39 UTC (rev 17470)
@@ -0,0 +1 @@
+-t auto -C
Added: trunk/raster/test/regress/loader/TiledAuto.select.expected
--- trunk/raster/test/regress/loader/TiledAuto.select.expected (rev 0)
+++ trunk/raster/test/regress/loader/TiledAuto.select.expected 2019-06-04 14:55:39 UTC (rev 17470)
@@ -0,0 +1 @@
+448
Added: trunk/raster/test/regress/loader/TiledAuto.select.sql
--- trunk/raster/test/regress/loader/TiledAuto.select.sql (rev 0)
+++ trunk/raster/test/regress/loader/TiledAuto.select.sql 2019-06-04 14:55:39 UTC (rev 17470)
@@ -0,0 +1 @@
+select count(*) from loadedrast;
Added: trunk/raster/test/regress/loader/testraster2.tif
(Binary files differ)
Index: trunk/raster/test/regress/loader/testraster2.tif
--- trunk/raster/test/regress/loader/testraster2.tif 2019-06-04 00:30:38 UTC (rev 17469)
+++ trunk/raster/test/regress/loader/testraster2.tif 2019-06-04 14:55:39 UTC (rev 17470)
Property changes on: trunk/raster/test/regress/loader/testraster2.tif
Added: svn:mime-type
## -0,0 +1 ##
+application/octet-stream
