[postgis-tickets] [PostGIS] #4405: Index over ST_Transform(constant, SRID) breaks pg_upgrade
trac at osgeo.org
Tue Jun 4 08:18:58 PDT 2019
Reporter: Algunenano | Owner: Algunenano
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.3.10
Component: build/upgrade/install | Version: 2.3.x
Resolution: | Keywords:
Comment (by Algunenano):
After looking into the code it appears that will also be present with PROJ
6 path as it also requires the projection to be available in
`spatial_ref_sys`.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4405#comment:2>
