[postgis-tickets] r17480 - Fix undefined behaviour in implicit conversions
Raul
raul at rmr.ninja
Mon Jun 10 03:55:10 PDT 2019
Author: algunenano
Date: 2019-06-10 03:55:10 -0700 (Mon, 10 Jun 2019)
New Revision: 17480
trunk/.travis.yml
trunk/NEWS
trunk/ci/travis/run_usan_clang.sh
trunk/liblwgeom/liblwgeom_topo.h
trunk/liblwgeom/liblwgeom_topo_internal.h
trunk/liblwgeom/lwgeom_topo.c
trunk/raster/rt_core/rt_band.c
trunk/raster/rt_core/rt_serialize.c
trunk/raster/rt_core/rt_statistics.c
trunk/raster/rt_core/rt_wkb.c
trunk/raster/rt_pg/rtpg_internal.c
trunk/raster/rt_pg/rtpg_mapalgebra.c
trunk/raster/test/regress/rt_mapalgebra.sql
trunk/topology/postgis_topology.c
Cleans up errors in raster and topology and adds an
extra sanitizer build in Travis
Closes #4383
Closes https://github.com/postgis/postgis/pull/398
Modified: trunk/.travis.yml
--- trunk/.travis.yml 2019-06-09 11:31:34 UTC (rev 17479)
+++ trunk/.travis.yml 2019-06-10 10:55:10 UTC (rev 17480)
@@ -10,7 +10,7 @@
- tag=pg11-geos37-gdal24-proj52 mode=debug
- tag=pg11-geos37-gdal24-proj52 mode=coverage
- tag=pg11-geos37-gdal24-proj52 mode=usan_gcc
- - tag=pg11-geos37-gdal24-proj52 mode=usan_clang
+ - tag=pg11-clang-geos37-gdal24-proj52 mode=usan_clang
- tag=pg11-geos37-gdal24-proj52 mode=nowagyu
- tag=pg11-geos37-gdal24-proj52 mode=tests
- tag=pg10-geos36-gdal23-proj49 mode=tests
Modified: trunk/NEWS
--- trunk/NEWS 2019-06-09 11:31:34 UTC (rev 17479)
+++ trunk/NEWS 2019-06-10 10:55:10 UTC (rev 17480)
@@ -156,6 +156,7 @@
- #4413, Raster tile size follows GeoTIFF block size on raster2pgsql -t auto
(Darafei Praliaskouski)
- #4422, Modernize Python 2 code to get ready for Python 3 (Christian Clauss)
+ - #4383, Fix undefined behaviour in implicit conversions (Raúl Marín)
PostGIS 2.5.0
Modified: trunk/ci/travis/run_usan_clang.sh
--- trunk/ci/travis/run_usan_clang.sh 2019-06-09 11:31:34 UTC (rev 17479)
+++ trunk/ci/travis/run_usan_clang.sh 2019-06-10 10:55:10 UTC (rev 17480)
@@ -2,12 +2,18 @@
set -e
# Enable undefined behaviour sanitizer using traps
-CFLAGS_STD="-g3 -O0 -mtune=generic -fno-omit-frame-pointer -fsanitize=undefined -fsanitize-undefined-trap-on-error"
+CFLAGS_USAN="-g3 -O0 -mtune=generic -fno-omit-frame-pointer -fsanitize=undefined,implicit-conversion -fsanitize-undefined-trap-on-error -fno-sanitize-recover=implicit-conversion"
LDFLAGS_STD="-Wl,-Bsymbolic-functions -Wl,-z,relro"
-/usr/local/pgsql/bin/pg_ctl -c -l /tmp/logfile start
-./autogen.sh
+# Sanitizer options to continue avoid stopping the runs on leaks (expected on postgres binaries)
+export ASAN_OPTIONS=halt_on_error=false,leak_check_at_exit=false,exitcode=0
+export MSAN_OPTIONS=halt_on_error=false,leak_check_at_exit=false,exitcode=0
+#Run postgres preloading sanitizer libs
+LD_PRELOAD=/usr/lib/clang/7/lib/linux/libclang_rt.asan-x86_64.so /usr/local/pgsql/bin/pg_ctl -c -l /tmp/logfile start
# Build with Clang and usan flags
-./configure CC=clang CFLAGS="${CFLAGS_STD}" LDFLAGS="${LDFLAGS_STD}"
+./autogen.sh
+./configure CC=clang CFLAGS="${CFLAGS_USAN}" LDFLAGS="${LDFLAGS_STD}"
bash ./ci/travis/logbt -- make -j check RUNTESTFLAGS=--verbose
Modified: trunk/liblwgeom/liblwgeom_topo.h
--- trunk/liblwgeom/liblwgeom_topo.h 2019-06-09 11:31:34 UTC (rev 17479)
+++ trunk/liblwgeom/liblwgeom_topo.h 2019-06-10 10:55:10 UTC (rev 17480)
@@ -222,7 +222,7 @@
double dist,
uint64_t *numelems,
int fields,
- int limit);
+ int64_t limit);
* Insert nodes
@@ -282,7 +282,7 @@
double dist,
uint64_t *numelems,
int fields,
- int limit);
+ int64_t limit);
* Get next available edge identifier
Modified: trunk/liblwgeom/liblwgeom_topo_internal.h
--- trunk/liblwgeom/liblwgeom_topo_internal.h 2019-06-09 11:31:34 UTC (rev 17479)
+++ trunk/liblwgeom/liblwgeom_topo_internal.h 2019-06-10 10:55:10 UTC (rev 17480)
@@ -54,7 +54,7 @@
double dist,
uint64_t *numelems,
int fields,
- uint64_t limit);
+ int64_t limit);
LWT_ISO_NODE *lwt_be_getNodeById(LWT_TOPOLOGY *topo, const LWT_ELEMID *ids, uint64_t *numelems, int fields);
@@ -70,7 +70,7 @@
double dist,
uint64_t *numelems,
int fields,
- uint64_t limit);
+ int64_t limit);
int lwt_be_insertEdges(LWT_TOPOLOGY *topo, LWT_ISO_EDGE *edge, uint64_t numelems);
int
lwt_be_updateEdges(LWT_TOPOLOGY* topo, const LWT_ISO_EDGE* sel_edge, int sel_fields, const LWT_ISO_EDGE* upd_edge, int upd_fields, const LWT_ISO_EDGE* exc_edge, int exc_fields);
Modified: trunk/liblwgeom/lwgeom_topo.c
--- trunk/liblwgeom/lwgeom_topo.c 2019-06-09 11:31:34 UTC (rev 17479)
+++ trunk/liblwgeom/lwgeom_topo.c 2019-06-10 10:55:10 UTC (rev 17480)
@@ -163,7 +163,7 @@
double dist,
uint64_t *numelems,
int fields,
- uint64_t limit)
+ int64_t limit)
CBT5(topo, getNodeWithinDistance2D, pt, dist, numelems, fields, limit);
@@ -252,7 +252,7 @@
double dist,
uint64_t *numelems,
int fields,
- uint64_t limit)
+ int64_t limit)
CBT5(topo, getEdgeWithinDistance2D, pt, dist, numelems, fields, limit);
Modified: trunk/raster/rt_core/rt_band.c
--- trunk/raster/rt_core/rt_band.c 2019-06-09 11:31:34 UTC (rev 17479)
+++ trunk/raster/rt_core/rt_band.c 2019-06-10 10:55:10 UTC (rev 17480)
@@ -978,7 +978,7 @@
int *converted
rt_pixtype pixtype = PT_END;
- unsigned char* data = NULL;
+ uint8_t *data = NULL;
uint32_t offset = 0;
int32_t checkvalint = 0;
@@ -1044,7 +1044,7 @@
break;
case PT_8BSI: {
- data[offset] = rt_util_clamp_to_8BSI(val);
+ data[offset] = (uint8_t)rt_util_clamp_to_8BSI(val);
checkvalint = (int8_t) data[offset];
break;
@@ -1300,7 +1300,7 @@
#endif
case PT_8BSI: {
- int8_t val = data[offset];
+ int8_t val = (int8_t)data[offset];
*value = val;
break;
@@ -1491,10 +1491,10 @@
*npixels = NULL;
/* maximum extent */
- max_extent[0] = x - distance[0]; /* min X */
- max_extent[1] = y - distance[1]; /* min Y */
- max_extent[2] = x + distance[0]; /* max X */
- max_extent[3] = y + distance[1]; /* max Y */
+ max_extent[0] = x - (int)distance[0]; /* min X */
+ max_extent[1] = y - (int)distance[1]; /* min Y */
+ max_extent[2] = x + (int)distance[0]; /* max X */
+ max_extent[3] = y + (int)distance[1]; /* max Y */
RASTER_DEBUGF(4, "Maximum Extent: (%d, %d, %d, %d)",
max_extent[0], max_extent[1], max_extent[2], max_extent[3]);
@@ -1504,10 +1504,10 @@
_d[0]++;
_d[1]++;
- extent[0] = x - _d[0]; /* min x */
- extent[1] = y - _d[1]; /* min y */
- extent[2] = x + _d[0]; /* max x */
- extent[3] = y + _d[1]; /* max y */
+ extent[0] = x - (int)_d[0]; /* min x */
+ extent[1] = y - (int)_d[1]; /* min y */
+ extent[2] = x + (int)_d[0]; /* max x */
+ extent[3] = y + (int)_d[1]; /* max y */
RASTER_DEBUGF(4, "Processing distances: %d x %d", _d[0], _d[1]);
RASTER_DEBUGF(4, "Extent: (%d, %d, %d, %d)",
Modified: trunk/raster/rt_core/rt_serialize.c
--- trunk/raster/rt_core/rt_serialize.c 2019-06-09 11:31:34 UTC (rev 17479)
+++ trunk/raster/rt_core/rt_serialize.c 2019-06-10 10:55:10 UTC (rev 17480)
@@ -261,7 +261,7 @@
read_int16(const uint8_t** from, uint8_t littleEndian) {
assert(NULL != from);
- return read_uint16(from, littleEndian);
+ return (int16_t)read_uint16(from, littleEndian);
/* unused up to now
@@ -333,7 +333,7 @@
read_int32(const uint8_t** from, uint8_t littleEndian) {
- return read_uint32(from, littleEndian);
+ return (int32_t)read_uint32(from, littleEndian);
/* unused up to now
@@ -625,7 +625,7 @@
case PT_8BSI: {
int8_t v = band->nodataval;
- *ptr = v;
+ *ptr = (uint8_t)v;
ptr += 1;
break;
Modified: trunk/raster/rt_core/rt_statistics.c
--- trunk/raster/rt_core/rt_statistics.c 2019-06-09 11:31:34 UTC (rev 17479)
+++ trunk/raster/rt_core/rt_statistics.c 2019-06-10 10:55:10 UTC (rev 17480)
@@ -113,7 +113,7 @@
uint64_t *cK, double *cM, double *cQ
uint32_t x = 0;
- uint32_t y = 0;
+ int64_t y = 0;
uint32_t z = 0;
uint32_t diff = 0;
@@ -928,7 +928,7 @@
RASTER_DEBUGF(5, "deleting index: %d => %f", i, qle->value);
- qll->index[i].index = -1;
+ qll->index[i].index = UINT32_MAX;
qll->index[i].element = NULL;
@@ -973,7 +973,7 @@
RASTER_DEBUG(5, "resetting index");
for (i = 0; i < qll->index_max; i++) {
@@ -1032,7 +1032,7 @@
uint32_t j = 0;
uint32_t k = 0;
uint32_t x = 0;
- uint32_t y = 0;
+ int64_t y = 0;
uint32_t z = 0;
uint32_t idx = 0;
Modified: trunk/raster/rt_core/rt_wkb.c
--- trunk/raster/rt_core/rt_wkb.c 2019-06-09 11:31:34 UTC (rev 17479)
+++ trunk/raster/rt_core/rt_wkb.c 2019-06-10 10:55:10 UTC (rev 17480)
@@ -588,7 +588,7 @@
case PT_8BSI: {
- *ptr = v;
ptr += 1;
break;
Modified: trunk/raster/rt_pg/rtpg_internal.c
--- trunk/raster/rt_pg/rtpg_internal.c 2019-06-09 11:31:34 UTC (rev 17479)
+++ trunk/raster/rt_pg/rtpg_internal.c 2019-06-10 10:55:10 UTC (rev 17480)
@@ -60,9 +60,9 @@
const char *tmp = str;
char *result;
int found = 0;
- int length, reslen;
- int oldlen = strlen(oldstr);
- int newlen = strlen(newstr);
+ int64_t length, reslen;
+ size_t oldlen = strlen(oldstr);
+ size_t newlen = strlen(newstr);
int limit = (count != NULL && *count > 0) ? *count : -1;
tmp = str;
Modified: trunk/raster/rt_pg/rtpg_mapalgebra.c
--- trunk/raster/rt_pg/rtpg_mapalgebra.c 2019-06-09 11:31:34 UTC (rev 17479)
+++ trunk/raster/rt_pg/rtpg_mapalgebra.c 2019-06-10 10:55:10 UTC (rev 17480)
@@ -457,10 +457,10 @@
i++;
for (z = 0; z < arg->rasters; z++) {
- _pos[i] = arg->src_pixel[z][0] + 1;
+ _pos[i] = (Datum)arg->src_pixel[z][0] + 1;
i++;
- _pos[i] = arg->src_pixel[z][1] + 1;
+ _pos[i] = (Datum)arg->src_pixel[z][1] + 1;
i++;
@@ -7068,8 +7068,8 @@
_pixel[i] = 0;
/* row/column */
- _x = x - (int) _rastoffset[i][0];
- _y = y - (int) _rastoffset[i][1];
+ _x = (int)x - (int)_rastoffset[i][0];
+ _y = (int)y - (int)_rastoffset[i][1];
/* store _x and _y in 1-based */
_pos[i][0] = _x + 1;
Modified: trunk/raster/test/regress/rt_mapalgebra.sql
--- trunk/raster/test/regress/rt_mapalgebra.sql 2019-06-09 11:31:34 UTC (rev 17479)
+++ trunk/raster/test/regress/rt_mapalgebra.sql 2019-06-10 10:55:10 UTC (rev 17480)
@@ -115,8 +115,6 @@
DO $$ DECLARE r record;
BEGIN
-- NOTE: added OFFSET 0 to CTE clauses to force PostgreSQL 12+ to materialize like old versions did
--- this ONLY works for PostgreSQL version 9.1 or higher
-IF array_to_string(regexp_matches(split_part(version(), ' ', 2), E'([0-9]+)\.([0-9]+)'), '')::int > 90 THEN
WITH foo AS (
SELECT
t1.rid,
@@ -195,111 +193,6 @@
INTO r
FROM foo;
RAISE NOTICE 'record = %', r;
-ELSE
- WITH foo AS (
- SELECT
- t1.rid,
- ST_Union(t2.rast) AS rast
- FROM raster_nmapalgebra_in t1
- JOIN raster_nmapalgebra_in t2
- ON ST_Intersects(t1.rast, t2.rast)
- AND t2.rid BETWEEN 10 AND 18
- WHERE t1.rid = 10
- GROUP BY t1.rid
- ), bar AS (
- SELECT
- t1.rid,
- ST_MapAlgebra(
- ARRAY[ROW(t2.rast, 1)]::rastbandarg[],
- 'raster_nmapalgebra_test(double precision[], int[], text[])'::regprocedure,
- '32BUI',
- 'CUSTOM', t1.rast,
- 1, 1
- ) AS rast
- JOIN foo t2
- ON t1.rid = t2.rid OFFSET 0
- SELECT
- rid,
- (ST_Metadata(rast)),
- (ST_BandMetadata(rast, 1)),
- ST_Value(rast, 1, 1, 1)
- INTO r
- FROM bar;
- RAISE NOTICE 'record = %', r;
- WITH foo AS (
- SELECT
- t1.rid,
- WHERE t1.rid = 14
- GROUP BY t1.rid
- ), bar AS (
- SELECT
- t1.rid,
- ST_MapAlgebra(
- '32BUI',
- 1, 1
- ) AS rast
- JOIN foo t2
- SELECT
- rid,
- INTO r
- FROM bar;
- WITH foo AS (
- SELECT
- t1.rid,
- WHERE t1.rid = 17
- GROUP BY t1.rid
- ), bar AS (
- SELECT
- t1.rid,
- ST_MapAlgebra(
- '32BUI',
- 1, 1,
- '1000'
- ) AS rast
- JOIN foo t2
- SELECT
- rid,
- INTO r
- FROM bar;
-END IF;
END $$;
INSERT INTO raster_nmapalgebra_in
Modified: trunk/topology/postgis_topology.c
--- trunk/topology/postgis_topology.c 2019-06-09 11:31:34 UTC (rev 17479)
+++ trunk/topology/postgis_topology.c 2019-06-10 10:55:10 UTC (rev 17480)
@@ -221,6 +221,7 @@
topo = palloc(sizeof(LWT_BE_TOPOLOGY));
topo->be_data = (LWT_BE_DATA *)be; /* const cast.. */
topo->name = pstrdup(name);
+ topo->hasZ = 0;
dat = SPI_getbinval(SPI_tuptable->vals[0], SPI_tuptable->tupdesc, 1, &isnull);
if ( isnull )
@@ -1366,11 +1367,11 @@
double dist,
uint64_t *numelems,
int fields,
- int limit)
+ int64_t limit)
LWT_ISO_EDGE *edges;
int spi_result;
- int elems_requested = limit;
+ int64_t elems_requested = limit;
size_t hexewkb_size;
char *hexewkb;
MemoryContext oldcontext = CurrentMemoryContext;
@@ -1406,7 +1407,7 @@
else if ( elems_requested > 0 )
- appendStringInfo(sql, " LIMIT %d", elems_requested);
+ appendStringInfo(sql, " LIMIT " INT64_FORMAT, elems_requested);
POSTGIS_DEBUGF(1, "cb_getEdgeWithinDistance2D: query is: %s", sql->data);
spi_result = SPI_execute(sql->data, !topo->be_data->data_changed, limit >= 0 ? limit : 0);
@@ -1422,7 +1423,7 @@
POSTGIS_DEBUGF(1,
"cb_getEdgeWithinDistance2D: edge query "
- "(limited by %d) returned " UINT64_FORMAT " rows",
+ "(limited by " INT64_FORMAT ") returned " UINT64_FORMAT " rows",
elems_requested,
SPI_processed);
*numelems = SPI_processed;
@@ -1466,7 +1467,7 @@
double dist,
uint64_t *numelems,
int fields,
- int limit)
+ int64_t limit)
LWT_ISO_NODE *nodes;
@@ -1475,7 +1476,7 @@
char *hexewkb;
StringInfoData sqldata;
StringInfo sql = &sqldata;
uint64_t i;
initStringInfo(sql);
@@ -1514,7 +1515,7 @@
MemoryContextSwitchTo( oldcontext ); /* switch back */
@@ -1530,7 +1531,7 @@
POSTGIS_DEBUGF(1,
"cb_getNodeWithinDistance2D: node query "
elems_requested,
SPI_processed);
if ( ! SPI_processed )
