[postgis-tickets] r17487 - Create a gserialized_hash function to hide serialized internals
Paul Ramsey pramsey at cleverelephant.ca
Mon Jun 10 03:12:00 PDT 2019
Author: pramsey
Date: 2019-06-10 15:12:00 -0700 (Mon, 10 Jun 2019)
New Revision: 17487
Added:
   trunk/liblwgeom/lookup3.c
   trunk/GNUmakefile.in
   trunk/liblwgeom/Makefile.in
   trunk/liblwgeom/g_serialized.c
   trunk/liblwgeom/liblwgeom.h.in
   trunk/postgis/lwgeom_btree.c
within the gserialized module, closes #4424
Modified: trunk/GNUmakefile.in
--- trunk/GNUmakefile.in	2019-06-10 20:32:44 UTC (rev 17486)
+++ trunk/GNUmakefile.in	2019-06-10 22:12:00 UTC (rev 17487)
@@ -45,6 +45,7 @@
 	! find . -name '*.c' -o -name '*.h' -o -name '*.proto' | \
 		grep -v lwin_wkt_lex.c | \
 		grep -v lwin_wkt_parse | \
+		grep -v lookup3 | \
 		grep -v vector_tile.pb-c | \
 		grep -v postgis/sqldefines.h | \
 		xargs grep -n '[[:space:]]$$'
Modified: trunk/liblwgeom/Makefile.in
--- trunk/liblwgeom/Makefile.in	2019-06-10 20:32:44 UTC (rev 17486)
+++ trunk/liblwgeom/Makefile.in	2019-06-10 22:12:00 UTC (rev 17487)
@@ -55,6 +55,7 @@
 	measures.o \
 	measures3d.o \
 	ptarray.o \
+	lookup3.o \
 	lwgeom_api.o \
 	lwgeom.o \
 	lwpoint.o \
Modified: trunk/liblwgeom/g_serialized.c
--- trunk/liblwgeom/g_serialized.c	2019-06-10 20:32:44 UTC (rev 17486)
+++ trunk/liblwgeom/g_serialized.c	2019-06-10 22:12:00 UTC (rev 17487)
@@ -181,6 +181,40 @@
+/* Prototype for lookup3.c */
+/* key = the key to hash */
+/* length = length of the key */
+/* pc = IN: primary initval, OUT: primary hash */
+/* pb = IN: secondary initval, OUT: secondary hash */
+void hashlittle2(const void *key, size_t length, uint32_t *pc, uint32_t *pb);
+uint64_t gserialized_hash(const GSERIALIZED *g1)
+	uint64_t hval;
+	uint32_t pb = 0, pc = 0;
+	/* Point to just the type/coordinate part of buffer */
+	size_t hsz1 = gserialized_header_size(g1);
+	uint8_t *b1 = (uint8_t*)g1 + hsz1;
+	/* Calculate size of type/coordinate buffer */
+	size_t sz1 = SIZE_GET(g1->size);
+	size_t bsz1 = sz1 - hsz1;
+	/* Calculate size of srid/type/coordinate buffer */
+	int32_t srid = gserialized_get_srid(g1);
+	size_t bsz2 = bsz1 + sizeof(int);
+	uint8_t *b2 = lwalloc(bsz2);
+	/* Copy srid into front of combined buffer */
+	memcpy(b2, &srid, sizeof(int));
+	/* Copy type/coordinates into rest of combined buffer */
+	memcpy(b2+sizeof(int), b1, bsz1);
+	/* Hash combined buffer */
+	hashlittle2(b2, bsz1, &pb, &pc);
+	lwfree(b2);
+	hval = pc + (((uint64_t)pb)<<32);
+	return hval;
 /* Unfortunately including advanced instructions is something that
 only helps a small sliver of users who can build their own
 knowing the target system they will be running on. Packagers
Modified: trunk/liblwgeom/liblwgeom.h.in
--- trunk/liblwgeom/liblwgeom.h.in	2019-06-10 20:32:44 UTC (rev 17486)
+++ trunk/liblwgeom/liblwgeom.h.in	2019-06-10 22:12:00 UTC (rev 17487)
@@ -689,6 +689,13 @@
 extern uint32_t gserialized_header_size(const GSERIALIZED *gser);
+* Returns a hash code for the srid/type/geometry information
+* in the GSERIALIZED. Ignores metadata like flags and optional
+* boxes, etc.
+extern uint64_t gserialized_hash(const GSERIALIZED *g);
 * Extract the SRID from the serialized form (it is packed into
 * three bytes so this is a handy function).
Added: trunk/liblwgeom/lookup3.c
--- trunk/liblwgeom/lookup3.c	                        (rev 0)
+++ trunk/liblwgeom/lookup3.c	2019-06-10 22:12:00 UTC (rev 17487)
@@ -0,0 +1,778 @@
+lookup3.c, by Bob Jenkins, May 2006, Public Domain.
+These are functions for producing 32-bit hashes for hash table lookup.
+hashword(), hashlittle(), hashlittle2(), hashbig(), mix(), and final()
+are externally useful functions.  Routines to test the hash are included
+if SELF_TEST is defined.  You can use this free for any purpose.  It's in
+the public domain.  It has no warranty.
+You probably want to use hashlittle().  hashlittle() and hashbig()
+hash byte arrays.  hashlittle() is is faster than hashbig() on
+little-endian machines.  Intel and AMD are little-endian machines.
+On second thought, you probably want hashlittle2(), which is identical to
+hashlittle() except it returns two 32-bit hashes for the price of one.
+You could implement hashbig2() if you wanted but I haven't bothered here.
+If you want to find a hash of, say, exactly 7 integers, do
+  a = i1;  b = i2;  c = i3;
+  mix(a,b,c);
+  a += i4; b += i5; c += i6;
+  mix(a,b,c);
+  a += i7;
+  final(a,b,c);
+then use c as the hash value.  If you have a variable length array of
+4-byte integers to hash, use hashword().  If you have a byte array (like
+a character string), use hashlittle().  If you have several byte arrays, or
+a mix of things, see the comments above hashlittle().
+Why is this so big?  I read 12 bytes at a time into 3 4-byte integers,
+then mix those integers.  This is fast (you can do a lot more thorough
+mixing with 12*3 instructions on 3 integers than you can with 3 instructions
+on 1 byte), but shoehorning those bytes into integers efficiently is messy.
+#define SELF_TEST 1
+#include <stdio.h>      /* defines printf for tests */
+#include <time.h>       /* defines time_t for timings in the test */
+#include <stdint.h>     /* defines uint32_t etc */
+#include <sys/param.h>  /* attempt to define endianness */
+#ifdef linux
+# include <endian.h>    /* attempt to define endianness */
+#endif
+ * My best guess at if you are big-endian or little-endian.  This may
+ * need adjustment.
+#if (defined(__BYTE_ORDER) && defined(__LITTLE_ENDIAN) && \
+     __BYTE_ORDER == __LITTLE_ENDIAN) || \
+    (defined(i386) || defined(__i386__) || defined(__i486__) || \
+     defined(__i586__) || defined(__i686__) || defined(vax) || defined(MIPSEL))
+# define HASH_LITTLE_ENDIAN 1
+# define HASH_BIG_ENDIAN 0
+#elif (defined(__BYTE_ORDER) && defined(__BIG_ENDIAN) && \
+       __BYTE_ORDER == __BIG_ENDIAN) || \
+      (defined(sparc) || defined(POWERPC) || defined(mc68000) || defined(sel))
+# define HASH_LITTLE_ENDIAN 0
+# define HASH_BIG_ENDIAN 1
+#else
+#endif
+#define hashsize(n) ((uint32_t)1<<(n))
+#define hashmask(n) (hashsize(n)-1)
+#define rot(x,k) (((x)<<(k)) | ((x)>>(32-(k))))
+#if 0
+static uint32_t hashword(const uint32_t *k, size_t length, uint32_t initval);
+static void hashword2 (const uint32_t *k, size_t length, uint32_t *pc, uint32_t *pb);
+static uint32_t hashlittle( const void *key, size_t length, uint32_t initval);
+static uint32_t hashbig( const void *key, size_t length, uint32_t initval);
+#endif
+mix -- mix 3 32-bit values reversibly.
+This is reversible, so any information in (a,b,c) before mix() is
+still in (a,b,c) after mix().
+If four pairs of (a,b,c) inputs are run through mix(), or through
+mix() in reverse, there are at least 32 bits of the output that
+are sometimes the same for one pair and different for another pair.
+This was tested for:
+* pairs that differed by one bit, by two bits, in any combination
+  of top bits of (a,b,c), or in any combination of bottom bits of
+  (a,b,c).
+* "differ" is defined as +, -, ^, or ~^.  For + and -, I transformed
+  the output delta to a Gray code (a^(a>>1)) so a string of 1's (as
+  is commonly produced by subtraction) look like a single 1-bit
+  difference.
+* the base values were pseudorandom, all zero but one bit set, or
+  all zero plus a counter that starts at zero.
+Some k values for my "a-=c; a^=rot(c,k); c+=b;" arrangement that
+satisfy this are
+    4  6  8 16 19  4
+    9 15  3 18 27 15
+   14  9  3  7 17  3
+Well, "9 15 3 18 27 15" didn't quite get 32 bits diffing
+for "differ" defined as + with a one-bit base and a two-bit delta.  I
+used http://burtleburtle.net/bob/hash/avalanche.html to choose
+the operations, constants, and arrangements of the variables.
+This does not achieve avalanche.  There are input bits of (a,b,c)
+that fail to affect some output bits of (a,b,c), especially of a.  The
+most thoroughly mixed value is c, but it doesn't really even achieve
+avalanche in c.
+This allows some parallelism.  Read-after-writes are good at doubling
+the number of bits affected, so the goal of mixing pulls in the opposite
+direction as the goal of parallelism.  I did what I could.  Rotates
+seem to cost as much as shifts on every machine I could lay my hands
+on, and rotates are much kinder to the top and bottom bits, so I used
+rotates.
+#define mix(a,b,c) \
+  a -= c;  a ^= rot(c, 4);  c += b; \
+  b -= a;  b ^= rot(a, 6);  a += c; \
+  c -= b;  c ^= rot(b, 8);  b += a; \
+  a -= c;  a ^= rot(c,16);  c += b; \
+  b -= a;  b ^= rot(a,19);  a += c; \
+  c -= b;  c ^= rot(b, 4);  b += a; \
+final -- final mixing of 3 32-bit values (a,b,c) into c
+Pairs of (a,b,c) values differing in only a few bits will usually
+produce values of c that look totally different.  This was tested for
+  (a,b,c).
+  difference.
+These constants passed:
+ 14 11 25 16 4 14 24
+ 12 14 25 16 4 14 24
+and these came close:
+  4  8 15 26 3 22 24
+ 10  8 15 26 3 22 24
+ 11  8 15 26 3 22 24
+#define final(a,b,c) \
+  c ^= b; c -= rot(b,14); \
+  a ^= c; a -= rot(c,11); \
+  b ^= a; b -= rot(a,25); \
+  c ^= b; c -= rot(b,16); \
+  a ^= c; a -= rot(c,4);  \
+  b ^= a; b -= rot(a,14); \
+  c ^= b; c -= rot(b,24); \
+#if 0
+ This works on all machines.  To be useful, it requires
+ -- that the key be an array of uint32_t's, and
+ -- that the length be the number of uint32_t's in the key
+ The function hashword() is identical to hashlittle() on little-endian
+ machines, and identical to hashbig() on big-endian machines,
+ except that the length has to be measured in uint32_ts rather than in
+ bytes.  hashlittle() is more complicated than hashword() only because
+ hashlittle() has to dance around fitting the key bytes into registers.
+const uint32_t *k,                   /* the key, an array of uint32_t values */
+size_t          length,               /* the length of the key, in uint32_ts */
+uint32_t        initval)         /* the previous hash, or an arbitrary value */
+  uint32_t a,b,c;
+  /* Set up the internal state */
+  a = b = c = 0xdeadbeef + (((uint32_t)length)<<2) + initval;
+  /*------------------------------------------------- handle most of the key */
+  while (length > 3)
+    a += k[0];
+    b += k[1];
+    c += k[2];
+    mix(a,b,c);
+    length -= 3;
+    k += 3;
+  /*------------------------------------------- handle the last 3 uint32_t's */
+  switch(length)                     /* all the case statements fall through */
+  case 3 : c+=k[2];
+  case 2 : b+=k[1];
+  case 1 : a+=k[0];
+    final(a,b,c);
+  case 0:     /* case 0: nothing left to add */
+    break;
+  /*------------------------------------------------------ report the result */
+  return c;
+#endif
+#if 0
+hashword2() -- same as hashword(), but take two seeds and return two
+32-bit values.  pc and pb must both be nonnull, and *pc and *pb must
+both be initialized with seeds.  If you pass in (*pb)==0, the output
+(*pc) will be the same as the return value from hashword().
+uint32_t       *pc,                      /* IN: seed OUT: primary hash value */
+uint32_t       *pb)               /* IN: more seed OUT: secondary hash value */
+  uint32_t a,b,c;
+  a = b = c = 0xdeadbeef + ((uint32_t)(length<<2)) + *pc;
+  c += *pb;
+    a += k[0];
+    b += k[1];
+    c += k[2];
+    mix(a,b,c);
+    length -= 3;
+    k += 3;
+  case 3 : c+=k[2];
+  case 2 : b+=k[1];
+  case 1 : a+=k[0];
+    final(a,b,c);
+    break;
+  *pc=c; *pb=b;
+#endif
+hashlittle() -- hash a variable-length key into a 32-bit value
+  k       : the key (the unaligned variable-length array of bytes)
+  length  : the length of the key, counting by bytes
+  initval : can be any 4-byte value
+Returns a 32-bit value.  Every bit of the key affects every bit of
+the return value.  Two keys differing by one or two bits will have
+totally different hash values.
+The best hash table sizes are powers of 2.  There is no need to do
+mod a prime (mod is sooo slow!).  If you need less than 32 bits,
+use a bitmask.  For example, if you need only 10 bits, do
+  h = (h & hashmask(10));
+In which case, the hash table should have hashsize(10) elements.
+If you are hashing n strings (uint8_t **)k, do it like this:
+  for (i=0, h=0; i<n; ++i) h = hashlittle( k[i], len[i], h);
+By Bob Jenkins, 2006.  bob_jenkins at burtleburtle.net.  You may use this
+code any way you wish, private, educational, or commercial.  It's free.
+Use for hash table lookup, or anything where one collision in 2^^32 is
+acceptable.  Do NOT use for cryptographic purposes.
+#if 0
+  uint32_t a,b,c;                                          /* internal state */
+  union { const void *ptr; size_t i; } u;     /* needed for Mac Powerbook G4 */
+  a = b = c = 0xdeadbeef + ((uint32_t)length) + initval;
+  u.ptr = key;
+  if (HASH_LITTLE_ENDIAN && ((u.i & 0x3) == 0)) {
+    const uint32_t *k = (const uint32_t *)key;         /* read 32-bit chunks */
+    // const uint8_t  *k8;
+    /*------ all but last block: aligned reads and affect 32 bits of (a,b,c) */
+    while (length > 12)
+      a += k[0];
+      b += k[1];
+      c += k[2];
+      mix(a,b,c);
+      length -= 12;
+      k += 3;
+    /*----------------------------- handle the last (probably partial) block */
+     * "k[2]&0xffffff" actually reads beyond the end of the string, but
+     * then masks off the part it's not allowed to read.  Because the
+     * string is aligned, the masked-off tail is in the same word as the
+     * rest of the string.  Every machine with memory protection I've seen
+     * does it on word boundaries, so is OK with this.  But VALGRIND will
+     * still catch it and complain.  The masking trick does make the hash
+     * noticably faster for short strings (like English words).
+#ifndef VALGRIND
+    switch(length)
+    case 12: c+=k[2]; b+=k[1]; a+=k[0]; break;
+    case 11: c+=k[2]&0xffffff; b+=k[1]; a+=k[0]; break;
+    case 10: c+=k[2]&0xffff; b+=k[1]; a+=k[0]; break;
+    case 9 : c+=k[2]&0xff; b+=k[1]; a+=k[0]; break;
+    case 8 : b+=k[1]; a+=k[0]; break;
+    case 7 : b+=k[1]&0xffffff; a+=k[0]; break;
+    case 6 : b+=k[1]&0xffff; a+=k[0]; break;
+    case 5 : b+=k[1]&0xff; a+=k[0]; break;
+    case 4 : a+=k[0]; break;
+    case 3 : a+=k[0]&0xffffff; break;
+    case 2 : a+=k[0]&0xffff; break;
+    case 1 : a+=k[0]&0xff; break;
+    case 0 : return c;              /* zero length strings require no mixing */
+#else /* make valgrind happy */
+    k8 = (const uint8_t *)k;
+    switch(length)
+    case 11: c+=((uint32_t)k8[10])<<16;  /* fall through */
+    case 10: c+=((uint32_t)k8[9])<<8;    /* fall through */
+    case 9 : c+=k8[8];                   /* fall through */
+    case 7 : b+=((uint32_t)k8[6])<<16;   /* fall through */
+    case 6 : b+=((uint32_t)k8[5])<<8;    /* fall through */
+    case 5 : b+=k8[4];                   /* fall through */
+    case 3 : a+=((uint32_t)k8[2])<<16;   /* fall through */
+    case 2 : a+=((uint32_t)k8[1])<<8;    /* fall through */
+    case 1 : a+=k8[0]; break;
+#endif /* !valgrind */
+  } else if (HASH_LITTLE_ENDIAN && ((u.i & 0x1) == 0)) {
+    const uint16_t *k = (const uint16_t *)key;         /* read 16-bit chunks */
+    const uint8_t  *k8;
+    /*--------------- all but last block: aligned reads and different mixing */
+      a += k[0] + (((uint32_t)k[1])<<16);
+      b += k[2] + (((uint32_t)k[3])<<16);
+      c += k[4] + (((uint32_t)k[5])<<16);
+      mix(a,b,c);
+      length -= 12;
+      k += 6;
+    switch(length)
+    case 12: c+=k[4]+(((uint32_t)k[5])<<16);
+             b+=k[2]+(((uint32_t)k[3])<<16);
+             a+=k[0]+(((uint32_t)k[1])<<16);
+             break;
+    case 10: c+=k[4];
+             break;
+    case 8 : b+=k[2]+(((uint32_t)k[3])<<16);
+             break;
+    case 6 : b+=k[2];
+             break;
+    case 4 : a+=k[0]+(((uint32_t)k[1])<<16);
+             break;
+    case 2 : a+=k[0];
+             break;
+             break;
+    case 0 : return c;                     /* zero length requires no mixing */
+  } else {                        /* need to read the key one byte at a time */
+    const uint8_t *k = (const uint8_t *)key;
+    /*--------------- all but the last block: affect some 32 bits of (a,b,c) */
+      a += k[0];
+      a += ((uint32_t)k[1])<<8;
+      a += ((uint32_t)k[2])<<16;
+      a += ((uint32_t)k[3])<<24;
+      b += k[4];
+      b += ((uint32_t)k[5])<<8;
+      b += ((uint32_t)k[6])<<16;
+      b += ((uint32_t)k[7])<<24;
+      c += k[8];
+      c += ((uint32_t)k[9])<<8;
+      c += ((uint32_t)k[10])<<16;
+      c += ((uint32_t)k[11])<<24;
+      mix(a,b,c);
+      length -= 12;
+      k += 12;
+    /*-------------------------------- last block: affect all 32 bits of (c) */
+    case 12: c+=((uint32_t)k[11])<<24;
+    case 11: c+=((uint32_t)k[10])<<16;
+    case 10: c+=((uint32_t)k[9])<<8;
+    case 9 : c+=k[8];
+    case 8 : b+=((uint32_t)k[7])<<24;
+    case 7 : b+=((uint32_t)k[6])<<16;
+    case 6 : b+=((uint32_t)k[5])<<8;
+    case 5 : b+=k[4];
+    case 4 : a+=((uint32_t)k[3])<<24;
+    case 3 : a+=((uint32_t)k[2])<<16;
+    case 2 : a+=((uint32_t)k[1])<<8;
+    case 1 : a+=k[0];
+             break;
+  final(a,b,c);
+  return c;
+#endif
+ * hashlittle2: return 2 32-bit hash values
+ * This is identical to hashlittle(), except it returns two 32-bit hash
+ * values instead of just one.  This is good enough for hash table
+ * lookup with 2^^64 buckets, or if you want a second hash if you're not
+ * happy with the first, or if you want a probably-unique 64-bit ID for
+ * the key.  *pc is better mixed than *pb, so use *pc first.  If you want
+ * a 64-bit value do something like "*pc + (((uint64_t)*pb)<<32)".
+void hashlittle2(
+  const void *key,       /* the key to hash */
+  size_t      length,    /* length of the key */
+  uint32_t   *pc,        /* IN: primary initval, OUT: primary hash */
+  uint32_t   *pb)        /* IN: secondary initval, OUT: secondary hash */
+  a = b = c = 0xdeadbeef + ((uint32_t)length) + *pc;
+  c += *pb;
+  u.ptr = key;
+      a += k[0];
+      b += k[1];
+      c += k[2];
+      mix(a,b,c);
+      length -= 12;
+      k += 3;
+#ifndef VALGRIND
+    switch(length)
+    case 0 : *pc=c; *pb=b; return;  /* zero length strings require no mixing */
+    switch(length)
+      mix(a,b,c);
+      length -= 12;
+      k += 6;
+    switch(length)
+             break;
+    case 10: c+=k[4];
+             break;
+             break;
+    case 6 : b+=k[2];
+             break;
+             break;
+    case 2 : a+=k[0];
+             break;
+             break;
+      a += k[0];
+      b += k[4];
+      c += k[8];
+      mix(a,b,c);
+      length -= 12;
+      k += 12;
+    case 9 : c+=k[8];
+    case 5 : b+=k[4];
+    case 1 : a+=k[0];
+             break;
+  final(a,b,c);
+  *pc=c; *pb=b;
+#if 0
+ * hashbig():
+ * This is the same as hashword() on big-endian machines.  It is different
+ * from hashlittle() on all machines.  hashbig() takes advantage of
+ * big-endian byte ordering.
+  uint32_t a,b,c;
+  union { const void *ptr; size_t i; } u; /* to cast key to (size_t) happily */
+  u.ptr = key;
+  if (HASH_BIG_ENDIAN && ((u.i & 0x3) == 0)) {
+      a += k[0];
+      b += k[1];
+      c += k[2];
+      mix(a,b,c);
+      length -= 12;
+      k += 3;
+     * "k[2]<<8" actually reads beyond the end of the string, but
+     * then shifts out the part it's not allowed to read.  Because the
+     * string is aligned, the illegal read is in the same word as the
+#ifndef VALGRIND
+    switch(length)
+    case 11: c+=k[2]&0xffffff00; b+=k[1]; a+=k[0]; break;
+    case 10: c+=k[2]&0xffff0000; b+=k[1]; a+=k[0]; break;
+    case 9 : c+=k[2]&0xff000000; b+=k[1]; a+=k[0]; break;
+    case 7 : b+=k[1]&0xffffff00; a+=k[0]; break;
+    case 6 : b+=k[1]&0xffff0000; a+=k[0]; break;
+    case 5 : b+=k[1]&0xff000000; a+=k[0]; break;
+    case 3 : a+=k[0]&0xffffff00; break;
+    case 2 : a+=k[0]&0xffff0000; break;
+    case 1 : a+=k[0]&0xff000000; break;
+    case 11: c+=((uint32_t)k8[10])<<8;  /* fall through */
+    case 10: c+=((uint32_t)k8[9])<<16;  /* fall through */
+    case 9 : c+=((uint32_t)k8[8])<<24;  /* fall through */
+    case 7 : b+=((uint32_t)k8[6])<<8;   /* fall through */
+    case 6 : b+=((uint32_t)k8[5])<<16;  /* fall through */
+    case 5 : b+=((uint32_t)k8[4])<<24;  /* fall through */
+    case 3 : a+=((uint32_t)k8[2])<<8;   /* fall through */
+    case 2 : a+=((uint32_t)k8[1])<<16;  /* fall through */
+    case 1 : a+=((uint32_t)k8[0])<<24; break;
+#endif /* !VALGRIND */
+      a += ((uint32_t)k[0])<<24;
+      a += ((uint32_t)k[1])<<16;
+      a += ((uint32_t)k[2])<<8;
+      a += ((uint32_t)k[3]);
+      b += ((uint32_t)k[4])<<24;
+      b += ((uint32_t)k[5])<<16;
+      b += ((uint32_t)k[6])<<8;
+      b += ((uint32_t)k[7]);
+      c += ((uint32_t)k[8])<<24;
+      c += ((uint32_t)k[9])<<16;
+      c += ((uint32_t)k[10])<<8;
+      c += ((uint32_t)k[11]);
+      mix(a,b,c);
+      length -= 12;
+      k += 12;
+    case 12: c+=k[11];
+    case 11: c+=((uint32_t)k[10])<<8;
+    case 10: c+=((uint32_t)k[9])<<16;
+    case 9 : c+=((uint32_t)k[8])<<24;
+    case 8 : b+=k[7];
+    case 7 : b+=((uint32_t)k[6])<<8;
+    case 6 : b+=((uint32_t)k[5])<<16;
+    case 5 : b+=((uint32_t)k[4])<<24;
+    case 4 : a+=k[3];
+    case 3 : a+=((uint32_t)k[2])<<8;
+    case 2 : a+=((uint32_t)k[1])<<16;
+    case 1 : a+=((uint32_t)k[0])<<24;
+             break;
+  final(a,b,c);
+  return c;
+#endif
Modified: trunk/postgis/lwgeom_btree.c
--- trunk/postgis/lwgeom_btree.c	2019-06-10 20:32:44 UTC (rev 17486)
+++ trunk/postgis/lwgeom_btree.c	2019-06-10 22:12:00 UTC (rev 17487)
@@ -130,27 +130,10 @@
 PG_FUNCTION_INFO_V1(lwgeom_hash);
 Datum lwgeom_hash(PG_FUNCTION_ARGS)
-	Datum hval;
 	GSERIALIZED *g1 = PG_GETARG_GSERIALIZED_P(0);
-	/* Point to just the type/coordinate part of buffer */
-	size_t hsz1 = gserialized_header_size(g1);
-	uint8_t *b1 = (uint8_t*)g1 + hsz1;
-	/* Calculate size of type/coordinate buffer */
-	size_t sz1 = VARSIZE(g1);
-	size_t bsz1 = sz1 - hsz1;
-	/* Calculate size of srid/type/coordinate buffer */
-	int32_t srid = gserialized_get_srid(g1);
-	size_t bsz2 = bsz1 + sizeof(int);
-	uint8_t *b2 = palloc(bsz2);
-	/* Copy srid into front of combined buffer */
-	memcpy(b2, &srid, sizeof(int));
-	/* Copy type/coordinates into rest of combined buffer */
-	memcpy(b2+sizeof(int), b1, bsz1);
-	/* Hash combined buffer */
-	hval = hash_any(b2, bsz2);
-	pfree(b2);
+	uint64_t hval = gserialized_hash(g1);
 	PG_FREE_IF_COPY(g1, 0);
-	PG_RETURN_DATUM(hval);
+	PG_RETURN_DATUM(Int64GetDatum(hval));
