[postgis-tickets] r17481 - Clean postgis_config.h.in and related functions
Raul
raul at rmr.ninja
Mon Jun 10 06:56:14 PDT 2019
Author: algunenano
Date: 2019-06-10 06:56:14 -0700 (Mon, 10 Jun 2019)
New Revision: 17481
trunk/configure.ac
trunk/postgis/lwgeom_functions_basic.c
trunk/postgis/postgis_legacy.c
trunk/postgis_config.h.in
Closes https://github.com/postgis/postgis/pull/412
Closes #4423
Modified: trunk/configure.ac
--- trunk/configure.ac 2019-06-10 10:55:10 UTC (rev 17480)
+++ trunk/configure.ac 2019-06-10 13:56:14 UTC (rev 17481)
@@ -1124,16 +1124,6 @@
AC_SUBST([POSTGIS_SCRIPTS_VERSION])
-dnl ===========================================================================
-dnl Other parameters
-dnl
-dnl Always enable BBOX caching by default
-AC_DEFINE_UNQUOTED([POSTGIS_AUTOCACHE_BBOX], [1], [Enable caching of bounding box within geometries])
-dnl Always enable use of ANALYZE statistics by default
-AC_DEFINE_UNQUOTED([POSTGIS_USE_STATS], [1], [Enable use of ANALYZE statistics])
dnl address standardizer stuff
Modified: trunk/postgis/lwgeom_functions_basic.c
--- trunk/postgis/lwgeom_functions_basic.c 2019-06-10 10:55:10 UTC (rev 17480)
+++ trunk/postgis/lwgeom_functions_basic.c 2019-06-10 13:56:14 UTC (rev 17481)
@@ -44,8 +44,6 @@
Datum LWGEOM_npoints(PG_FUNCTION_ARGS);
Datum LWGEOM_nrings(PG_FUNCTION_ARGS);
Datum ST_Area(PG_FUNCTION_ARGS);
-Datum postgis_uses_stats(PG_FUNCTION_ARGS);
-Datum postgis_autocache_bbox(PG_FUNCTION_ARGS);
Datum postgis_scripts_released(PG_FUNCTION_ARGS);
Datum postgis_version(PG_FUNCTION_ARGS);
Datum postgis_liblwgeom_version(PG_FUNCTION_ARGS);
@@ -207,22 +205,6 @@
PG_RETURN_TEXT_P(result);
-PG_FUNCTION_INFO_V1(postgis_uses_stats);
- PG_RETURN_BOOL(true);
-PG_FUNCTION_INFO_V1(postgis_autocache_bbox);
-#ifdef POSTGIS_AUTOCACHE_BBOX
-#else
- PG_RETURN_BOOL(false);
-#endif
PG_FUNCTION_INFO_V1(postgis_libxml_version);
Datum postgis_libxml_version(PG_FUNCTION_ARGS)
Modified: trunk/postgis/postgis_legacy.c
--- trunk/postgis/postgis_legacy.c 2019-06-10 10:55:10 UTC (rev 17480)
+++ trunk/postgis/postgis_legacy.c 2019-06-10 13:56:14 UTC (rev 17481)
@@ -75,3 +75,5 @@
POSTGIS_DEPRECATE("3.0.0", LWGEOM_mindistance3d);
POSTGIS_DEPRECATE("3.0.0", intersects);
POSTGIS_DEPRECATE("3.0.0", pgis_geometry_accum_finalfn);
+POSTGIS_DEPRECATE("3.0.0", postgis_autocache_bbox);
+POSTGIS_DEPRECATE("2.0.0", postgis_uses_stats);
Modified: trunk/postgis_config.h.in
--- trunk/postgis_config.h.in 2019-06-10 10:55:10 UTC (rev 17480)
+++ trunk/postgis_config.h.in 2019-06-10 13:56:14 UTC (rev 17481)
@@ -14,27 +14,9 @@
language is requested. */
#undef ENABLE_NLS
-/* Define to 1 if you have the MacOS X function CFLocaleCopyCurrent in the
- CoreFoundation framework. */
-#undef HAVE_CFLOCALECOPYCURRENT
-/* Define to 1 if you have the MacOS X function CFPreferencesCopyAppValue in
- the CoreFoundation framework. */
-#undef HAVE_CFPREFERENCESCOPYAPPVALUE
-/* Define if the GNU dcgettext() function is already present or preinstalled.
-#undef HAVE_DCGETTEXT
/* Define for some functions we are interested in */
-#undef HAVE_VASPRINTF
-#undef HAVE_ASPRINTF
#undef HAVE_FSEEKO
-#undef HAVE_STRCASESTR
-/* Define to 1 if you have the <dlfcn.h> header file. */
-#undef HAVE_DLFCN_H
/* Define if the GNU gettext() function is already present or preinstalled. */
#undef HAVE_GETTEXT
@@ -47,9 +29,6 @@
/* ieeefp.h header */
#undef HAVE_IEEEFP_H
-/* Define to 1 if you have the <inttypes.h> header file. */
-#undef HAVE_INTTYPES_H
/* Define to 1 if you have the `geos_c' library (-lgeos_c). */
#undef HAVE_LIBGEOS_C
@@ -86,27 +65,6 @@
/* Define to 1 if you have the <libxml/xpath.h> header file. */
#undef HAVE_LIBXML_XPATH_H
-/* Define to 1 if you have the <memory.h> header file. */
-#undef HAVE_MEMORY_H
-/* Define to 1 if you have the <stdint.h> header file. */
-#undef HAVE_STDINT_H
-/* Define to 1 if you have the <stdlib.h> header file. */
-#undef HAVE_STDLIB_H
-/* Define to 1 if you have the <strings.h> header file. */
-#undef HAVE_STRINGS_H
-/* Define to 1 if you have the <string.h> header file. */
-#undef HAVE_STRING_H
-/* Define to 1 if you have the <sys/stat.h> header file. */
-#undef HAVE_SYS_STAT_H
-/* Define to 1 if you have the <sys/types.h> header file. */
-#undef HAVE_SYS_TYPES_H
/* Define to 1 if you have the <unistd.h> header file. */
#undef HAVE_UNISTD_H
@@ -116,16 +74,12 @@
/* Define to 1 if sfcgal is being built */
#undef HAVE_SFCGAL
-/* Define to the sub-directory in which libtool stores uninstalled libraries.
+/* Define to the sub-directory in which libtool stores uninstalled libraries. */
#undef LT_OBJDIR
/* Location of PostgreSQL locale directory */
#undef PGSQL_LOCALEDIR
-/* Enable caching of bounding box within geometries */
-#undef POSTGIS_AUTOCACHE_BBOX
/* PostGIS build date */
#undef POSTGIS_BUILD_DATE
@@ -159,9 +113,6 @@
/* PROJ library version */
#undef POSTGIS_PROJ_VERSION
-/* PROJ 6: Flag to use the old API */
-#undef ACCEPT_USE_OF_DEPRECATED_PROJ_API_H
/* PostGIS Raster build date */
#undef POSTGIS_RASTER_BUILD_DATE
@@ -189,15 +140,10 @@
/* PostGIS scripts version */
#undef POSTGIS_SCRIPTS_VERSION
-/* Enable use of ANALYZE statistics */
-#undef POSTGIS_USE_STATS
/* PostGIS version */
#undef POSTGIS_VERSION
-/* Define command to determine the current directory during regression */
-#undef PWDREGRESS
/* Define to 1 if you have the ANSI C header files. */
#undef STDC_HEADERS
