[postgis-tickets] r17482 - Include version number in address_standardizer lib
Raul
raul at rmr.ninja
Mon Jun 10 08:12:25 PDT 2019
Author: algunenano
Date: 2019-06-10 08:12:25 -0700 (Mon, 10 Jun 2019)
New Revision: 17482
trunk/NEWS
trunk/extensions/address_standardizer/Makefile.in
Reverts r15933
Closes https://trac.osgeo.org/postgis/ticket/4414
Closes https://github.com/postgis/postgis/pull/413
Modified: trunk/NEWS
--- trunk/NEWS 2019-06-10 13:56:14 UTC (rev 17481)
+++ trunk/NEWS 2019-06-10 15:12:25 UTC (rev 17482)
@@ -17,6 +17,7 @@
from 2.5 (Raúl Marín)
- #4198, Add ST_ConstrainedDelaunayTriangles SFCGAL function (Darafei
Praliaskouski)
+ - #4414, Include version number in address_standardizer lib (Raúl Marín)
PostGIS 3.0.0alpha1
2019/05/26
@@ -71,6 +72,7 @@
- #4331, ST_3DMakeBox now returns error instead of a miniscule box (Regina Obe)
- #4342, Removed "versioned" variants of ST_AsGeoJSON and ST_AsKML (Paul Ramsey)
- #4356, ST_Accum removed. Use array_agg instead. (Darafei Praliaskouski)
* New Features *
- #2902, postgis_geos_noop (Sandro Santilli)
Modified: trunk/extensions/address_standardizer/Makefile.in
--- trunk/extensions/address_standardizer/Makefile.in 2019-06-10 13:56:14 UTC (rev 17481)
+++ trunk/extensions/address_standardizer/Makefile.in 2019-06-10 15:12:25 UTC (rev 17482)
@@ -29,9 +29,13 @@
# SQL preprocessor
SQLPP = @SQLPP@
GREP=@GREP@
-EXTVERSION = @POSTGIS_LIB_VERSION@
-MINORVERSION = @POSTGIS_MAJOR_VERSION at .@POSTGIS_MINOR_VERSION@
-MODULE_big = address_standardizer
+EXTVERSION = @POSTGIS_LIB_VERSION@
+MODULE_big = address_standardizer- at POSTGIS_MAJOR_VERSION@
+MODULEPATH = $$libdir/address_standardizer- at POSTGIS_MAJOR_VERSION@
+ifeq (@LIBINCLUDEMINORVERSION@,yes)
+MODULE_big = address_standardizer- at POSTGIS_MAJOR_VERSION@. at POSTGIS_MINOR_VERSION@
+MODULEPATH = $$libdir/address_standardizer- at POSTGIS_MAJOR_VERSION@. at POSTGIS_MINOR_VERSION@
+endif
EXTENSION = address_standardizer
DATA = sql/$(EXTENSION).sql sql/$(EXTENSION)_data_us.sql
@@ -62,7 +66,7 @@
sql/%.sql: %.sql.in
mkdir -p sql
$(SQLPP) -I../libpgcommon $< | grep -v '^#' | \
- $(PERL) -lpe "s'MODULE_PATHNAME'\$$libdir/${EXTENSION}'g" > $@
+ $(PERL) -lpe "s'MODULE_PATHNAME'\$(MODULEPATH)'g" > $@
%.control: %.control.in Makefile
cat $< \
