[postgis-tickets] r17507 - Fix upgrade issues related to renamed function parameters
Raul
raul at rmr.ninja
Wed Jun 12 02:49:21 PDT 2019
Author: algunenano
Date: 2019-06-12 02:49:20 -0700 (Wed, 12 Jun 2019)
New Revision: 17507
trunk/NEWS
trunk/postgis/postgis_drop_before.sql
References #4334
Closes https://github.com/postgis/postgis/pull/415
Modified: trunk/NEWS
--- trunk/NEWS 2019-06-11 22:02:11 UTC (rev 17506)
+++ trunk/NEWS 2019-06-12 09:49:20 UTC (rev 17507)
@@ -19,6 +19,7 @@
Praliaskouski)
- #4414, Include version number in address_standardizer lib (Raúl Marín)
- #4352, Use CREATE OR REPLACE AGGREGATE for PG12+ (Raúl Marín)
+ - #4334, Fix upgrade issues related to renamed parameters (Raúl Marín)
PostGIS 3.0.0alpha1
2019/05/26
@@ -74,6 +75,7 @@
- #4342, Removed "versioned" variants of ST_AsGeoJSON and ST_AsKML (Paul Ramsey)
- #4356, ST_Accum removed. Use array_agg instead. (Darafei Praliaskouski)
+ - #4334, Fix upgrade issues related to renamed function parameters (Raúl Marín)
* New Features *
- #2902, postgis_geos_noop (Sandro Santilli)
@@ -161,6 +163,7 @@
- #4422, Modernize Python 2 code to get ready for Python 3 (Christian Clauss)
- #4383, Fix undefined behaviour in implicit conversions (Raúl Marín)
PostGIS 2.5.0
Modified: trunk/postgis/postgis_drop_before.sql
--- trunk/postgis/postgis_drop_before.sql 2019-06-11 22:02:11 UTC (rev 17506)
+++ trunk/postgis/postgis_drop_before.sql 2019-06-12 09:49:20 UTC (rev 17507)
@@ -19,13 +19,78 @@
-DROP FUNCTION IF EXISTS AddGeometryColumn(varchar,varchar,varchar,varchar,integer,varchar,integer,boolean);
-DROP FUNCTION IF EXISTS ST_MakeEnvelope(float8, float8, float8, float8);
---changed name of prec arg to be consistent with ST_AsGML/KML
-DROP FUNCTION IF EXISTS ST_AsX3D(geometry, integer, integer);
---changed name of arg: http://trac.osgeo.org/postgis/ticket/1606
-DROP FUNCTION IF EXISTS UpdateGeometrySRID(varchar,varchar,varchar,varchar,integer);
+-- Helper function to drop functions when they match the full signature
+-- Requires schema, name and __identity_arguments__ as extracted from pg_catalog
+CREATE OR REPLACE FUNCTION _postgis_drop_function_if_needed(
+ function_schema text,
+ function_name text,
+ function_arguments text) RETURNS void AS $$
+DECLARE
+ frec RECORD;
+ sql_drop text;
+BEGIN
+ FOR frec IN
+ SELECT p.oid as oid,
+ n.nspname as schema,
+ p.proname as name,
+ pg_catalog.pg_get_function_arguments(p.oid) as arguments,
+ pg_catalog.pg_get_function_identity_arguments(p.oid) as identity_arguments
+ FROM pg_catalog.pg_proc p
+ LEFT JOIN pg_catalog.pg_namespace n ON n.oid = p.pronamespace
+ WHERE
+ LOWER(n.nspname) = LOWER(function_schema) AND
+ LOWER(p.proname) = LOWER(function_name) AND
+ LOWER(pg_catalog.pg_get_function_arguments(p.oid)) ~ LOWER(function_arguments) AND
+ pg_catalog.pg_function_is_visible(p.oid)
+ ORDER BY 1, 2, 4
+ LOOP
+ sql_drop := 'DROP FUNCTION ' || quote_ident(frec.schema) || '.' || quote_ident(frec.name) || ' ( ' || frec.identity_arguments || ' ) ';
+ RAISE DEBUG 'Name (%): %', frec.oid, frec.name;
+ RAISE DEBUG 'Arguments: %', frec.arguments;
+ RAISE DEBUG 'Identity arguments: %', frec.identity_arguments;
+ RAISE DEBUG 'SQL query: %', sql_drop;
+ BEGIN
+ EXECUTE sql_drop;
+ EXCEPTION
+ WHEN OTHERS THEN
+ RAISE EXCEPTION 'Could not drop function %.%. You might need to drop dependant objects. Postgres error: %', function_schema, function_name, SQLERRM;
+ END;
+ END LOOP;
+END;
+$$ LANGUAGE plpgsql;
+-- FUNCTION AddGeometryColumn signature dropped
+-- (catalog_name character varying, schema_name character varying, table_name character varying, column_name character varying, new_srid integer, new_type character varying, new_dim integer, use_typmod boolean)
+SELECT _postgis_drop_function_if_needed
+ '@extschema@',
+ 'AddGeometryColumn',
+ 'catalog_name character varying, schema_name character varying, table_name character varying, column_name character varying, new_srid integer, new_type character varying, new_dim integer, use_typmod boolean'
+-- FUNCTION ST_AsX3D was changed to add versioning for 2.0
+-- (geom geometry, prec integer, options integer)
+ '@extschema@',
+ 'ST_AsX3D',
+ 'geom geometry, prec integer, options integer'
+-- FUNCTION UpdateGeometrySRID changed the name of the args (http://trac.osgeo.org/postgis/ticket/1606) for 2.0
+-- It changed the paramenter `new_srid` to `new_srid_in`
+-- (catalogn_name character varying, schema_name character varying, table_name character varying, column_name character varying, new_srid integer)
+-- Dropping it conditionally since the same signature still exists.
+ '@extschema@',
+ 'UpdateGeometrySRID',
+ 'catalogn_name character varying, schema_name character varying, table_name character varying, column_name character varying, new_srid integer'
--deprecated and removed in 2.1
-- Hack to fix 2.0 naming
-- We can't just drop it since its bound to opclass
@@ -59,32 +124,111 @@
END;
--- Going from multiple functions to default args
--- Need to drop old multiple variants to not get in trouble.
-DROP FUNCTION IF EXISTS ST_AsLatLonText(geometry);
-DROP FUNCTION IF EXISTS ST_AsLatLonText(geometry, text);
-DROP FUNCTION IF EXISTS ST_AsTWKB(geometry,int4);
-DROP FUNCTION IF EXISTS ST_AsTWKB(geometry,int4,int8);
-DROP FUNCTION IF EXISTS ST_AsTWKB(geometry,int4,int8,boolean);
--- Going from un-named to named arguments
-DROP FUNCTION IF EXISTS _st_linecrossingdirection(geometry,geometry);
-DROP FUNCTION IF EXISTS ST_LineCrossingDirection(geometry, geometry);
-DROP FUNCTION IF EXISTS _st_orderingequals(geometry,geometry);
-DROP FUNCTION IF EXISTS st_orderingequals(geometry,geometry);
-DROP FUNCTION IF EXISTS st_askml(geometry, integer); -- changed to use default args in PostGIS 3.0 (r17357)
-DROP FUNCTION IF EXISTS st_askml(geography, integer); -- changed to use default args in PostGIS 3.0 (r17357)
-DROP FUNCTION IF EXISTS st_buffer(geometry, double precision);
+-- FUNCTION ST_AsLatLonText went from multiple signatures to a single one with defaults for 2.2.0
+DROP FUNCTION IF EXISTS ST_AsLatLonText(geometry); -- Does not conflict
+ '@extschema@',
+ 'ST_AsLatLonText',
+ 'geometry, text'
--- Old signatures for protobuf related functions improved in 2.4.0 RC/final
-DROP AGGREGATE IF EXISTS ST_AsMVT(text, int4, text, anyelement);
-DROP FUNCTION IF EXISTS ST_AsMVTGeom(geom geometry, bounds box2d, extent int4, buffer int4, clip_geom bool);
-DROP AGGREGATE IF EXISTS ST_AsGeobuf(text, anyelement);
-DROP FUNCTION IF EXISTS pgis_asgeobuf_transfn(internal, text, anyelement);
-DROP FUNCTION IF EXISTS pgis_asmvt_transfn(internal, text, int4, text, anyelement);
-DROP FUNCTION IF EXISTS ST_CurveToLine(geometry, integer);
-DROP FUNCTION IF EXISTS ST_CurveToLine(geometry);
-DROP VIEW IF EXISTS geometry_columns; -- removed cast 2.2.0 so need to recreate
+-- FUNCTION _st_linecrossingdirection changed argument names in 3.0
+-- Was (geom1 geometry, geom2 geometry) and now (line1 geometry, line2 geometry)
+ '@extschema@',
+ '_st_linecrossingdirection',
+ 'geom1 geometry, geom2 geometry'
+-- FUNCTION ST_LineCrossingDirection changed argument names in 3.0
+ '@extschema@',
+ 'ST_LineCrossingDirection',
+-- FUNCTION _st_orderingequals changed argument names in 3.0
+-- Was (GeometryA geometry, GeometryB geometry) and now (geom1 geometry, geom2 geometry)
+ '@extschema@',
+ '_st_orderingequals',
+ 'GeometryA geometry, GeometryB geometry'
+-- FUNCTION st_orderingequals changed argument names in 3.0
+ '@extschema@',
+ 'st_orderingequals',
+-- FUNCTION st_askml changed to add defaults in 3.0 / r17357
+-- These signatures were superseeded
+DROP FUNCTION IF EXISTS st_askml(geometry, integer); -- Does not conflict
+DROP FUNCTION IF EXISTS st_askml(geography, integer); -- Does not conflict
+-- FUNCTION st_buffer changed to add defaults in 3.0
+-- This signature was superseeded
+DROP FUNCTION IF EXISTS st_buffer(geometry, double precision); -- Does not conflict
+-- FUNCTION ST_CurveToLine changed to add defaults in 2.5
+DROP FUNCTION IF EXISTS ST_CurveToLine(geometry, integer); -- Does not conflict
+DROP FUNCTION IF EXISTS ST_CurveToLine(geometry); -- Does not conflict
+-- geometry_columns changed parameter types so we verify if it needs to be dropped
+-- We check the catalog to see if the view (geometry_columns) has a column
+-- with name `f_table_schema` and type `character varying(256)` as it was
+-- changed to type `name` in 2.2
+DO language 'plpgsql' $$
+BEGIN
+ IF EXISTS
+ WITH oids AS
+ SELECT c.oid as oid,
+ n.nspname,
+ c.relname
+ FROM pg_catalog.pg_class c
+ LEFT JOIN pg_catalog.pg_namespace n ON n.oid = c.relnamespace
+ WHERE c.relname = 'geometry_columns' AND
+ n.nspname = 'public'
+ AND pg_catalog.pg_table_is_visible(c.oid)
+ ORDER BY 2, 3
+ name_attribute AS
+ SELECT a.attname as attname,
+ pg_catalog.format_type(a.atttypid, a.atttypmod) as format_type
+ FROM pg_catalog.pg_attribute a, oids
+ WHERE a.attrelid = oids.oid AND a.attnum > 0 AND NOT a.attisdropped
+ ORDER BY a.attnum
+ SELECT attname, format_type
+ FROM name_attribute
+ WHERE attname = 'f_table_schema' AND format_type = 'character varying(256)'
+ THEN
+ DROP VIEW geometry_columns;
+ END IF;
+END;
+-- DROP auxiliar function (created above)
+DROP FUNCTION _postgis_drop_function_if_needed(text, text, text);
