[postgis-tickets] r17517 - Further re-organization of gserialized, attempting to hide all knowledge
Paul Ramsey
pramsey at cleverelephant.ca
Wed Jun 12 03:04:58 PDT 2019
Author: pramsey
Date: 2019-06-12 15:04:58 -0700 (Wed, 12 Jun 2019)
New Revision: 17517
trunk/liblwgeom/Makefile.in
trunk/liblwgeom/cunit/cu_geodetic.c
trunk/liblwgeom/cunit/cu_gserialized1.c
trunk/liblwgeom/gbox.c
trunk/liblwgeom/gserialized.h
trunk/liblwgeom/gserialized1.c
trunk/liblwgeom/gutil.c
trunk/liblwgeom/liblwgeom.h.in
trunk/liblwgeom/lwcircstring.c
trunk/liblwgeom/lwcollection.c
trunk/liblwgeom/lwcurvepoly.c
trunk/liblwgeom/lwgeodetic.c
trunk/liblwgeom/lwin_twkb.c
trunk/liblwgeom/lwline.c
trunk/liblwgeom/lwpoint.c
trunk/liblwgeom/lwpoly.c
trunk/liblwgeom/lwspheroid.c
trunk/liblwgeom/lwtriangle.c
trunk/liblwgeom/lwutil.c
trunk/liblwgeom/ptarray.c
trunk/libpgcommon/gserialized_gist.c
trunk/libpgcommon/gserialized_gist.h
trunk/libpgcommon/lwgeom_pg.h
trunk/postgis/geography_centroid.c
trunk/postgis/geography_measurement.c
trunk/postgis/gserialized_gist_nd.c
trunk/postgis/gserialized_typmod.c
trunk/postgis/lwgeom_box.c
trunk/postgis/lwgeom_dumppoints.c
trunk/postgis/lwgeom_functions_analytic.c
trunk/postgis/lwgeom_geos.c
trunk/postgis/lwgeom_in_geohash.c
trunk/postgis/lwgeom_inout.c
of the underlying structure behind the API
Modified: trunk/liblwgeom/Makefile.in
--- trunk/liblwgeom/Makefile.in 2019-06-12 15:27:01 UTC (rev 17516)
+++ trunk/liblwgeom/Makefile.in 2019-06-12 22:04:58 UTC (rev 17517)
@@ -96,7 +96,6 @@
gserialized.o \
gserialized1.o \
gserialized2.o \
- gutil.o \
lwgeodetic.o \
lwgeodetic_tree.o \
lwrandom.o \
Modified: trunk/liblwgeom/cunit/cu_geodetic.c
--- trunk/liblwgeom/cunit/cu_geodetic.c 2019-06-12 15:27:01 UTC (rev 17516)
+++ trunk/liblwgeom/cunit/cu_geodetic.c 2019-06-12 22:04:58 UTC (rev 17517)
@@ -853,7 +853,7 @@
LWGEOM *geom;
int i = 0;
- GBOX *gbox = gbox_new(gflags(0,0,0));
+ GBOX *gbox = gbox_new(lwflags(0,0,0));
BOX3D *box3d;
char ewkt[][512] =
@@ -1348,7 +1348,7 @@
/* Init to WGS84 */
spheroid_init(&s, WGS84_MAJOR_AXIS, WGS84_MINOR_AXIS);
- gbox.flags = gflags(0, 0, 1);
+ gbox.flags = lwflags(0, 0, 1);
/* Medford lot test polygon */
lwg = lwgeom_from_wkt("POLYGON((-122.848227067007 42.5007249610493,-122.848309475585 42.5007179884263,-122.848327688675 42.500835880696,-122.848245279942 42.5008428533324,-122.848227067007 42.5007249610493))", LW_PARSER_CHECK_NONE);
@@ -1429,7 +1429,7 @@
/* Init to WGS84 */
/* One-degree square by equator */
lwg = lwgeom_from_wkt("POLYGON((1 20,1 21,2 21,2 20,1 20))", LW_PARSER_CHECK_NONE);
Modified: trunk/liblwgeom/cunit/cu_gserialized1.c
--- trunk/liblwgeom/cunit/cu_gserialized1.c 2019-06-12 15:27:01 UTC (rev 17516)
+++ trunk/liblwgeom/cunit/cu_gserialized1.c 2019-06-12 22:04:58 UTC (rev 17517)
@@ -102,7 +102,7 @@
FLAGS_SET_GEODETIC(flags, 1);
CU_ASSERT_EQUAL(1, FLAGS_GET_GEODETIC(flags));
- flags = gflags(1, 0, 1); /* z=1, m=0, geodetic=1 */
+ flags = lwflags(1, 0, 1); /* z=1, m=0, geodetic=1 */
CU_ASSERT_EQUAL(1, FLAGS_GET_Z(flags));
@@ -109,7 +109,7 @@
CU_ASSERT_EQUAL(0, FLAGS_GET_M(flags));
CU_ASSERT_EQUAL(2, FLAGS_GET_ZM(flags));
- flags = gflags(1, 1, 1); /* z=1, m=1, geodetic=1 */
+ flags = lwflags(1, 1, 1); /* z=1, m=1, geodetic=1 */
@@ -116,7 +116,7 @@
CU_ASSERT_EQUAL(1, FLAGS_GET_M(flags));
CU_ASSERT_EQUAL(3, FLAGS_GET_ZM(flags));
- flags = gflags(0, 1, 0); /* z=0, m=1, geodetic=0 */
+ flags = lwflags(0, 1, 0); /* z=0, m=1, geodetic=0 */
CU_ASSERT_EQUAL(0, FLAGS_GET_GEODETIC(flags));
CU_ASSERT_EQUAL(0, FLAGS_GET_Z(flags));
@@ -236,7 +236,7 @@
static void test_gbox_serialized_size(void)
- uint8_t flags = gflags(0, 0, 0);
+ uint8_t flags = lwflags(0, 0, 0);
CU_ASSERT_EQUAL(gbox_serialized_size(flags),16);
FLAGS_SET_BBOX(flags, 1);
Modified: trunk/liblwgeom/gbox.c
--- trunk/liblwgeom/gbox.c 2019-06-12 15:27:01 UTC (rev 17516)
+++ trunk/liblwgeom/gbox.c 2019-06-12 22:04:58 UTC (rev 17517)
@@ -365,7 +365,7 @@
const char *ptr = str;
char *nextptr;
char *gbox_start = strstr(str, "GBOX((");
- GBOX *gbox = gbox_new(gflags(0,0,1));
+ GBOX *gbox = gbox_new(lwflags(0,0,1));
if ( ! gbox_start ) return NULL; /* No header found */
ptr += 6;
gbox->xmin = strtod(ptr, &nextptr);
@@ -544,7 +544,7 @@
has_z = FLAGS_GET_Z(pa->flags);
has_m = FLAGS_GET_M(pa->flags);
- gbox->flags = gflags(has_z, has_m, 0);
+ gbox->flags = lwflags(has_z, has_m, 0);
LWDEBUGF(4, "ptarray_calculate_gbox Z: %d M: %d", has_z, has_m);
getPoint4d_p(pa, 0, &p);
@@ -586,7 +586,7 @@
if (curve->points->npoints < 3) return LW_FAILURE;
tmp.flags =
- gflags(FLAGS_GET_Z(curve->flags), FLAGS_GET_M(curve->flags), 0);
+ lwflags(FLAGS_GET_Z(curve->flags), FLAGS_GET_M(curve->flags), 0);
/* Initialize */
gbox->xmin = gbox->ymin = gbox->zmin = gbox->mmin = FLT_MAX;
Modified: trunk/liblwgeom/gserialized.h
--- trunk/liblwgeom/gserialized.h 2019-06-12 15:27:01 UTC (rev 17516)
+++ trunk/liblwgeom/gserialized.h 2019-06-12 22:04:58 UTC (rev 17517)
@@ -0,0 +1,162 @@
+ * PostGIS - Spatial Types for PostgreSQL
+ * http://postgis.net
+ * PostGIS is free software: you can redistribute it and/or modify
+ * it under the terms of the GNU General Public License as published by
+ * the Free Software Foundation, either version 2 of the License, or
+ * (at your option) any later version.
+ * PostGIS is distributed in the hope that it will be useful,
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+ * GNU General Public License for more details.
+ * You should have received a copy of the GNU General Public License
+ * along with PostGIS. If not, see <http://www.gnu.org/licenses/>.
+ * Copyright 2019 Paul Ramsey <pramsey at cleverelephant.ca>
+* GSERIALIZED PUBLIC API
+* Copy a new bounding box into an existing gserialized.
+* If necessary a new #GSERIALIZED will be allocated. Test
+* that input != output before freeing input.
+GSERIALIZED *gserialized_set_gbox(GSERIALIZED *g, GBOX *gbox);
+* Remove the bounding box from a #GSERIALIZED. Returns a freshly
+* allocated #GSERIALIZED every time.
+GSERIALIZED* gserialized_drop_gbox(GSERIALIZED *g)
+* Read the box from the #GSERIALIZED or calculate it if necessary.
+* Return #LWFAILURE if box cannot be calculated (NULL or EMPTY
+* input).
+int gserialized_get_gbox_p(const GSERIALIZED *g, GBOX *gbox);
+* Read the box from the #GSERIALIZED or return #LWFAILURE if
+* box is unavailable.
+int gserialized_fast_gbox_p(const GSERIALIZED *g, GBOX *gbox);
+* Extract the geometry type from the serialized form (it hides in
+* the anonymous data area, so this is a handy function).
+extern uint32_t gserialized_get_type(const GSERIALIZED *g);
+* Returns the size in bytes to read from toast to get the basic
+* information from a geometry: GSERIALIZED struct, bbox and type
+extern uint32_t gserialized_max_header_size(void);
+* Returns a hash code for the srid/type/geometry information
+* in the GSERIALIZED. Ignores metadata like flags and optional
+* boxes, etc.
+extern uint64_t gserialized_hash(const GSERIALIZED *g);
+* Extract the SRID from the serialized form (it is packed into
+* three bytes so this is a handy function).
+extern int32_t gserialized_get_srid(const GSERIALIZED *g);
+* Write the SRID into the serialized form (it is packed into
+extern void gserialized_set_srid(GSERIALIZED *g, int32_t srid);
+* Check if a #GSERIALIZED is empty without deserializing first.
+* Only checks if the number of elements of the parent geometry
+* is zero, will not catch collections of empty, eg:
+* GEOMETRYCOLLECTION(POINT EMPTY)
+extern int gserialized_is_empty(const GSERIALIZED *g);
+* Check if a #GSERIALIZED has a bounding box without deserializing first.
+extern int gserialized_has_bbox(const GSERIALIZED *gser);
+* Check if a #GSERIALIZED has a Z ordinate.
+extern int gserialized_has_z(const GSERIALIZED *gser);
+* Check if a #GSERIALIZED has an M ordinate.
+extern int gserialized_has_m(const GSERIALIZED *gser);
+* Check if a #GSERIALIZED is a geography.
+extern int gserialized_is_geodetic(const GSERIALIZED *gser);
+* Return the number of dimensions (2, 3, 4) in a geometry
+extern int gserialized_ndims(const GSERIALIZED *gser);
+* Return -1 if g1 is "less than" g2, 1 if g1 is "greater than"
+* g2 and 0 if g1 and g2 are the "same". Equality is evaluated
+* with a memcmp and size check. So it is possible that two
+* identical objects where one lacks a bounding box could be
+* evaluated as non-equal initially. Greater and less than
+* are evaluated by calculating a sortable key from the center
+* point of the object bounds.
+extern int gserialized_cmp(const GSERIALIZED *g1, const GSERIALIZED *g2);
+* Allocate a new #GSERIALIZED from an #LWGEOM. For all non-point types, a bounding
+* box will be calculated and embedded in the serialization. The geodetic flag is used
+* to control the box calculation (cartesian or geocentric). If set, the size pointer
+* will contain the size of the final output, which is useful for setting the PgSQL
+* VARSIZE information.
+extern GSERIALIZED* gserialized_from_lwgeom(LWGEOM *geom, size_t *size);
+* Return the memory size a GSERIALIZED will occupy for a given LWGEOM.
+extern size_t gserialized_from_lwgeom_size(const LWGEOM *geom);
+* Allocate a new #LWGEOM from a #GSERIALIZED. The resulting #LWGEOM will have coordinates
+* that are double aligned and suitable for direct reading using getPoint2d_p_ro
+extern LWGEOM* lwgeom_from_gserialized(const GSERIALIZED *g);
+* Pull a #GBOX from the header of a #GSERIALIZED, if one is available. If
+* it is not, calculate it from the geometry. If that doesn't work (null
+* or empty) return LW_FAILURE.
+extern int gserialized_get_gbox_p(const GSERIALIZED *g, GBOX *box);
+* it is not, return LW_FAILURE.
+extern int gserialized_fast_gbox_p(const GSERIALIZED *g, GBOX *box);
Modified: trunk/liblwgeom/gserialized1.c
--- trunk/liblwgeom/gserialized1.c 2019-06-12 15:27:01 UTC (rev 17516)
+++ trunk/liblwgeom/gserialized1.c 2019-06-12 22:04:58 UTC (rev 17517)
@@ -1612,3 +1612,121 @@
return lwgeom;
+const float * gserialized_get_float_box_p(const GSERIALIZED *g, size_t *ndims)
+ if (ndims)
+ *ndims = FLAGS_NDIMS_BOX(g->flags);
+ if (!g) return NULL;
+ if (!gserialized_has_bbox(g)) return NULL;
+ return (const float *)(g->data);
+* Update the bounding box of a #GSERIALIZED, allocating a fresh one
+* if there is not enough space to just write the new box in.
+* <em>WARNING</em> if a new object needs to be created, the
+* input pointer will have to be freed by the caller! Check
+* to see if input == output. Returns null if there's a problem
+* like mismatched dimensions.
+GSERIALIZED* gserialized_set_gbox(GSERIALIZED *g, GBOX *gbox)
+ int g_ndims = FLAGS_NDIMS_BOX(g->flags);
+ int box_ndims = FLAGS_NDIMS_BOX(gbox->flags);
+ GSERIALIZED *g_out = NULL;
+ size_t box_size = 2 * g_ndims * sizeof(float);
+ float *fbox;
+ int fbox_pos = 0;
+ /* The dimensionality of the inputs has to match or we are SOL. */
+ if ( g_ndims != box_ndims )
+ return NULL;
+ /* Serialized already has room for a box. */
+ if (FLAGS_GET_BBOX(g->flags))
+ g_out = g;
+ /* Serialized has no box. We need to allocate enough space for the old
+ data plus the box, and leave a gap in the memory segment to write
+ the new values into.
+ else
+ size_t varsize_new = SIZE_GET(g->size) + box_size;
+ uint8_t *ptr;
+ g_out = lwalloc(varsize_new);
+ /* Copy the head of g into place */
+ memcpy(g_out, g, 8);
+ /* Copy the body of g into place after leaving space for the box */
+ ptr = g_out->data;
+ ptr += box_size;
+ memcpy(ptr, g->data, SIZE_GET(g->size) - 8);
+ FLAGS_SET_BBOX(g_out->flags, 1);
+ g->size = SIZE_SET(g->size, varsize_new);
+ /* Move bounds to nearest float values */
+ gbox_float_round(gbox);
+ /* Now write the float box values into the memory segement */
+ fbox = (float*)(g_out->data);
+ /* Copy in X/Y */
+ fbox[fbox_pos++] = gbox->xmin;
+ fbox[fbox_pos++] = gbox->xmax;
+ fbox[fbox_pos++] = gbox->ymin;
+ fbox[fbox_pos++] = gbox->ymax;
+ /* Optionally copy in higher dims */
+ if (g_ndims > 2)
+ fbox[fbox_pos++] = gbox->zmin;
+ fbox[fbox_pos++] = gbox->zmax;
+ if (g_ndims > 3)
+ fbox[fbox_pos++] = gbox->mmin;
+ fbox[fbox_pos++] = gbox->mmax;
+ return g_out;
+ size_t g_out_size = SIZE_GET(g->size) - box_size;
+ GSERIALIZED *g_out = lwalloc(g_out_size);
+ /* Copy the contents while omitting the box */
+ if ( FLAGS_GET_BBOX(g->flags) )
+ uint8_t *outptr = (uint8_t*)g_out;
+ uint8_t *inptr = (uint8_t*)g;
+ /* Copy the header (size+type) of g into place */
+ memcpy(outptr, inptr, 8);
+ outptr += 8;
+ inptr += 8 + box_size;
+ /* Copy parts after the box into place */
+ memcpy(outptr, inptr, g_out_size - 8);
+ FLAGS_SET_BBOX(g_out->flags, 0);
+ g_out->size = SIZE_SET(g_out->size, g_out_size);
+ /* No box? Nothing to do but copy and return. */
+ else
+ memcpy(g_out, g, g_out_size);
+ return g_out;
Modified: trunk/liblwgeom/gutil.c
--- trunk/liblwgeom/gutil.c 2019-06-12 15:27:01 UTC (rev 17516)
+++ trunk/liblwgeom/gutil.c 2019-06-12 22:04:58 UTC (rev 17517)
@@ -22,210 +22,3 @@
-#include <ctype.h>
-#include "liblwgeom_internal.h"
-/* Structure for the type array */
-struct geomtype_struct
- char *typename;
- int type;
- int z;
- int m;
-/* Type array. Note that the order of this array is important in
- that any typename in the list must *NOT* occur within an entry
- before it. Otherwise if we search for "POINT" at the top of the
- list we would also match MULTIPOINT, for example. */
-struct geomtype_struct geomtype_struct_array[] =
- { "GEOMETRYCOLLECTIONZM", COLLECTIONTYPE, 1, 1 },
- { "GEOMETRYCOLLECTIONZ", COLLECTIONTYPE, 1, 0 },
- { "GEOMETRYCOLLECTIONM", COLLECTIONTYPE, 0, 1 },
- { "GEOMETRYCOLLECTION", COLLECTIONTYPE, 0, 0 },
- { "GEOMETRYZM", 0, 1, 1 },
- { "GEOMETRYZ", 0, 1, 0 },
- { "GEOMETRYM", 0, 0, 1 },
- { "GEOMETRY", 0, 0, 0 },
- { "POLYHEDRALSURFACEZM", POLYHEDRALSURFACETYPE, 1, 1 },
- { "POLYHEDRALSURFACEZ", POLYHEDRALSURFACETYPE, 1, 0 },
- { "POLYHEDRALSURFACEM", POLYHEDRALSURFACETYPE, 0, 1 },
- { "POLYHEDRALSURFACE", POLYHEDRALSURFACETYPE, 0, 0 },
- { "TINZM", TINTYPE, 1, 1 },
- { "TINZ", TINTYPE, 1, 0 },
- { "TINM", TINTYPE, 0, 1 },
- { "TIN", TINTYPE, 0, 0 },
- { "CIRCULARSTRINGZM", CIRCSTRINGTYPE, 1, 1 },
- { "CIRCULARSTRINGZ", CIRCSTRINGTYPE, 1, 0 },
- { "CIRCULARSTRINGM", CIRCSTRINGTYPE, 0, 1 },
- { "CIRCULARSTRING", CIRCSTRINGTYPE, 0, 0 },
- { "COMPOUNDCURVEZM", COMPOUNDTYPE, 1, 1 },
- { "COMPOUNDCURVEZ", COMPOUNDTYPE, 1, 0 },
- { "COMPOUNDCURVEM", COMPOUNDTYPE, 0, 1 },
- { "COMPOUNDCURVE", COMPOUNDTYPE, 0, 0 },
- { "CURVEPOLYGONZM", CURVEPOLYTYPE, 1, 1 },
- { "CURVEPOLYGONZ", CURVEPOLYTYPE, 1, 0 },
- { "CURVEPOLYGONM", CURVEPOLYTYPE, 0, 1 },
- { "CURVEPOLYGON", CURVEPOLYTYPE, 0, 0 },
- { "MULTICURVEZM", MULTICURVETYPE, 1, 1 },
- { "MULTICURVEZ", MULTICURVETYPE, 1, 0 },
- { "MULTICURVEM", MULTICURVETYPE, 0, 1 },
- { "MULTICURVE", MULTICURVETYPE, 0, 0 },
- { "MULTISURFACEZM", MULTISURFACETYPE, 1, 1 },
- { "MULTISURFACEZ", MULTISURFACETYPE, 1, 0 },
- { "MULTISURFACEM", MULTISURFACETYPE, 0, 1 },
- { "MULTISURFACE", MULTISURFACETYPE, 0, 0 },
- { "MULTILINESTRINGZM", MULTILINETYPE, 1, 1 },
- { "MULTILINESTRINGZ", MULTILINETYPE, 1, 0 },
- { "MULTILINESTRINGM", MULTILINETYPE, 0, 1 },
- { "MULTILINESTRING", MULTILINETYPE, 0, 0 },
- { "MULTIPOLYGONZM", MULTIPOLYGONTYPE, 1, 1 },
- { "MULTIPOLYGONZ", MULTIPOLYGONTYPE, 1, 0 },
- { "MULTIPOLYGONM", MULTIPOLYGONTYPE, 0, 1 },
- { "MULTIPOLYGON", MULTIPOLYGONTYPE, 0, 0 },
- { "MULTIPOINTZM", MULTIPOINTTYPE, 1, 1 },
- { "MULTIPOINTZ", MULTIPOINTTYPE, 1, 0 },
- { "MULTIPOINTM", MULTIPOINTTYPE, 0, 1 },
- { "MULTIPOINT", MULTIPOINTTYPE, 0, 0 },
- { "LINESTRINGZM", LINETYPE, 1, 1 },
- { "LINESTRINGZ", LINETYPE, 1, 0 },
- { "LINESTRINGM", LINETYPE, 0, 1 },
- { "LINESTRING", LINETYPE, 0, 0 },
- { "TRIANGLEZM", TRIANGLETYPE, 1, 1 },
- { "TRIANGLEZ", TRIANGLETYPE, 1, 0 },
- { "TRIANGLEM", TRIANGLETYPE, 0, 1 },
- { "TRIANGLE", TRIANGLETYPE, 0, 0 },
- { "POLYGONZM", POLYGONTYPE, 1, 1 },
- { "POLYGONZ", POLYGONTYPE, 1, 0 },
- { "POLYGONM", POLYGONTYPE, 0, 1 },
- { "POLYGON", POLYGONTYPE, 0, 0 },
- { "POINTZM", POINTTYPE, 1, 1 },
- { "POINTZ", POINTTYPE, 1, 0 },
- { "POINTM", POINTTYPE, 0, 1 },
- { "POINT", POINTTYPE, 0, 0 }
-#define GEOMTYPE_STRUCT_ARRAY_LEN (sizeof geomtype_struct_array/sizeof(struct geomtype_struct))
-* We use a very simple upper case mapper here, because the system toupper() function
-* is locale dependent and may have trouble mapping lower case strings to the upper
-* case ones we expect (see, the "Turkisk I", http://www.i18nguy.com/unicode/turkish-i18n.html)
-* We could also count on PgSQL sending us *lower* case inputs, as it seems to do that
-* regardless of the case the user provides for the type arguments.
-const char dumb_upper_map[128] = "................................................0123456789.......ABCDEFGHIJKLMNOPQRSTUVWXYZ......ABCDEFGHIJKLMNOPQRSTUVWXYZ.....";
-static char dump_toupper(int in)
- if ( in < 0 || in > 127 )
- return '.';
- return dumb_upper_map[in];
-uint8_t gflags(int hasz, int hasm, int geodetic)
- uint8_t flags = 0;
- if ( hasz )
- FLAGS_SET_Z(flags, 1);
- if ( hasm )
- FLAGS_SET_M(flags, 1);
- if ( geodetic )
- FLAGS_SET_GEODETIC(flags, 1);
- return flags;
-* Calculate type integer and dimensional flags from string input.
-* Case insensitive, and insensitive to spaces at front and back.
-* Type == 0 in the case of the string "GEOMETRY" or "GEOGRAPHY".
-* Return LW_SUCCESS for success.
-int geometry_type_from_string(const char *str, uint8_t *type, int *z, int *m)
- char *tmpstr;
- size_t tmpstartpos, tmpendpos;
- size_t i;
- assert(str);
- assert(type);
- assert(z);
- assert(m);
- /* Initialize. */
- *type = 0;
- *z = 0;
- *m = 0;
- /* Locate any leading/trailing spaces */
- tmpstartpos = 0;
- for (i = 0; i < strlen(str); i++)
- if (str[i] != ' ')
- tmpstartpos = i;
- break;
- tmpendpos = strlen(str) - 1;
- for (i = strlen(str) - 1; i != 0; i--)
- tmpendpos = i;
- break;
- /* Copy and convert to upper case for comparison */
- tmpstr = lwalloc(tmpendpos - tmpstartpos + 2);
- for (i = tmpstartpos; i <= tmpendpos; i++)
- tmpstr[i - tmpstartpos] = dump_toupper(str[i]);
- /* Add NULL to terminate */
- tmpstr[i - tmpstartpos] = '\0';
- /* Now check for the type */
- for (i = 0; i < GEOMTYPE_STRUCT_ARRAY_LEN; i++)
- if (!strcmp(tmpstr, geomtype_struct_array[i].typename))
- *type = geomtype_struct_array[i].type;
- *z = geomtype_struct_array[i].z;
- *m = geomtype_struct_array[i].m;
- lwfree(tmpstr);
- return LW_SUCCESS;
- lwfree(tmpstr);
- return LW_FAILURE;
Modified: trunk/liblwgeom/liblwgeom.h.in
--- trunk/liblwgeom/liblwgeom.h.in 2019-06-12 15:27:01 UTC (rev 17516)
+++ trunk/liblwgeom/liblwgeom.h.in 2019-06-12 22:04:58 UTC (rev 17517)
@@ -669,15 +669,22 @@
extern LWCOLLECTION* lwcollection_concat_in_place(LWCOLLECTION* col1, const LWCOLLECTION* col2);
+* Construct a new flags char.
+extern uint8_t lwflags(int hasz, int hasm, int geodetic);
-** Utility functions for flag byte and srid_flag integer.
+** GSERIALIZED API
-* Construct a new flags char.
+* Access to the float bounding box, if there is one.
+* NULL if there is not.
-extern uint8_t gflags(int hasz, int hasm, int geodetic);
+extern const float * gserialized_get_float_box_p(const GSERIALIZED *g, size_t *ndims);
@@ -755,6 +762,50 @@
+extern GSERIALIZED *gserialized_set_gbox(GSERIALIZED *g, GBOX *gbox);
+extern GSERIALIZED* gserialized_drop_gbox(GSERIALIZED *g);
* Call this function to drop BBOX and SRID
* from LWGEOM. If LWGEOM type is *not* flagged
* with the HASBBOX flag and has a bbox, it
@@ -1962,35 +2013,6 @@
extern int geometry_type_from_string(const char *str, uint8_t *type, int *z, int *m);
-* Allocate a new #GSERIALIZED from an #LWGEOM. For all non-point types, a bounding
-* box will be calculated and embedded in the serialization. The geodetic flag is used
-* to control the box calculation (cartesian or geocentric). If set, the size pointer
-* will contain the size of the final output, which is useful for setting the PgSQL
-* VARSIZE information.
-extern GSERIALIZED* gserialized_from_lwgeom(LWGEOM *geom, size_t *size);
-* Allocate a new #LWGEOM from a #GSERIALIZED. The resulting #LWGEOM will have coordinates
-* that are double aligned and suitable for direct reading using getPoint2d_p_ro
-extern LWGEOM* lwgeom_from_gserialized(const GSERIALIZED *g);
-* Pull a #GBOX from the header of a #GSERIALIZED, if one is available. If
-* it is not, calculate it from the geometry. If that doesn't work (null
-* or empty) return LW_FAILURE.
-extern int gserialized_get_gbox_p(const GSERIALIZED *g, GBOX *box);
-* it is not, return LW_FAILURE.
-extern int gserialized_fast_gbox_p(const GSERIALIZED *g, GBOX *box);
* Parser check flags
* @see lwgeom_from_wkb
Modified: trunk/liblwgeom/lwcircstring.c
--- trunk/liblwgeom/lwcircstring.c 2019-06-12 15:27:01 UTC (rev 17516)
+++ trunk/liblwgeom/lwcircstring.c 2019-06-12 22:04:58 UTC (rev 17517)
@@ -80,7 +80,7 @@
LWCIRCSTRING *result = lwalloc(sizeof(LWCIRCSTRING));
result->type = CIRCSTRINGTYPE;
- result->flags = gflags(hasz,hasm,0);
+ result->flags = lwflags(hasz,hasm,0);
result->srid = srid;
result->points = ptarray_construct_empty(hasz, hasm, 1);
result->bbox = NULL;
Modified: trunk/liblwgeom/lwcollection.c
--- trunk/liblwgeom/lwcollection.c 2019-06-12 15:27:01 UTC (rev 17516)
+++ trunk/liblwgeom/lwcollection.c 2019-06-12 22:04:58 UTC (rev 17517)
@@ -77,7 +77,7 @@
ret = lwalloc(sizeof(LWCOLLECTION));
ret->type = type;
- ret->flags = gflags(hasz,hasm,0);
+ ret->flags = lwflags(hasz,hasm,0);
FLAGS_SET_BBOX(ret->flags, bbox?1:0);
ret->srid = srid;
ret->ngeoms = ngeoms;
@@ -97,7 +97,7 @@
ret->type = type;
ret->srid = srid;
ret->ngeoms = 0;
ret->maxgeoms = 1; /* Allocate room for sub-members, just in case. */
Modified: trunk/liblwgeom/lwcurvepoly.c
--- trunk/liblwgeom/lwcurvepoly.c 2019-06-12 15:27:01 UTC (rev 17516)
+++ trunk/liblwgeom/lwcurvepoly.c 2019-06-12 22:04:58 UTC (rev 17517)
@@ -38,7 +38,7 @@
ret = lwalloc(sizeof(LWCURVEPOLY));
ret->type = CURVEPOLYTYPE;
- ret->flags = gflags(hasz, hasm, 0);
+ ret->flags = lwflags(hasz, hasm, 0);
ret->srid = srid;
ret->nrings = 0;
ret->maxrings = 1; /* Allocate room for sub-members, just in case. */
Modified: trunk/liblwgeom/lwgeodetic.c
--- trunk/liblwgeom/lwgeodetic.c 2019-06-12 15:27:01 UTC (rev 17516)
+++ trunk/liblwgeom/lwgeodetic.c 2019-06-12 22:04:58 UTC (rev 17517)
@@ -2952,7 +2952,7 @@
LWDEBUGF(4, "got type %d", geom->type);
/* Add a geodetic flag to the incoming gbox */
- gbox->flags = gflags(FLAGS_GET_Z(geom->flags),FLAGS_GET_M(geom->flags),1);
+ gbox->flags = lwflags(FLAGS_GET_Z(geom->flags),FLAGS_GET_M(geom->flags),1);
switch (geom->type)
Modified: trunk/liblwgeom/lwin_twkb.c
--- trunk/liblwgeom/lwin_twkb.c 2019-06-12 15:27:01 UTC (rev 17516)
+++ trunk/liblwgeom/lwin_twkb.c 2019-06-12 22:04:58 UTC (rev 17517)
@@ -583,7 +583,7 @@
/* Initialize */
has_bbox = s->has_bbox;
memset(&bbox, 0, sizeof(GBOX));
- bbox.flags = gflags(s->has_z, s->has_m, 0);
+ bbox.flags = lwflags(s->has_z, s->has_m, 0);
/* X */
bbox.xmin = twkb_parse_state_double(s, s->factor);
Modified: trunk/liblwgeom/lwline.c
--- trunk/liblwgeom/lwline.c 2019-06-12 15:27:01 UTC (rev 17516)
+++ trunk/liblwgeom/lwline.c 2019-06-12 22:04:58 UTC (rev 17517)
@@ -65,7 +65,7 @@
LWLINE *result = lwalloc(sizeof(LWLINE));
result->type = LINETYPE;
Modified: trunk/liblwgeom/lwpoint.c
--- trunk/liblwgeom/lwpoint.c 2019-06-12 15:27:01 UTC (rev 17516)
+++ trunk/liblwgeom/lwpoint.c 2019-06-12 22:04:58 UTC (rev 17517)
@@ -152,7 +152,7 @@
LWPOINT *result = lwalloc(sizeof(LWPOINT));
result->type = POINTTYPE;
- result->flags = gflags(hasz, hasm, 0);
+ result->flags = lwflags(hasz, hasm, 0);
result->point = ptarray_construct(hasz, hasm, 0);
Modified: trunk/liblwgeom/lwpoly.c
--- trunk/liblwgeom/lwpoly.c 2019-06-12 15:27:01 UTC (rev 17516)
+++ trunk/liblwgeom/lwpoly.c 2019-06-12 22:04:58 UTC (rev 17517)
@@ -65,7 +65,7 @@
result = (LWPOLY*) lwalloc(sizeof(LWPOLY));
result->type = POLYGONTYPE;
FLAGS_SET_BBOX(result->flags, bbox?1:0);
result->nrings = nrings;
@@ -162,7 +162,7 @@
LWPOLY *result = lwalloc(sizeof(LWPOLY));
result->nrings = 0;
result->maxrings = 1; /* Allocate room for ring, just in case. */
Modified: trunk/liblwgeom/lwspheroid.c
--- trunk/liblwgeom/lwspheroid.c 2019-06-12 15:27:01 UTC (rev 17516)
+++ trunk/liblwgeom/lwspheroid.c 2019-06-12 22:04:58 UTC (rev 17517)
@@ -502,7 +502,7 @@
double delta_lon_tolerance;
double latitude_min;
- gbox2d.flags = gflags(0, 0, 0);
+ gbox2d.flags = lwflags(0, 0, 0);
/* Return zero on non-sensical inputs */
if ( ! pa || pa->npoints < 4 )
Modified: trunk/liblwgeom/lwtriangle.c
--- trunk/liblwgeom/lwtriangle.c 2019-06-12 15:27:01 UTC (rev 17516)
+++ trunk/liblwgeom/lwtriangle.c 2019-06-12 22:04:58 UTC (rev 17517)
@@ -59,7 +59,7 @@
LWTRIANGLE *result = lwalloc(sizeof(LWTRIANGLE));
result->type = TRIANGLETYPE;
Modified: trunk/liblwgeom/lwutil.c
--- trunk/liblwgeom/lwutil.c 2019-06-12 15:27:01 UTC (rev 17516)
+++ trunk/liblwgeom/lwutil.c 2019-06-12 22:04:58 UTC (rev 17517)
@@ -370,3 +370,210 @@
return newsrid;
+/* Structure for the type array */
+struct geomtype_struct
+ char *typename;
+ int type;
+ int z;
+ int m;
+/* Type array. Note that the order of this array is important in
+ that any typename in the list must *NOT* occur within an entry
+ before it. Otherwise if we search for "POINT" at the top of the
+ list we would also match MULTIPOINT, for example. */
+struct geomtype_struct geomtype_struct_array[] =
+ { "GEOMETRYCOLLECTIONZM", COLLECTIONTYPE, 1, 1 },
+ { "GEOMETRYCOLLECTIONZ", COLLECTIONTYPE, 1, 0 },
+ { "GEOMETRYCOLLECTIONM", COLLECTIONTYPE, 0, 1 },
+ { "GEOMETRYCOLLECTION", COLLECTIONTYPE, 0, 0 },
+ { "GEOMETRYZM", 0, 1, 1 },
+ { "GEOMETRYZ", 0, 1, 0 },
+ { "GEOMETRYM", 0, 0, 1 },
+ { "GEOMETRY", 0, 0, 0 },
+ { "POLYHEDRALSURFACEZM", POLYHEDRALSURFACETYPE, 1, 1 },
+ { "POLYHEDRALSURFACEZ", POLYHEDRALSURFACETYPE, 1, 0 },
+ { "POLYHEDRALSURFACEM", POLYHEDRALSURFACETYPE, 0, 1 },
+ { "POLYHEDRALSURFACE", POLYHEDRALSURFACETYPE, 0, 0 },
+ { "TINZM", TINTYPE, 1, 1 },
+ { "TINZ", TINTYPE, 1, 0 },
+ { "TINM", TINTYPE, 0, 1 },
+ { "TIN", TINTYPE, 0, 0 },
+ { "CIRCULARSTRINGZM", CIRCSTRINGTYPE, 1, 1 },
+ { "CIRCULARSTRINGZ", CIRCSTRINGTYPE, 1, 0 },
+ { "CIRCULARSTRINGM", CIRCSTRINGTYPE, 0, 1 },
+ { "CIRCULARSTRING", CIRCSTRINGTYPE, 0, 0 },
+ { "COMPOUNDCURVEZM", COMPOUNDTYPE, 1, 1 },
+ { "COMPOUNDCURVEZ", COMPOUNDTYPE, 1, 0 },
+ { "COMPOUNDCURVEM", COMPOUNDTYPE, 0, 1 },
+ { "COMPOUNDCURVE", COMPOUNDTYPE, 0, 0 },
+ { "CURVEPOLYGONZM", CURVEPOLYTYPE, 1, 1 },
+ { "CURVEPOLYGONZ", CURVEPOLYTYPE, 1, 0 },
+ { "CURVEPOLYGONM", CURVEPOLYTYPE, 0, 1 },
+ { "CURVEPOLYGON", CURVEPOLYTYPE, 0, 0 },
+ { "MULTICURVEZM", MULTICURVETYPE, 1, 1 },
+ { "MULTICURVEZ", MULTICURVETYPE, 1, 0 },
+ { "MULTICURVEM", MULTICURVETYPE, 0, 1 },
+ { "MULTICURVE", MULTICURVETYPE, 0, 0 },
+ { "MULTISURFACEZM", MULTISURFACETYPE, 1, 1 },
+ { "MULTISURFACEZ", MULTISURFACETYPE, 1, 0 },
+ { "MULTISURFACEM", MULTISURFACETYPE, 0, 1 },
+ { "MULTISURFACE", MULTISURFACETYPE, 0, 0 },
+ { "MULTILINESTRINGZM", MULTILINETYPE, 1, 1 },
+ { "MULTILINESTRINGZ", MULTILINETYPE, 1, 0 },
+ { "MULTILINESTRINGM", MULTILINETYPE, 0, 1 },
+ { "MULTILINESTRING", MULTILINETYPE, 0, 0 },
+ { "MULTIPOLYGONZM", MULTIPOLYGONTYPE, 1, 1 },
+ { "MULTIPOLYGONZ", MULTIPOLYGONTYPE, 1, 0 },
+ { "MULTIPOLYGONM", MULTIPOLYGONTYPE, 0, 1 },
+ { "MULTIPOLYGON", MULTIPOLYGONTYPE, 0, 0 },
+ { "MULTIPOINTZM", MULTIPOINTTYPE, 1, 1 },
+ { "MULTIPOINTZ", MULTIPOINTTYPE, 1, 0 },
+ { "MULTIPOINTM", MULTIPOINTTYPE, 0, 1 },
+ { "MULTIPOINT", MULTIPOINTTYPE, 0, 0 },
+ { "LINESTRINGZM", LINETYPE, 1, 1 },
+ { "LINESTRINGZ", LINETYPE, 1, 0 },
+ { "LINESTRINGM", LINETYPE, 0, 1 },
+ { "LINESTRING", LINETYPE, 0, 0 },
+ { "TRIANGLEZM", TRIANGLETYPE, 1, 1 },
+ { "TRIANGLEZ", TRIANGLETYPE, 1, 0 },
+ { "TRIANGLEM", TRIANGLETYPE, 0, 1 },
+ { "TRIANGLE", TRIANGLETYPE, 0, 0 },
+ { "POLYGONZM", POLYGONTYPE, 1, 1 },
+ { "POLYGONZ", POLYGONTYPE, 1, 0 },
+ { "POLYGONM", POLYGONTYPE, 0, 1 },
+ { "POLYGON", POLYGONTYPE, 0, 0 },
+ { "POINTZM", POINTTYPE, 1, 1 },
+ { "POINTZ", POINTTYPE, 1, 0 },
+ { "POINTM", POINTTYPE, 0, 1 },
+ { "POINT", POINTTYPE, 0, 0 }
+#define GEOMTYPE_STRUCT_ARRAY_LEN (sizeof geomtype_struct_array/sizeof(struct geomtype_struct))
+* We use a very simple upper case mapper here, because the system toupper() function
+* is locale dependent and may have trouble mapping lower case strings to the upper
+* case ones we expect (see, the "Turkisk I", http://www.i18nguy.com/unicode/turkish-i18n.html)
+* We could also count on PgSQL sending us *lower* case inputs, as it seems to do that
+* regardless of the case the user provides for the type arguments.
+const char dumb_upper_map[128] = "................................................0123456789.......ABCDEFGHIJKLMNOPQRSTUVWXYZ......ABCDEFGHIJKLMNOPQRSTUVWXYZ.....";
+static char dumb_toupper(int in)
+ if ( in < 0 || in > 127 )
+ return '.';
+ return dumb_upper_map[in];
+uint8_t lwflags(int hasz, int hasm, int geodetic)
+ uint8_t flags = 0;
+ if ( hasz )
+ FLAGS_SET_Z(flags, 1);
+ if ( hasm )
+ FLAGS_SET_M(flags, 1);
+ if ( geodetic )
+ FLAGS_SET_GEODETIC(flags, 1);
+ return flags;
+* Calculate type integer and dimensional flags from string input.
+* Case insensitive, and insensitive to spaces at front and back.
+* Type == 0 in the case of the string "GEOMETRY" or "GEOGRAPHY".
+* Return LW_SUCCESS for success.
+int geometry_type_from_string(const char *str, uint8_t *type, int *z, int *m)
+ char *tmpstr;
+ size_t tmpstartpos, tmpendpos;
+ size_t i;
+ assert(str);
+ assert(type);
+ assert(z);
+ assert(m);
+ /* Initialize. */
+ *type = 0;
+ *z = 0;
+ *m = 0;
+ /* Locate any leading/trailing spaces */
+ tmpstartpos = 0;
+ for (i = 0; i < strlen(str); i++)
+ if (str[i] != ' ')
+ tmpstartpos = i;
+ break;
+ tmpendpos = strlen(str) - 1;
+ for (i = strlen(str) - 1; i != 0; i--)
+ tmpendpos = i;
+ break;
+ /* Copy and convert to upper case for comparison */
+ tmpstr = lwalloc(tmpendpos - tmpstartpos + 2);
+ for (i = tmpstartpos; i <= tmpendpos; i++)
+ tmpstr[i - tmpstartpos] = dumb_toupper(str[i]);
+ /* Add NULL to terminate */
+ tmpstr[i - tmpstartpos] = '\0';
+ /* Now check for the type */
+ for (i = 0; i < GEOMTYPE_STRUCT_ARRAY_LEN; i++)
+ if (!strcmp(tmpstr, geomtype_struct_array[i].typename))
+ *type = geomtype_struct_array[i].type;
+ *z = geomtype_struct_array[i].z;
+ *m = geomtype_struct_array[i].m;
+ lwfree(tmpstr);
+ return LW_SUCCESS;
+ lwfree(tmpstr);
+ return LW_FAILURE;
Modified: trunk/liblwgeom/ptarray.c
--- trunk/liblwgeom/ptarray.c 2019-06-12 15:27:01 UTC (rev 17516)
+++ trunk/liblwgeom/ptarray.c 2019-06-12 22:04:58 UTC (rev 17517)
@@ -62,7 +62,7 @@
pa->serialized_pointlist = NULL;
/* Set our dimensionality info on the bitmap */
- pa->flags = gflags(hasz, hasm, 0);
+ pa->flags = lwflags(hasz, hasm, 0);
/* We will be allocating a bit of room */
pa->npoints = 0;
@@ -283,7 +283,7 @@
POINTARRAY *pa = lwalloc(sizeof(POINTARRAY));
LWDEBUGF(5, "hasz = %d, hasm = %d, npoints = %d, ptlist = %p", hasz, hasm, npoints, ptlist);
FLAGS_SET_READONLY(pa->flags, 1); /* We don't own this memory, so we can't alter or free it. */
pa->npoints = npoints;
pa->maxpoints = npoints;
@@ -297,7 +297,7 @@
Modified: trunk/libpgcommon/gserialized_gist.c
--- trunk/libpgcommon/gserialized_gist.c 2019-06-12 15:27:01 UTC (rev 17516)
+++ trunk/libpgcommon/gserialized_gist.c 2019-06-12 22:04:58 UTC (rev 17517)
@@ -56,6 +56,16 @@
return rv;
+/* Allocates a new GIDX on the heap of the requested dimensionality */
+GIDX* gidx_new(int ndims)
+ size_t size = GIDX_SIZE(ndims);
+ GIDX *g = (GIDX*)palloc(size);
+ Assert( (ndims <= GIDX_MAX_DIM) && (size <= GIDX_MAX_SIZE) );
+ POSTGIS_DEBUGF(5,"created new gidx of %d dimensions, size %d", ndims, (int)size);
+ SET_VARSIZE(g, size);
+ return g;
static uint8_t
gserialized_datum_get_flags(Datum gsdatum)
@@ -158,92 +168,6 @@
-* Update the bounding box of a #GSERIALIZED, allocating a fresh one
-* if there is not enough space to just write the new box in.
-* <em>WARNING</em> if a new object needs to be created, the
-* input pointer will have to be freed by the caller! Check
-* to see if input == output. Returns null if there's a problem
-* like mismatched dimensions.
-GSERIALIZED* gserialized_set_gidx(GSERIALIZED *g, GIDX *gidx)
- int g_ndims = FLAGS_NDIMS_BOX(g->flags);
- int box_ndims = GIDX_NDIMS(gidx);
- GSERIALIZED *g_out = NULL;
- size_t box_size = 2 * g_ndims * sizeof(float);
- /* The dimensionality of the inputs has to match or we are SOL. */
- if ( g_ndims != box_ndims )
- return NULL;
- /* Serialized already has room for a box. */
- if ( FLAGS_GET_BBOX(g->flags) )
- g_out = g;
- /* Serialized has no box. We need to allocate enough space for the old
- data plus the box, and leave a gap in the memory segment to write
- the new values into.
- else
- size_t varsize_new = VARSIZE(g) + box_size;
- uint8_t *ptr;
- g_out = palloc(varsize_new);
- /* Copy the head of g into place */
- memcpy(g_out, g, 8);
- /* Copy the body of g into place after leaving space for the box */
- ptr = g_out->data;
- ptr += box_size;
- memcpy(ptr, g->data, VARSIZE(g) - 8);
- FLAGS_SET_BBOX(g_out->flags, 1);
- SET_VARSIZE(g_out, varsize_new);
- /* Now write the gidx values into the memory segement */
- memcpy(g_out->data, gidx->c, box_size);
- return g_out;
-* Remove the bounding box from a #GSERIALIZED. Returns a freshly
-* allocated #GSERIALIZED every time.
-GSERIALIZED* gserialized_drop_gidx(GSERIALIZED *g)
- size_t g_out_size = VARSIZE(g) - box_size;
- GSERIALIZED *g_out = palloc(g_out_size);
- /* Copy the contents while omitting the box */
- uint8_t *outptr = (uint8_t*)g_out;
- uint8_t *inptr = (uint8_t*)g;
- /* Copy the header (size+type) of g into place */
- memcpy(outptr, inptr, 8);
- outptr += 8;
- inptr += 8 + box_size;
- /* Copy parts after the box into place */
- memcpy(outptr, inptr, g_out_size - 8);
- FLAGS_SET_BBOX(g_out->flags, 0);
- SET_VARSIZE(g_out, g_out_size);
- /* No box? Nothing to do but copy and return. */
- else
- memcpy(g_out, g, g_out_size);
- return g_out;
* Peak into a #GSERIALIZED datum to find the bounding box. If the
* box is there, copy it out and return it. If not, calculate the box from the
* full object and return the box based on that. If no box is available,
@@ -263,17 +187,21 @@
gpart = (GSERIALIZED*)PG_DETOAST_DATUM_SLICE(gsdatum, 0, 40);
- POSTGIS_DEBUGF(4, "got flags %d", gpart->flags);
/* Do we even have a serialized bounding box? */
- if ( FLAGS_GET_BBOX(gpart->flags) )
+ if (gserialized_has_bbox(gpart))
/* Yes! Copy it out into the GIDX! */
size_t size = gbox_serialized_size(gpart->flags);
- POSTGIS_DEBUG(4, "copying box out of serialization");
- memcpy(gidx->c, gpart->data, size);
+ size_t ndims, dim;
+ const float *f = gserialized_get_float_box_p(gpart, &ndims);
+ if (!f) return LW_FAILURE;
+ for (dim = 0; dim < ndims; dim++)
+ GIDX_SET_MIN(gidx, dim, f[2*dim]);
+ GIDX_SET_MAX(gidx, dim, f[2*dim+1]);
/* if M is present but Z is not, pad Z and shift M */
- if ( FLAGS_GET_M(gpart->flags) && ! FLAGS_GET_Z(gpart->flags) )
+ if (gserialized_has_m(gpart) && ! gserialized_has_z(gpart))
size += 2 * sizeof(float);
GIDX_SET_MIN(gidx,3,GIDX_GET_MIN(gidx,2));
@@ -289,7 +217,7 @@
GSERIALIZED *g = (GSERIALIZED*)PG_DETOAST_DATUM(gsdatum);
LWGEOM *lwgeom = lwgeom_from_gserialized(g);
GBOX gbox;
- if ( lwgeom_calculate_gbox(lwgeom, &gbox) == LW_FAILURE )
+ if (lwgeom_calculate_gbox(lwgeom, &gbox) == LW_FAILURE)
POSTGIS_DEBUG(4, "could not calculate bbox, returning failure");
lwgeom_free(lwgeom);
@@ -301,81 +229,10 @@
POSTGIS_FREE_IF_COPY_P(g, gsdatum);
gidx_from_gbox_p(gbox, gidx);
POSTGIS_FREE_IF_COPY_P(gpart, gsdatum);
POSTGIS_DEBUGF(4, "got gidx %s", gidx_to_string(gidx));
return LW_SUCCESS;
-** Peak into a geography to find the bounding box. If the
-** box is there, copy it out and return it. If not, calculate the box from the
-** full geography and return the box based on that. If no box is available,
-** return LW_FAILURE, otherwise LW_SUCCESS.
-int gserialized_get_gidx_p(const GSERIALIZED *g, GIDX *gidx)
- POSTGIS_DEBUG(4, "entered function");
- POSTGIS_DEBUGF(4, "got flags %d", g->flags);
- int ndims = FLAGS_NDIMS_GIDX(g->flags);
- const size_t size = 2 * ndims * sizeof(float);
- memcpy(gidx->c, g->data, size);
- SET_VARSIZE(gidx, VARHDRSZ + size);
- else
- /* No, we need to calculate it from the full object. */
- LWGEOM *lwgeom = lwgeom_from_gserialized(g);
- GBOX gbox;
- POSTGIS_DEBUG(4, "could not calculate bbox, returning failure");
- lwgeom_free(lwgeom);
- gidx_from_gbox_p(gbox, gidx);
- POSTGIS_DEBUGF(4, "got gidx %s", gidx_to_string(gidx));
-** GIDX expansion, make d units bigger in all dimensions.
-void gidx_expand(GIDX *a, float d)
- uint32_t i;
- POSTGIS_DEBUG(5, "entered function");
- if ( a == NULL ) return;
- for (i = 0; i < GIDX_NDIMS(a); i++)
- GIDX_SET_MIN(a, i, GIDX_GET_MIN(a, i) - d);
- GIDX_SET_MAX(a, i, GIDX_GET_MAX(a, i) + d);
-/* Allocates a new GIDX on the heap of the requested dimensionality */
-GIDX* gidx_new(int ndims)
- size_t size = GIDX_SIZE(ndims);
- GIDX *g = (GIDX*)palloc(size);
- Assert( (ndims <= GIDX_MAX_DIM) && (size <= GIDX_MAX_SIZE) );
- POSTGIS_DEBUGF(5,"created new gidx of %d dimensions, size %d", ndims, (int)size);
- SET_VARSIZE(g, size);
- return g;
Modified: trunk/libpgcommon/gserialized_gist.h
--- trunk/libpgcommon/gserialized_gist.h 2019-06-12 15:27:01 UTC (rev 17516)
+++ trunk/libpgcommon/gserialized_gist.h 2019-06-12 22:04:58 UTC (rev 17517)
@@ -62,9 +62,6 @@
/* allocate a new gidx object on the heap */
GIDX *gidx_new(int ndims);
-/* Increase the size of a GIDX */
-void gidx_expand(GIDX *a, float d);
/* Note empty GIDX */
bool gidx_is_unknown(const GIDX *a);
@@ -118,16 +115,6 @@
/* Pull out the #GIDX bounding box with a absolute minimum system overhead */
int gserialized_datum_get_gidx_p(Datum gserialized_datum, GIDX *gidx);
-/* Pull out the gidx bounding box from an already de-toasted geography */
-int gserialized_get_gidx_p(const GSERIALIZED *g, GIDX *gidx);
-/* Copy a new bounding box into an existing gserialized */
-GSERIALIZED *gserialized_set_gidx(GSERIALIZED *g, GIDX *gidx);
-/* Given two datums, do they overlap? Computed very fast using embedded boxes. */
-/* int gserialized_datum_overlaps(Datum gs1, Datum gs2); */
-/* Remove the box from a disk serialization */
-GSERIALIZED *gserialized_drop_gidx(GSERIALIZED *g);
bool box2df_contains(const BOX2DF *a, const BOX2DF *b);
void box2df_set_empty(BOX2DF *a);
void box2df_set_finite(BOX2DF *a);
Modified: trunk/libpgcommon/lwgeom_pg.h
--- trunk/libpgcommon/lwgeom_pg.h 2019-06-12 15:27:01 UTC (rev 17516)
+++ trunk/libpgcommon/lwgeom_pg.h 2019-06-12 22:04:58 UTC (rev 17517)
@@ -43,27 +43,27 @@
/* Display a simple message at NOTICE level */
/* from PgSQL utils/elog.h, LOG is 15, and DEBUG5 is 10 and everything else is in between */
#define POSTGIS_DEBUG(level, msg) \
- do { \
- if (POSTGIS_DEBUG_LEVEL >= level) \
- ereport((level < 1 || level > 5) ? DEBUG5 : (LOG - level), (errmsg_internal("[%s:%s:%d] " msg, __FILE__, __func__, __LINE__))); \
- } while (0);
+ do { \
+ if (POSTGIS_DEBUG_LEVEL >= level) \
+ ereport((level < 1 || level > 5) ? DEBUG5 : (LOG - level), (errmsg_internal("[%s:%s:%d] " msg, __FILE__, __func__, __LINE__))); \
+ } while (0);
/* Display a formatted message at NOTICE level (like printf, with variadic arguments) */
#define POSTGIS_DEBUGF(level, msg, ...) \
- do { \
- ereport((level < 1 || level > 5) ? DEBUG5 : (LOG - level), (errmsg_internal("[%s:%s:%d] " msg, __FILE__, __func__, __LINE__, __VA_ARGS__))); \
- } while (0);
+ do { \
+ ereport((level < 1 || level > 5) ? DEBUG5 : (LOG - level), (errmsg_internal("[%s:%s:%d] " msg, __FILE__, __func__, __LINE__, __VA_ARGS__))); \
+ } while (0);
#else /* POSTGIS_DEBUG_LEVEL */
/* Empty prototype that can be optimised away by the compiler for non-debug builds */
- ((void) 0)
+ ((void) 0)
- ((void) 0)
+ ((void) 0)
#endif /* POSTGIS_DEBUG_LEVEL */
@@ -83,17 +83,17 @@
extern void pg_unparser_errhint(LWGEOM_UNPARSER_RESULT *lwg_unparser_result);
#define PG_PARSER_ERROR(lwg_parser_result) \
- do { \
- pg_parser_errhint(&lwg_parser_result); \
- } while(0);
+ do { \
+ pg_parser_errhint(&lwg_parser_result); \
+ } while(0);
* Standard macro for reporting unparser errors to PostgreSQL
#define PG_UNPARSER_ERROR(lwg_unparser_result) \
- do { \
- pg_unparser_errhint(&lwg_unparser_result); \
- } while(0);
+ do { \
+ pg_unparser_errhint(&lwg_unparser_result); \
+ } while(0);
/* TODO: only cancel the interrupt if inside an outer call ? */
#define LWGEOM_INIT() { \
@@ -100,17 +100,7 @@
lwgeom_cancel_interrupt(); \
-** GSERIALIED prototypes used outside the index functions
-* Remove the embedded bounding box
-GSERIALIZED* gserialized_drop_gidx(GSERIALIZED *g);
* Utility method to call the serialization and then set the
* PgSQL varsize header appropriately with the serialized size.
Modified: trunk/postgis/geography_centroid.c
--- trunk/postgis/geography_centroid.c 2019-06-12 15:27:01 UTC (rev 17516)
+++ trunk/postgis/geography_centroid.c 2019-06-12 22:04:58 UTC (rev 17517)
@@ -78,7 +78,7 @@
LWCOLLECTION* empty = lwcollection_construct_empty(COLLECTIONTYPE, srid, 0, 0);
lwgeom_out = lwcollection_as_lwgeom(empty);
lwgeom_set_geodetic(lwgeom_out, true);
- g_out = gserialized_from_lwgeom(lwgeom_out, 0);
+ g_out = geography_serialize(lwgeom_out);
PG_RETURN_POINTER(g_out);
@@ -167,8 +167,7 @@
PG_FREE_IF_COPY(g, 0);
lwgeom_out = lwpoint_as_lwgeom(lwpoint_out);
- lwgeom_set_geodetic(lwgeom_out, true);
Modified: trunk/postgis/geography_measurement.c
--- trunk/postgis/geography_measurement.c 2019-06-12 15:27:01 UTC (rev 17516)
+++ trunk/postgis/geography_measurement.c 2019-06-12 22:04:58 UTC (rev 17517)
@@ -687,7 +687,6 @@
GBOX gbox;
GSERIALIZED *g = NULL;
- size_t g_out_size;
LWGEOM *lwpoint = NULL;
POINT2D pt;
@@ -707,13 +706,9 @@
gbox_pt_outside(&gbox, &pt);
lwpoint = (LWGEOM*) lwpoint_make2d(4326, pt.x, pt.y);
- /* TODO: Investigate where this is used, this was probably not
- * returning a geography object before. How did this miss checking
- lwgeom_set_geodetic(lwpoint, true);
- g_out = gserialized_from_lwgeom(lwpoint, &g_out_size);
+ g_out = geography_serialize(lwpoint);
Modified: trunk/postgis/gserialized_gist_nd.c
--- trunk/postgis/gserialized_gist_nd.c 2019-06-12 15:27:01 UTC (rev 17516)
+++ trunk/postgis/gserialized_gist_nd.c 2019-06-12 22:04:58 UTC (rev 17517)
@@ -613,41 +613,6 @@
return sqrt(sum);
-static double
-gidx_distance_m(const GIDX *a, const GIDX *b)
- int mdim_a, mdim_b;
- double d, amin, amax, bmin, bmax;
- /* Base computation on least available dimensions */
- mdim_a = GIDX_NDIMS(a) - 1;
- mdim_b = GIDX_NDIMS(b) - 1;
- amin = GIDX_GET_MIN(a, mdim_a);
- amax = GIDX_GET_MAX(a, mdim_a);
- bmin = GIDX_GET_MIN(b, mdim_b);
- bmax = GIDX_GET_MAX(b, mdim_b);
- if ((amin <= bmax && amax >= bmin))
- /* overlaps */
- d = 0;
- else if (bmax < amin)
- /* is "left" */
- d = amin - bmax;
- else
- /* is "right" */
- assert(bmin > amax);
- d = bmin - amax;
- return d;
* Return a #GSERIALIZED with an expanded bounding box.
@@ -654,18 +619,18 @@
GSERIALIZED *
gserialized_expand(GSERIALIZED *g, double distance)
- char boxmem[GIDX_MAX_SIZE];
- GIDX *gidx = (GIDX *)boxmem;
+ GBOX gbox;
float fdistance = (float)distance;
+ gbox_init(&gbox);
/* Get our bounding box out of the geography, return right away if
input is an EMPTY geometry. */
- if (gserialized_get_gidx_p(g, gidx) == LW_FAILURE)
+ if (gserialized_get_gbox_p(g, &gbox) == LW_FAILURE)
return g;
- gidx_expand(gidx, fdistance);
+ gbox_expand(&gbox, fdistance);
- return gserialized_set_gidx(g, gidx);
+ return gserialized_set_gbox(g, &gbox);
@@ -678,11 +643,6 @@
PG_FUNCTION_INFO_V1(gserialized_distance_nd);
Datum gserialized_distance_nd(PG_FUNCTION_ARGS)
- char b1mem[GIDX_MAX_SIZE];
- GIDX *b1 = (GIDX *)b1mem;
- char b2mem[GIDX_MAX_SIZE];
- GIDX *b2 = (GIDX *)b2mem;
/* Feature-to-feature distance */
GSERIALIZED *geom1 = PG_GETARG_GSERIALIZED_P(0);
GSERIALIZED *geom2 = PG_GETARG_GSERIALIZED_P(1);
@@ -743,11 +703,21 @@
if (usebox)
- double d;
- gserialized_get_gidx_p(geom1, b1);
- gserialized_get_gidx_p(geom2, b2);
- d = gidx_distance_m(b1, b2);
- distance += d * d;
+ GBOX b1, b2;
+ if (gserialized_get_gbox_p(geom1, &b1) && gserialized_get_gbox_p(geom2, &b2))
+ double d;
+ /* Disjoint left */
+ if (b1.mmin > b2.mmax)
+ d = b1.mmin - b2.mmax;
+ /* Disjoint right */
+ else if (b2.mmin > b1.mmax)
+ d = b2.mmin - b1.mmax;
+ /* Not Disjoint */
+ else
+ d = 0;
+ distance += d * d;
else
distance += (m2 - m1) * (m2 - m1);
Modified: trunk/postgis/gserialized_typmod.c
--- trunk/postgis/gserialized_typmod.c 2019-06-12 15:27:01 UTC (rev 17516)
+++ trunk/postgis/gserialized_typmod.c 2019-06-12 22:04:58 UTC (rev 17517)
@@ -235,7 +235,7 @@
&elem_values, NULL, &n);
/* Set the SRID to the default value first */
- if ( is_geography)
+ if (is_geography)
TYPMOD_SET_SRID(typmod, SRID_DEFAULT);
else
TYPMOD_SET_SRID(typmod, SRID_UNKNOWN);
Modified: trunk/postgis/lwgeom_box.c
--- trunk/postgis/lwgeom_box.c 2019-06-12 15:27:01 UTC (rev 17516)
+++ trunk/postgis/lwgeom_box.c 2019-06-12 22:04:58 UTC (rev 17517)
@@ -554,7 +554,7 @@
error_if_srid_mismatch(minpoint->srid, maxpoint->srid);
- result = gbox_new(gflags(0, 0, 0));
+ result = gbox_new(lwflags(0, 0, 0));
/* Process X min/max */
min = lwpoint_get_x(minpoint);
Modified: trunk/postgis/lwgeom_dumppoints.c
--- trunk/postgis/lwgeom_dumppoints.c 2019-06-12 15:27:01 UTC (rev 17516)
+++ trunk/postgis/lwgeom_dumppoints.c 2019-06-12 22:04:58 UTC (rev 17517)
@@ -257,7 +257,7 @@
pathpt[0] = PointerGetDatum(construct_array(state->path, state->pathlen+1,
INT4OID, state->typlen, state->byval, state->align));
- pathpt[1] = PointerGetDatum(gserialized_from_lwgeom((LWGEOM*)lwpoint,0));
+ pathpt[1] = PointerGetDatum(geometry_serialize((LWGEOM*)lwpoint));
tuple = heap_form_tuple(funcctx->tuple_desc, pathpt, isnull);
result = HeapTupleGetDatum(tuple);
Modified: trunk/postgis/lwgeom_functions_analytic.c
--- trunk/postgis/lwgeom_functions_analytic.c 2019-06-12 15:27:01 UTC (rev 17516)
+++ trunk/postgis/lwgeom_functions_analytic.c 2019-06-12 22:04:58 UTC (rev 17517)
@@ -433,10 +433,8 @@
getPoint4d_p(in_lwpoint->point, 0, &offsetpoint);
grid.ipx = offsetpoint.x;
grid.ipy = offsetpoint.y;
- if (lwgeom_has_z((LWGEOM*)in_lwpoint)) grid.ipz = offsetpoint.z;
- else grid.ipz=0;
- if (lwgeom_has_m((LWGEOM*)in_lwpoint)) grid.ipm = offsetpoint.m;
- else grid.ipm=0;
+ grid.ipz = lwgeom_has_z((LWGEOM*)in_lwpoint) ? offsetpoint.z : 0;
+ grid.ipm = lwgeom_has_m((LWGEOM*)in_lwpoint) ? offsetpoint.m : 0;
#if POSTGIS_DEBUG_LEVEL >= 4
grid_print(&grid);
Modified: trunk/postgis/lwgeom_geos.c
--- trunk/postgis/lwgeom_geos.c 2019-06-12 15:27:01 UTC (rev 17516)
+++ trunk/postgis/lwgeom_geos.c 2019-06-12 22:04:58 UTC (rev 17517)
@@ -1209,7 +1209,7 @@
PG_RETURN_NULL();
/* Serialize and return */
- gser_result = gserialized_from_lwgeom(lwgeom_result, 0);
+ gser_result = geometry_serialize(lwgeom_result);
lwgeom_free(lwgeom_result);
PG_RETURN_POINTER(gser_result);
@@ -1338,7 +1338,7 @@
if (!lwgeom_result)
lwpgerror("ST_OffsetCurve: lwgeom_offsetcurve returned NULL");
lwgeom_free(lwgeom_input);
@@ -3088,7 +3088,7 @@
result_array_data = palloc(nclusters * sizeof(Datum));
for (i=0; i<nclusters; ++i)
- result_array_data[i] = PointerGetDatum(gserialized_from_lwgeom(lw_results[i], NULL));
+ result_array_data[i] = PointerGetDatum(geometry_serialize(lw_results[i]));
lwgeom_free(lw_results[i]);
lwfree(lw_results);
Modified: trunk/postgis/lwgeom_in_geohash.c
--- trunk/postgis/lwgeom_in_geohash.c 2019-06-12 15:27:01 UTC (rev 17516)
+++ trunk/postgis/lwgeom_in_geohash.c 2019-06-12 22:04:58 UTC (rev 17517)
@@ -62,7 +62,7 @@
POSTGIS_DEBUGF(2, "ST_Box2dFromGeoHash sw: %.20f, %.20f", lon[0], lat[0]);
POSTGIS_DEBUGF(2, "ST_Box2dFromGeoHash ne: %.20f, %.20f", lon[1], lat[1]);
- box = gbox_new(gflags(0, 0, 1));
+ box = gbox_new(lwflags(0, 0, 1));
box->xmin = lon[0];
box->ymin = lat[0];
Modified: trunk/postgis/lwgeom_inout.c
--- trunk/postgis/lwgeom_inout.c 2019-06-12 15:27:01 UTC (rev 17516)
+++ trunk/postgis/lwgeom_inout.c 2019-06-12 22:04:58 UTC (rev 17517)
@@ -701,7 +701,7 @@
if ( ! gserialized_has_bbox(geom) )
PG_RETURN_POINTER(geom);
- PG_RETURN_POINTER(gserialized_drop_gidx(geom));
+ PG_RETURN_POINTER(gserialized_drop_gbox(geom));
