[postgis-tickets] r17529 - Throw on invalid characters when decoding geohash
Raul
raul at rmr.ninja
Thu Jun 13 04:57:14 PDT 2019
Author: algunenano
Date: 2019-06-13 04:57:13 -0700 (Thu, 13 Jun 2019)
New Revision: 17529
trunk/NEWS
trunk/liblwgeom/cunit/cu_algorithm.c
trunk/liblwgeom/lwalgorithm.c
Closes #4406
Closes https://github.com/postgis/postgis/pull/420
Modified: trunk/NEWS
--- trunk/NEWS 2019-06-13 11:56:02 UTC (rev 17528)
+++ trunk/NEWS 2019-06-13 11:57:13 UTC (rev 17529)
@@ -22,6 +22,7 @@
- #4334, Fix upgrade issues related to renamed parameters (Raúl Marín)
- #4388, AddRasterConstraints: Ignore NULLs when generating constraints (Raúl Marín)
- #4327, Avoid pfree'ing the result of getenv (Raúl Marín)
+ - #4406, Throw on invalid characters when decoding geohash (Raúl Marín)
PostGIS 3.0.0alpha1
2019/05/26
@@ -168,6 +169,7 @@
- #4334, Fix upgrade issues related to renamed function parameters (Raúl Marín)
PostGIS 2.5.0
Modified: trunk/liblwgeom/cunit/cu_algorithm.c
--- trunk/liblwgeom/cunit/cu_algorithm.c 2019-06-13 11:56:02 UTC (rev 17528)
+++ trunk/liblwgeom/cunit/cu_algorithm.c 2019-06-13 11:57:13 UTC (rev 17529)
@@ -1138,6 +1138,23 @@
CU_ASSERT_EQUAL(gh, rs);
+static void
+test_geohash_bbox(void)
+ double lat[2], lon[2];
+ /* SELECT ST_GeoHash(ST_SetSRID(ST_MakePoint(-126,48),4326)) */
+ decode_geohash_bbox("c0w3hf1s70w3hf1s70w3", lat, lon, 100);
+ CU_ASSERT_DOUBLE_EQUAL(lat[0], 48, 1e-11);
+ CU_ASSERT_DOUBLE_EQUAL(lat[1], 48, 1e-11);
+ CU_ASSERT_DOUBLE_EQUAL(lon[0], -126, 1e-11);
+ CU_ASSERT_DOUBLE_EQUAL(lon[1], -126, 1e-11);
+ cu_error_msg_reset();
+ decode_geohash_bbox("@@@@@@", lat, lon, 100);
+ ASSERT_STRING_EQUAL(cu_error_msg, "decode_geohash_bbox: Invalid character '@'");
static void test_lwgeom_remove_repeated_points(void)
LWGEOM *g;
@@ -1698,6 +1715,7 @@
PG_ADD_TEST(suite,test_geohash_precision);
PG_ADD_TEST(suite,test_geohash);
PG_ADD_TEST(suite,test_geohash_point_as_int);
+ PG_ADD_TEST(suite, test_geohash_bbox);
PG_ADD_TEST(suite,test_isclosed);
PG_ADD_TEST(suite,test_lwgeom_simplify);
PG_ADD_TEST(suite,test_lw_arc_center);
Modified: trunk/liblwgeom/lwalgorithm.c
--- trunk/liblwgeom/lwalgorithm.c 2019-06-13 11:56:02 UTC (rev 17528)
+++ trunk/liblwgeom/lwalgorithm.c 2019-06-13 11:57:13 UTC (rev 17529)
@@ -709,6 +709,7 @@
** set in them will be the southwest and northeast coordinates of the bounding
** box accordingly. A precision less than 0 indicates that the entire length
** of the GeoHash should be used.
+** It will call `lwerror` if an invalid character is found
void decode_geohash_bbox(char *geohash, double *lat, double *lon, int precision)
@@ -731,6 +732,13 @@
for (i = 0; i < precision; i++)
c = tolower(geohash[i]);
+ /* Valid characters are all digits and letters except a, i, l and o */
+ if (!(((c >= '0') && (c <= '9')) ||
+ ((c >= 'b') && (c <= 'z') && (c != 'i') && (c != 'l') && (c != 'o'))))
+ lwerror("%s: Invalid character '%c'", __func__, geohash[i]);
+ return;
cd = strchr(base32, c) - base32;
for (j = 0; j < 5; j++)
