[postgis-tickets] r17530 - lookup3: Address GCC warnings
Raul
raul at rmr.ninja
Thu Jun 13 07:54:47 PDT 2019
Author: algunenano
Date: 2019-06-13 07:54:46 -0700 (Thu, 13 Jun 2019)
New Revision: 17530
trunk/liblwgeom/lookup3.c
Modified: trunk/liblwgeom/lookup3.c
--- trunk/liblwgeom/lookup3.c 2019-06-13 11:57:13 UTC (rev 17529)
+++ trunk/liblwgeom/lookup3.c 2019-06-13 14:54:46 UTC (rev 17530)
@@ -624,17 +624,17 @@
/*-------------------------------- last block: affect all 32 bits of (c) */
switch(length) /* all the case statements fall through */
- case 12: c+=((uint32_t)k[11])<<24;
- case 11: c+=((uint32_t)k[10])<<16;
- case 10: c+=((uint32_t)k[9])<<8;
- case 9 : c+=k[8];
- case 8 : b+=((uint32_t)k[7])<<24;
- case 7 : b+=((uint32_t)k[6])<<16;
- case 6 : b+=((uint32_t)k[5])<<8;
- case 5 : b+=k[4];
- case 4 : a+=((uint32_t)k[3])<<24;
- case 3 : a+=((uint32_t)k[2])<<16;
- case 2 : a+=((uint32_t)k[1])<<8;
+ case 12: c+=((uint32_t)k[11])<<24; /* fall through */
+ case 11: c+=((uint32_t)k[10])<<16; /* fall through */
+ case 10: c+=((uint32_t)k[9])<<8; /* fall through */
+ case 9 : c+=k[8]; /* fall through */
+ case 8 : b+=((uint32_t)k[7])<<24; /* fall through */
+ case 7 : b+=((uint32_t)k[6])<<16; /* fall through */
+ case 6 : b+=((uint32_t)k[5])<<8; /* fall through */
+ case 5 : b+=k[4]; /* fall through */
+ case 4 : a+=((uint32_t)k[3])<<24; /* fall through */
+ case 3 : a+=((uint32_t)k[2])<<16; /* fall through */
+ case 2 : a+=((uint32_t)k[1])<<8; /* fall through */
case 1 : a+=k[0];
break;
case 0 : *pc=c; *pb=b; return; /* zero length strings require no mixing */
