[postgis-tickets] [PostGIS] #4429: PROJ6: lwgeom_transform_from_str leaks PJs
trac at osgeo.org
Fri Jun 14 08:47:14 PDT 2019
Reporter: Algunenano | Owner: Algunenano
Type: defect | Status: assigned
Priority: high | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Keywords: |
The current implementation of `lwgeom_transform_from_str` is leaking PJ
and might leak pj_out on error:
int
lwgeom_transform_from_str(LWGEOM *geom, const char* instr, const char*
outstr)
PJ *pj = proj_create_crs_to_crs(NULL, instr, outstr, NULL);
if (!pj)
PJ *pj_in = proj_create(NULL, instr);
PJ *pj_out = proj_create(NULL, outstr);
if (!pj_in)
lwerror("could not parse proj string '%s'",
instr);
<<<<<<<<<<<<<< pj_out might be leaked
if (!pj_out)
proj_destroy(pj_in);
outstr);
<<<<<<<<<<<<<< pj_out is definetely leaked
return LW_FAILURE;
return lwgeom_transform(geom, pj);
<<<<<<<<<<<<<<<<<<<< pj is leaked
I'm planning to fix this as part of the process of reviewing the slowness
issue with PROJ6, just making a note here.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4429>
