[postgis-tickets] [PostGIS] #4429: PROJ6: lwgeom_transform_from_str leaks PJs
trac at osgeo.org
Wed Jun 19 08:07:49 PDT 2019
Reporter: Algunenano | Owner: Algunenano
Type: defect | Status: closed
Priority: high | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords:
Changes (by Raul Marin):
* status: assigned => closed
* resolution: => fixed
Comment:
In [changeset:"17539" 17539]:
#!CommitTicketReference repository="" revision="17539"
lwgeom_transform_from_str: Avoid leaking resources under PROJ6+
Closes #4429
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4429#comment:1>
