[postgis-tickets] [PostGIS] #4421: winnie gcc 8.1 libxml not	liking EDB
    trac at osgeo.org
    Mon Jun 17 14:07:16 PDT 2019
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  PostGIS 3.0.0
 Component:  buildbots  |    Version:  trunk
Resolution:             |   Keywords:
Comment (by robe):
 okay evidentally I've got some other wackiness going on here.
 When I switched back to proj 4.9.3, all was good .  But if I go to proj
 6.1.0 back to crashing hell.
 I think it might be some sort of mix thing since as I recall last I tested
 on my local pc, 6.1.0 worked fine (assuming I get my paths right)
 So might be my GDAL that's the culprit.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4421#comment:2>
