[postgis-tickets] r17537 - Bytebuffer: Ifdef unused code
Raul raul at rmr.ninja
Wed Jun 19 04:57:19 PDT 2019
Author: algunenano
Date: 2019-06-19 04:57:19 -0700 (Wed, 19 Jun 2019)
New Revision: 17537
   trunk/liblwgeom/bytebuffer.c
   trunk/liblwgeom/bytebuffer.h
Raises the coverage of the file
I was going to delete it, but convinced otherwise
Modified: trunk/liblwgeom/bytebuffer.c
--- trunk/liblwgeom/bytebuffer.c	2019-06-18 15:33:32 UTC (rev 17536)
+++ trunk/liblwgeom/bytebuffer.c	2019-06-19 11:57:19 UTC (rev 17537)
@@ -27,43 +27,8 @@
 #include "liblwgeom_internal.h"
 #include "bytebuffer.h"
-* Allocate a new bytebuffer_t. Use bytebuffer_destroy to free.
-bytebuffer_t*
-bytebuffer_create(void)
-	LWDEBUG(2,"Entered bytebuffer_create");
-	return bytebuffer_create_with_size(BYTEBUFFER_STARTSIZE);
-bytebuffer_t*
-bytebuffer_create_with_size(size_t size)
-	LWDEBUGF(2,"Entered bytebuffer_create_with_size %d", size);
-	bytebuffer_t *s;
-	s = lwalloc(sizeof(bytebuffer_t));
-	if ( size < BYTEBUFFER_STATICSIZE )
-		s->capacity = BYTEBUFFER_STATICSIZE;
-		s->buf_start = s->buf_static;
-	else
-		s->buf_start = lwalloc(size);
-		s->capacity = size;
-	s->readcursor = s->writecursor = s->buf_start;
-	memset(s->buf_start,0,s->capacity);
-	LWDEBUGF(4,"We create a buffer on %p of %d bytes", s->buf_start, s->capacity);
-	return s;
 * Allocate just the internal buffer of an existing bytebuffer_t
 * struct. Useful for allocating short-lived bytebuffers off the stack.
@@ -88,19 +53,6 @@
 * Free the bytebuffer_t and all memory managed within it.
 void
-bytebuffer_destroy(bytebuffer_t *s)
-	bytebuffer_destroy_buffer(s);
-	if ( s )
-		lwfree(s);
-	return;
-* Free the bytebuffer_t and all memory managed within it.
-void
 bytebuffer_destroy_buffer(bytebuffer_t *s)
 	if ( s->buf_start != s->buf_static )
@@ -113,26 +65,6 @@
-* Set the read cursor to the beginning
-void
-bytebuffer_reset_reading(bytebuffer_t *s)
-	s->readcursor = s->buf_start;
-* Reset the bytebuffer_t. Useful for starting a fresh string
-* without the expense of freeing and re-allocating a new
-* bytebuffer_t.
-void
-bytebuffer_clear(bytebuffer_t *s)
 * If necessary, expand the bytebuffer_t internal buffer to accomodate the
 * specified additional size.
@@ -189,7 +121,6 @@
 	return s->buf_start;
 * Writes a uint8_t value to the buffer
@@ -203,24 +134,10 @@
 	return;
 void
-bytebuffer_append_bulk(bytebuffer_t *s, void * start, size_t size)
-	LWDEBUGF(2,"bytebuffer_append_bulk with size %d",size);
-	bytebuffer_makeroom(s, size);
-	memcpy(s->writecursor, start, size);
-	s->writecursor += size;
-	return;
-* Writes a uint8_t value to the buffer
-void
 bytebuffer_append_bytebuffer(bytebuffer_t *write_to,bytebuffer_t *write_from )
 	LWDEBUG(2,"bytebuffer_append_bytebuffer");
@@ -231,7 +148,6 @@
 	return;
 * Writes a signed varInt to the buffer
@@ -254,7 +170,100 @@
 	return;
+ * Returns the length of the current buffer
+size_t
+bytebuffer_getlength(const bytebuffer_t *s)
+	return (size_t)(s->writecursor - s->buf_start);
+/* Unused functions */
+#if 0
+* Allocate a new bytebuffer_t. Use bytebuffer_destroy to free.
+bytebuffer_t*
+bytebuffer_create(void)
+	LWDEBUG(2,"Entered bytebuffer_create");
+	return bytebuffer_create_with_size(BYTEBUFFER_STARTSIZE);
+bytebuffer_t*
+bytebuffer_create_with_size(size_t size)
+	LWDEBUGF(2,"Entered bytebuffer_create_with_size %d", size);
+	bytebuffer_t *s;
+	s = lwalloc(sizeof(bytebuffer_t));
+	if ( size < BYTEBUFFER_STATICSIZE )
+		s->capacity = BYTEBUFFER_STATICSIZE;
+		s->buf_start = s->buf_static;
+	else
+		s->buf_start = lwalloc(size);
+		s->capacity = size;
+	s->readcursor = s->writecursor = s->buf_start;
+	memset(s->buf_start,0,s->capacity);
+	LWDEBUGF(4,"We create a buffer on %p of %d bytes", s->buf_start, s->capacity);
+	return s;
+* Free the bytebuffer_t and all memory managed within it.
+void
+bytebuffer_destroy(bytebuffer_t *s)
+	bytebuffer_destroy_buffer(s);
+	if ( s )
+		lwfree(s);
+	return;
+* Set the read cursor to the beginning
+void
+bytebuffer_reset_reading(bytebuffer_t *s)
+	s->readcursor = s->buf_start;
+* Reset the bytebuffer_t. Useful for starting a fresh string
+* without the expense of freeing and re-allocating a new
+* bytebuffer_t.
+void
+bytebuffer_clear(bytebuffer_t *s)
+* Writes a uint8_t value to the buffer
+void
+bytebuffer_append_bulk(bytebuffer_t *s, void * start, size_t size)
+	LWDEBUGF(2,"bytebuffer_append_bulk with size %d",size);
+	bytebuffer_makeroom(s, size);
+	memcpy(s->writecursor, start, size);
+	s->writecursor += size;
+	return;
 * Writes Integer to the buffer
@@ -294,13 +303,13 @@
 	LWDEBUGF(4,"buf_start = %p and write_cursor=%p", buf->buf_start,buf->writecursor);
 	return;
 * Writes a float64 to the buffer
 void
@@ -340,9 +349,9 @@
 	LWDEBUG(4,"Return from bytebuffer_append_double");
 	return;
 * Reads a signed varInt from the buffer
 int64_t
@@ -354,7 +363,7 @@
 	return val;
 * Reads a unsigned varInt from the buffer
 uint64_t
@@ -366,17 +375,8 @@
 	return val;
-* Returns the length of the current buffer
-size_t
-bytebuffer_getlength(const bytebuffer_t *s)
-	return (size_t) (s->writecursor - s->buf_start);
 * Returns a new bytebuffer were both ingoing bytebuffers is merged.
 * Caller is responsible for freeing both incoming bytebuffers and resulting bytebuffer
@@ -402,4 +402,4 @@
 	return res;
+#endif
Modified: trunk/liblwgeom/bytebuffer.h
--- trunk/liblwgeom/bytebuffer.h	2019-06-18 15:33:32 UTC (rev 17536)
+++ trunk/liblwgeom/bytebuffer.h	2019-06-19 11:57:19 UTC (rev 17537)
@@ -46,24 +46,29 @@
 bytebuffer_t;
 void bytebuffer_init_with_size(bytebuffer_t *b, size_t size);
-bytebuffer_t *bytebuffer_create_with_size(size_t size);
-bytebuffer_t *bytebuffer_create(void);
-void bytebuffer_destroy(bytebuffer_t *s);
 void bytebuffer_destroy_buffer(bytebuffer_t *s);
-void bytebuffer_clear(bytebuffer_t *s);
 void bytebuffer_append_byte(bytebuffer_t *s, const uint8_t val);
+void bytebuffer_append_bytebuffer(bytebuffer_t *write_to, bytebuffer_t *write_from);
 void bytebuffer_append_varint(bytebuffer_t *s, const int64_t val);
 void bytebuffer_append_uvarint(bytebuffer_t *s, const uint64_t val);
+size_t bytebuffer_getlength(const bytebuffer_t *s);
+uint8_t* bytebuffer_get_buffer_copy(const bytebuffer_t *s, size_t *buffer_length);
+const uint8_t* bytebuffer_get_buffer(const bytebuffer_t *s, size_t *buffer_length);
+#if 0
+void bytebuffer_destroy(bytebuffer_t *s);
+bytebuffer_t *bytebuffer_create_with_size(size_t size);
+bytebuffer_t *bytebuffer_create(void);
+void bytebuffer_clear(bytebuffer_t *s);
 uint64_t bytebuffer_read_uvarint(bytebuffer_t *s);
 int64_t bytebuffer_read_varint(bytebuffer_t *s);
-size_t bytebuffer_getlength(const bytebuffer_t *s);
 bytebuffer_t* bytebuffer_merge(bytebuffer_t **buff_array, int nbuffers);
 void bytebuffer_reset_reading(bytebuffer_t *s);
-uint8_t* bytebuffer_get_buffer_copy(const bytebuffer_t *s, size_t *buffer_length);
-const uint8_t* bytebuffer_get_buffer(const bytebuffer_t *s, size_t *buffer_length);
 void bytebuffer_append_bytebuffer(bytebuffer_t *write_to,bytebuffer_t *write_from);
 void bytebuffer_append_bulk(bytebuffer_t *s, void * start, size_t size);
 void bytebuffer_append_int(bytebuffer_t *buf, const int val, int swap);
 void bytebuffer_append_double(bytebuffer_t *buf, const double val, int swap);
+#endif
 #endif /* _BYTEBUFFER_H */
