[postgis-tickets] r17538 - Configure: Avoid unnecessary errors with PROJ6
Raul
raul at rmr.ninja
Wed Jun 19 08:02:57 PDT 2019
Author: algunenano
Date: 2019-06-19 08:02:57 -0700 (Wed, 19 Jun 2019)
New Revision: 17538
trunk/configure.ac
No point on checking proj_api.h for PROJ6, just check
for proj.h directly
Related to #4372
Modified: trunk/configure.ac
--- trunk/configure.ac 2019-06-19 11:57:19 UTC (rev 17537)
+++ trunk/configure.ac 2019-06-19 15:02:57 UTC (rev 17538)
@@ -868,18 +868,6 @@
fi
-dnl Check that we can find the proj_api.h header file
-CPPFLAGS_SAVE="$CPPFLAGS"
-CPPFLAGS="$PROJ_CPPFLAGS"
-AC_CHECK_HEADER([proj_api.h],
- [AC_CHECK_HEADER([proj.h],
- [AC_MSG_ERROR([could not find proj.h or proj_api.h - you may need to specify the directory of a PROJ installation using --with-projdir])]
dnl Return the PROJ.4 version number
AC_PROJ_VERSION([POSTGIS_PROJ_VERSION])
AC_DEFINE_UNQUOTED([POSTGIS_PROJ_VERSION], [$POSTGIS_PROJ_VERSION], [PROJ library version])
@@ -891,6 +879,20 @@
AC_MSG_ERROR([PostGIS requires PROJ >= 4.6.0])
fi
+dnl Check that we can find proj headers
+CPPFLAGS_SAVE="$CPPFLAGS"
+CPPFLAGS="$PROJ_CPPFLAGS"
+if test ! "$POSTGIS_PROJ_VERSION" -ge 60; then
+ AC_CHECK_HEADER([proj_api.h],
+ [AC_MSG_ERROR([could not find proj.h or proj_api.h - you may need to specify the directory of a PROJ installation using --with-projdir])]
+else
+ AC_CHECK_HEADER([proj.h],
+fi
AC_SUBST([PROJ_CPPFLAGS])
AC_SUBST([PROJ_LDFLAGS])
