[postgis-tickets] r17539 - lwgeom_transform_from_str: Avoid leaking resources under PROJ6+
Raul
raul at rmr.ninja
Wed Jun 19 08:07:49 PDT 2019
Author: algunenano
Date: 2019-06-19 08:07:49 -0700 (Wed, 19 Jun 2019)
New Revision: 17539
trunk/NEWS
trunk/liblwgeom/lwgeom_transform.c
Closes #4429
Modified: trunk/NEWS
--- trunk/NEWS 2019-06-19 15:02:57 UTC (rev 17538)
+++ trunk/NEWS 2019-06-19 15:07:49 UTC (rev 17539)
@@ -23,6 +23,7 @@
- #4388, AddRasterConstraints: Ignore NULLs when generating constraints (Raúl Marín)
- #4327, Avoid pfree'ing the result of getenv (Raúl Marín)
- #4406, Throw on invalid characters when decoding geohash (Raúl Marín)
+ - #4372, Avoid resource leaks with PROJ6 (Raúl Marín)
PostGIS 3.0.0alpha1
2019/05/26
Modified: trunk/liblwgeom/lwgeom_transform.c
--- trunk/liblwgeom/lwgeom_transform.c 2019-06-19 15:02:57 UTC (rev 17538)
+++ trunk/liblwgeom/lwgeom_transform.c 2019-06-19 15:07:49 UTC (rev 17539)
@@ -219,20 +219,26 @@
if (!pj)
PJ *pj_in = proj_create(NULL, instr);
- PJ *pj_out = proj_create(NULL, outstr);
if (!pj_in)
lwerror("could not parse proj string '%s'", instr);
+ proj_destroy(pj_in);
+ PJ *pj_out = proj_create(NULL, outstr);
if (!pj_out)
- proj_destroy(pj_in);
lwerror("could not parse proj string '%s'", outstr);
+ proj_destroy(pj_out);
+ lwerror("%s: Failed to transform", __func__);
return LW_FAILURE;
- return lwgeom_transform(geom, pj);
+ int ret = lwgeom_transform(geom, pj);
+ proj_destroy(pj);
+ return ret;
int
