[postgis-tickets] r17540 - Fix NEWS related to 3.0alpha3
Raul
raul at rmr.ninja
Wed Jun 19 08:09:25 PDT 2019
Author: algunenano
Date: 2019-06-19 08:09:25 -0700 (Wed, 19 Jun 2019)
New Revision: 17540
trunk/NEWS
Modified: trunk/NEWS
--- trunk/NEWS 2019-06-19 15:07:49 UTC (rev 17539)
+++ trunk/NEWS 2019-06-19 15:09:25 UTC (rev 17540)
@@ -2,6 +2,19 @@
2019/xx/xx
Coming soon
+For full changes and enhancements, refer to PostGIS 3.0.0 section.
+This version requires PostgreSQL 9.5+-12 and GEOS >= 3.6+
+Additional features enabled if you are running Proj6+ and PostgreSQL 12
+* Major highlights *
+ - #4414, Include version number in address_standardizer lib (Raúl Marín)
+ - #4352, Use CREATE OR REPLACE AGGREGATE for PG12+ (Raúl Marín)
+ - #4334, Fix upgrade issues related to renamed parameters (Raúl Marín)
+ - #4388, AddRasterConstraints: Ignore NULLs when generating constraints (Raúl Marín)
+ - #4327, Avoid pfree'ing the result of getenv (Raúl Marín)
+ - #4406, Throw on invalid characters when decoding geohash (Raúl Marín)
+ - #4372, Avoid resource leaks with PROJ6 (Raúl Marín)
PostGIS 3.0.0alpha2
2019/06/02
@@ -17,13 +30,6 @@
from 2.5 (Raúl Marín)
- #4198, Add ST_ConstrainedDelaunayTriangles SFCGAL function (Darafei
Praliaskouski)
- - #4414, Include version number in address_standardizer lib (Raúl Marín)
- - #4352, Use CREATE OR REPLACE AGGREGATE for PG12+ (Raúl Marín)
- - #4334, Fix upgrade issues related to renamed parameters (Raúl Marín)
- - #4388, AddRasterConstraints: Ignore NULLs when generating constraints (Raúl Marín)
- - #4327, Avoid pfree'ing the result of getenv (Raúl Marín)
- - #4406, Throw on invalid characters when decoding geohash (Raúl Marín)
- - #4372, Avoid resource leaks with PROJ6 (Raúl Marín)
PostGIS 3.0.0alpha1
2019/05/26
