[postgis-tickets] r17542 - Increase size of internal PROJ cache
Raul raul at rmr.ninja
Wed Jun 19 08:15:34 PDT 2019
Author: algunenano
Date: 2019-06-19 08:15:34 -0700 (Wed, 19 Jun 2019)
New Revision: 17542
   trunk/libpgcommon/lwgeom_cache.h
   trunk/libpgcommon/lwgeom_transform.c
Creating PROJ projections is specially slow for PROJ6, so
we want to avoid recalculating them as much as possible
This is specially important for ST_Buffer(geography) since
it decides the SRID, and thus the projection, dinamically
based on the geometry position around the globe.
References #4372
Modified: trunk/libpgcommon/lwgeom_cache.h
--- trunk/libpgcommon/lwgeom_cache.h	2019-06-19 15:12:21 UTC (rev 17541)
+++ trunk/libpgcommon/lwgeom_cache.h	2019-06-19 15:15:34 UTC (rev 17542)
@@ -73,7 +73,7 @@
 PROJSRSCacheItem;
 /* PROJ 4 lookup transaction cache methods */
-#define PROJ_CACHE_ITEMS	8
+#define PROJ_CACHE_ITEMS 128
 * The proj4 cache holds a fixed number of reprojection
Modified: trunk/libpgcommon/lwgeom_transform.c
--- trunk/libpgcommon/lwgeom_transform.c	2019-06-19 15:12:21 UTC (rev 17541)
+++ trunk/libpgcommon/lwgeom_transform.c	2019-06-19 15:15:34 UTC (rev 17542)
@@ -40,16 +40,14 @@
 static char *spatialRefSysSchema = NULL;
  * PROJ 4 backend hash table initial hash size
  * (since 16 is the default portal hash table size, and we would
  * typically have 2 entries per portal
- * then we shall use a default size of 32)
+ * then we shall use a default size of 256)
-#define PROJ_BACKEND_HASH_SIZE	32
+#define PROJ_BACKEND_HASH_SIZE 256
  * Backend PROJ hash table
