[postgis-tickets] r17543 - PROJ: Avoid double lookups
Raul
raul at rmr.ninja
Wed Jun 19 08:16:16 PDT 2019
Author: algunenano
Date: 2019-06-19 08:16:15 -0700 (Wed, 19 Jun 2019)
New Revision: 17543
trunk/libpgcommon/lwgeom_transform.c
References #4372
Modified: trunk/libpgcommon/lwgeom_transform.c
--- trunk/libpgcommon/lwgeom_transform.c 2019-06-19 15:15:34 UTC (rev 17542)
+++ trunk/libpgcommon/lwgeom_transform.c 2019-06-19 15:16:15 UTC (rev 17543)
@@ -89,9 +89,7 @@
static void AddPJHashEntry(MemoryContext mcxt, LWPROJ *projection);
/* Internal Cache API */
-/* static PROJPortalCache *GetPROJSRSCache(FunctionCallInfo fcinfo) ; */
-static bool IsInPROJSRSCache(PROJPortalCache *PROJCache, int32_t srid_from, int32_t srid_to);
-static void AddToPROJSRSCache(PROJPortalCache *PROJCache, int32_t srid_from, int32_t srid_to);
+static LWPROJ *AddToPROJSRSCache(PROJPortalCache *PROJCache, int32_t srid_from, int32_t srid_to);
static void DeleteFromPROJSRSCache(PROJPortalCache *PROJCache, int32_t srid_from, int32_t srid_to);
/* Search path for PROJ.4 library */
@@ -339,29 +337,11 @@
* Per-cache management functions
-static bool
-IsInPROJSRSCache(PROJPortalCache *cache, int32_t srid_from, int32_t srid_to)
- * Return true/false depending upon whether the item
- * is in the SRS cache.
- uint32_t i;
- for (i = 0; i < PROJ_CACHE_ITEMS; i++)
- if (cache->PROJSRSCache[i].srid_from == srid_from &&
- cache->PROJSRSCache[i].srid_to == srid_to)
- return true;
- /* Otherwise not found */
- return false;
static LWPROJ *
GetProjectionFromPROJCache(PROJPortalCache *cache, int32_t srid_from, int32_t srid_to)
uint32_t i;
+ for (i = 0; i < cache->PROJSRSCacheCount; i++)
@@ -622,7 +602,7 @@
* we must make sure the entry we choose to delete does not contain other_srid
* which is the definition for the other half of the transformation.
-static void
+static LWPROJ *
MemoryContext PJMemoryContext;
@@ -677,13 +657,13 @@
if (!projpj)
elog(ERROR, "could not form projection (PJ) from 'srid=%d' to 'srid=%d'", srid_from, srid_to);
- return;
+ return NULL;
LWPROJ *projection = lwproj_from_PJ(projpj, srid_from == srid_to);
if (!projection)
elog(ERROR, "could not form projection (LWPROJ) from 'srid=%d' to 'srid=%d'", srid_from, srid_to);
- return;
+ return NULL;
#endif
@@ -766,6 +746,8 @@
PROJCache->PROJSRSCache[PROJCache->PROJSRSCacheCount].projection = projection;
PROJCache->PROJSRSCache[PROJCache->PROJSRSCacheCount].projection_mcxt = PJMemoryContext;
PROJCache->PROJSRSCacheCount++;
+ return projection;
static void
@@ -858,11 +840,11 @@
return LW_FAILURE;
/* Add the output srid to the cache if it's not already there */
- if (!IsInPROJSRSCache(proj_cache, srid_from, srid_to))
- AddToPROJSRSCache(proj_cache, srid_from, srid_to);
- /* Get the projections */
*pj = GetProjectionFromPROJCache(proj_cache, srid_from, srid_to);
+ if (*pj == NULL)
+ *pj = AddToPROJSRSCache(proj_cache, srid_from, srid_to);
return LW_SUCCESS;
