[postgis-tickets] r17544 - PROJ: Use the cache memory context
Raul
raul at rmr.ninja
Wed Jun 19 08:17:19 PDT 2019
Author: algunenano
Date: 2019-06-19 08:17:19 -0700 (Wed, 19 Jun 2019)
New Revision: 17544
trunk/liblwgeom/lwgeom_transform.c
trunk/libpgcommon/lwgeom_cache.c
trunk/libpgcommon/lwgeom_transform.c
trunk/postgis/lwgeom_in_gml.c
Before it was using malloc/free manually, so with
this change we depend fully on Postgres allocator
References #4372
Modified: trunk/liblwgeom/lwgeom_transform.c
--- trunk/liblwgeom/lwgeom_transform.c 2019-06-19 15:16:15 UTC (rev 17543)
+++ trunk/liblwgeom/lwgeom_transform.c 2019-06-19 15:17:19 UTC (rev 17544)
@@ -326,7 +326,7 @@
uint8_t target_swapped = proj_crs_is_swapped(pj_target_crs);
proj_destroy(pj_target_crs);
- LWPROJ *lp = malloc(sizeof(LWPROJ));
+ LWPROJ *lp = lwalloc(sizeof(LWPROJ));
lp->pj = pj;
lp->source_swapped = source_swapped;
lp->target_swapped = target_swapped;
@@ -365,7 +365,7 @@
int ret = lwgeom_transform(geom, lp);
proj_destroy(pj);
- free(lp);
+ lwfree(lp);
return ret;
Modified: trunk/libpgcommon/lwgeom_cache.c
--- trunk/libpgcommon/lwgeom_cache.c 2019-06-19 15:16:15 UTC (rev 17543)
+++ trunk/libpgcommon/lwgeom_cache.c 2019-06-19 15:17:19 UTC (rev 17544)
@@ -95,7 +95,9 @@
int i;
- POSTGIS_DEBUGF(3, "Allocating PROJCache for portal with transform() MemoryContext %p", FIContext(fcinfo));
+ POSTGIS_DEBUGF(3,
+ "Allocating PROJCache for portal with transform() MemoryContext %p",
+ FIContext(fcinfo));
/* Put in any required defaults */
for (i = 0; i < PROJ_CACHE_ITEMS; i++)
Modified: trunk/libpgcommon/lwgeom_transform.c
--- trunk/libpgcommon/lwgeom_transform.c 2019-06-19 15:16:15 UTC (rev 17543)
+++ trunk/libpgcommon/lwgeom_transform.c 2019-06-19 15:17:19 UTC (rev 17544)
@@ -131,10 +131,10 @@
pj_free(pj->pj_from);
if (pj->pj_to)
pj_free(pj->pj_to);
- free(pj);
+ pfree(pj);
#else
proj_destroy(pj->pj);
- free(pj);
+ pfree(pj);
#endif
@@ -311,7 +311,7 @@
/* Return the projection object from the hash */
he = (PJHashEntry *) hash_search(PJHash, key, HASH_FIND, NULL);
- return he->projection;
+ return he ? he->projection : NULL;
@@ -605,7 +605,7 @@
static LWPROJ *
AddToPROJSRSCache(PROJPortalCache *PROJCache, int32_t srid_from, int32_t srid_to)
- MemoryContext PJMemoryContext;
+ MemoryContext PJMemoryContext, oldContext;
PjStrs from_strs, to_strs;
char *pj_from_str, *pj_to_str;
@@ -621,8 +621,10 @@
if (!pjstrs_has_entry(&to_strs))
elog(ERROR, "got NULL for SRID (%d)", srid_to);
+ oldContext = MemoryContextSwitchTo(PROJCache->PROJSRSCacheContext);
#if POSTGIS_PROJ_VERSION < 60
- PJ* projection = malloc(sizeof(PJ));
+ PJ *projection = palloc(sizeof(PJ));
pj_from_str = from_strs.proj4text;
pj_to_str = to_strs.proj4text;
projection->pj_from = projpj_from_string(pj_from_str);
@@ -747,6 +749,7 @@
PROJCache->PROJSRSCache[PROJCache->PROJSRSCacheCount].projection_mcxt = PJMemoryContext;
PROJCache->PROJSRSCacheCount++;
+ MemoryContextSwitchTo(oldContext);
return projection;
Modified: trunk/postgis/lwgeom_in_gml.c
--- trunk/postgis/lwgeom_in_gml.c 2019-06-19 15:16:15 UTC (rev 17543)
+++ trunk/postgis/lwgeom_in_gml.c 2019-06-19 15:17:19 UTC (rev 17544)
@@ -369,7 +369,7 @@
return NULL;
proj_destroy(pj);
- free(lwp);
+ pfree(lwp);
return pa;
