[postgis-tickets] r17548 - PROJ cache: Improve the eviction process
Raul
raul at rmr.ninja
Wed Jun 19 08:26:37 PDT 2019
Author: algunenano
Date: 2019-06-19 08:26:37 -0700 (Wed, 19 Jun 2019)
New Revision: 17548
trunk/libpgcommon/lwgeom_cache.c
trunk/libpgcommon/lwgeom_cache.h
trunk/libpgcommon/lwgeom_transform.c
trunk/regress/core/regress_proj.sql
trunk/regress/core/regress_proj_expected
Instead of selecting a projection that doesn't match
the input source srid and silently drop all cache elements
after it (potentially dropping the whole cache), we keep
a count to know how many item each element has been used
and only drop the element with less uses.
Closes #4372
Modified: trunk/libpgcommon/lwgeom_cache.c
--- trunk/libpgcommon/lwgeom_cache.c 2019-06-19 15:23:33 UTC (rev 17547)
+++ trunk/libpgcommon/lwgeom_cache.c 2019-06-19 15:26:37 UTC (rev 17548)
@@ -96,7 +96,6 @@
POSTGIS_DEBUGF(3,
"Allocating PROJCache for portal with transform() MemoryContext %p",
FIContext(fcinfo));
- /* Put in any required defaults */
memset(cache->PROJSRSCache, 0, sizeof(PROJSRSCacheItem) * PROJ_CACHE_ITEMS);
cache->type = PROJ_CACHE_ENTRY;
cache->PROJSRSCacheCount = 0;
Modified: trunk/libpgcommon/lwgeom_cache.h
--- trunk/libpgcommon/lwgeom_cache.h 2019-06-19 15:23:33 UTC (rev 17547)
+++ trunk/libpgcommon/lwgeom_cache.h 2019-06-19 15:26:37 UTC (rev 17548)
@@ -67,6 +67,7 @@
int32_t srid_from;
int32_t srid_to;
+ uint64_t hits;
LWPROJ *projection;
#if POSTGIS_PGSQL_VERSION < 96
MemoryContext projection_mcxt;
Modified: trunk/libpgcommon/lwgeom_transform.c
--- trunk/libpgcommon/lwgeom_transform.c 2019-06-19 15:23:33 UTC (rev 17547)
+++ trunk/libpgcommon/lwgeom_transform.c 2019-06-19 15:26:37 UTC (rev 17548)
@@ -61,7 +61,7 @@
/* Internal Cache API */
static LWPROJ *AddToPROJSRSCache(PROJPortalCache *PROJCache, int32_t srid_from, int32_t srid_to);
-static void DeleteFromPROJSRSCache(PROJPortalCache *PROJCache, int32_t srid_from, int32_t srid_to);
+static void DeleteFromPROJSRSCache(PROJPortalCache *PROJCache, uint32_t position);
* Given a function call context, figure out what namespace the
@@ -328,7 +328,10 @@
if (cache->PROJSRSCache[i].srid_from == srid_from &&
cache->PROJSRSCache[i].srid_to == srid_to)
+ cache->PROJSRSCache[i].hits++;
return cache->PROJSRSCache[i].projection;
return NULL;
@@ -655,42 +658,40 @@
#endif
- * If the cache is already full then find the first entry
- * that doesn't contain our srids and use this as the
- * subsequent value of PROJSRSCacheCount
- if (PROJCache->PROJSRSCacheCount == PROJ_CACHE_ITEMS)
+ /* If the cache is already full then find the least used element and delete it */
+ uint32_t cache_position = PROJCache->PROJSRSCacheCount;
+ uint32_t hits = 1;
+ if (cache_position == PROJ_CACHE_ITEMS)
- bool found = false;
- uint32_t i;
- for (i = 0; i < PROJ_CACHE_ITEMS; i++)
+ cache_position = 0;
+ hits = PROJCache->PROJSRSCache[0].hits;
+ for (uint32_t i = 1; i < PROJ_CACHE_ITEMS; i++)
- if (found == false &&
- (PROJCache->PROJSRSCache[i].srid_from != srid_from ||
- PROJCache->PROJSRSCache[i].srid_to != srid_to))
+ if (PROJCache->PROJSRSCache[i].hits < hits)
- POSTGIS_DEBUGF(3, "choosing to remove item from query cache with SRIDs %d => %d and index %d",
- PROJCache->PROJSRSCache[i].srid_from,
- PROJCache->PROJSRSCache[i].srid_to,
- i);
- DeleteFromPROJSRSCache(PROJCache,
- PROJCache->PROJSRSCache[i].srid_to);
- PROJCache->PROJSRSCacheCount = i;
- found = true;
+ cache_position = i;
+ hits = PROJCache->PROJSRSCache[i].hits;
+ DeleteFromPROJSRSCache(PROJCache, cache_position);
+ /* To avoid the element we are introduced now being evicted next (as
+ * it would have 1 hit, being most likely the lower one) we reuse the
+ * hits from the evicted position and add some extra buffer
+ hits += 5;
+ else
+ PROJCache->PROJSRSCacheCount++;
- * Now create a memory context for this projection and
- * store it in the backend hash
- POSTGIS_DEBUGF(3, "adding transform %d => %d aka \"%s\" => \"%s\" to query cache at index %d",
- srid_from, srid_to, pj_from_str, pj_to_str, PROJCache->PROJSRSCacheCount);
+ POSTGIS_DEBUGF(3,
+ "adding transform %d => %d aka \"%s\" => \"%s\" to query cache at index %d",
+ srid_from,
+ srid_to,
+ pj_from_str,
+ pj_to_str,
+ cache_position);
/* Free the projection strings */
pjstrs_pfree(&from_strs);
@@ -697,6 +698,10 @@
pjstrs_pfree(&to_strs);
+ * Now create a memory context for this projection and
+ * store it in the backend hash
PJMemoryContext = MemoryContextCreate(T_AllocSetContext, 8192,
&PROJSRSCacheContextMethods,
PROJCache->PROJSRSCacheContext,
@@ -717,13 +722,13 @@
MemoryContextRegisterResetCallback(PROJCache->PROJSRSCacheContext, callback);
#endif
- PROJCache->PROJSRSCache[PROJCache->PROJSRSCacheCount].srid_from = srid_from;
- PROJCache->PROJSRSCache[PROJCache->PROJSRSCacheCount].srid_to = srid_to;
- PROJCache->PROJSRSCache[PROJCache->PROJSRSCacheCount].projection = projection;
+ PROJCache->PROJSRSCache[cache_position].srid_from = srid_from;
+ PROJCache->PROJSRSCache[cache_position].srid_to = srid_to;
+ PROJCache->PROJSRSCache[cache_position].projection = projection;
+ PROJCache->PROJSRSCache[cache_position].hits = hits;
- PROJCache->PROJSRSCache[PROJCache->PROJSRSCacheCount].projection_mcxt = PJMemoryContext;
+ PROJCache->PROJSRSCache[cache_position].projection_mcxt = PJMemoryContext;
#endif
- PROJCache->PROJSRSCacheCount++;
MemoryContextSwitchTo(oldContext);
return projection;
@@ -730,37 +735,26 @@
static void
-DeleteFromPROJSRSCache(PROJPortalCache *PROJCache, int32_t srid_from, int32_t srid_to)
+DeleteFromPROJSRSCache(PROJPortalCache *PROJCache, uint32_t position)
- * Delete the SRID entry from the cache
- uint32_t i;
- if (PROJCache->PROJSRSCache[i].srid_from == srid_from &&
- PROJCache->PROJSRSCache[i].srid_to == srid_to)
- POSTGIS_DEBUGF(3, "removing query cache entry with SRIDs %d => %d at index %d", srid_from, srid_to, i);
+ POSTGIS_DEBUGF(3,
+ "removing query cache entry with SRIDs %d => %d at index %u",
+ PROJCache->PROJSRSCache[position].srid_from,
+ PROJCache->PROJSRSCache[position].srid_to,
+ position);
- * Zero out the entries and free the PROJ handle
- * by deleting the memory context
- /* Deleting the memory context will free the PROJ objects */
- MemoryContextDelete(PROJCache->PROJSRSCache[i].projection_mcxt);
- PROJCache->PROJSRSCache[i].projection_mcxt = NULL;
+ /* Deleting the memory context will free the PROJ objects */
+ MemoryContextDelete(PROJCache->PROJSRSCache[position].projection_mcxt);
+ PROJCache->PROJSRSCache[position].projection_mcxt = NULL;
#else
- /* Call PROJSRSDestroyPJ to free the PROJ objects memory now instead of
- * waiting for the parent memory context to exit */
- PROJSRSDestroyPJ(PROJCache->PROJSRSCache[i].projection);
+ /* Call PROJSRSDestroyPJ to free the PROJ objects memory now instead of
+ * waiting for the parent memory context to exit */
+ PROJSRSDestroyPJ(PROJCache->PROJSRSCache[position].projection);
#endif
- PROJCache->PROJSRSCache[i].projection = NULL;
- PROJCache->PROJSRSCache[i].srid_from = SRID_UNKNOWN;
- PROJCache->PROJSRSCache[i].srid_to = SRID_UNKNOWN;
+ PROJCache->PROJSRSCache[position].projection = NULL;
+ PROJCache->PROJSRSCache[position].srid_from = SRID_UNKNOWN;
+ PROJCache->PROJSRSCache[position].srid_to = SRID_UNKNOWN;
Modified: trunk/regress/core/regress_proj.sql
--- trunk/regress/core/regress_proj.sql 2019-06-19 15:23:33 UTC (rev 17547)
+++ trunk/regress/core/regress_proj.sql 2019-06-19 15:26:37 UTC (rev 17548)
@@ -58,3 +58,12 @@
DELETE FROM spatial_ref_sys WHERE srid >= 100000;
+--- Overflow proj cache
+TRUNCATE spatial_ref_sys;
+\i ../../spatial_ref_sys.sql
+SELECT 13, count(*) FROM
+ SELECT ST_Transform('SRID=4326; POINT(0 0)'::geometry, srid) AS g
+ FROM
+ ( SELECT srid FROM spatial_ref_sys LIMIT 150 ) _a
+) _b WHERE g IS NOT NULL;
\ No newline at end of file
Modified: trunk/regress/core/regress_proj_expected
--- trunk/regress/core/regress_proj_expected 2019-06-19 15:23:33 UTC (rev 17547)
+++ trunk/regress/core/regress_proj_expected 2019-06-19 15:26:37 UTC (rev 17548)
@@ -11,3 +11,4 @@
10|POINT(574600 5316780)
11|SRID=100001;POINT(574600 5316780)
ERROR: could not parse proj string 'invalid projection'
+13|150
