[postgis-tickets] r17549 - Revert r17538
Raul
raul at rmr.ninja
Wed Jun 19 09:57:22 PDT 2019
Author: algunenano
Date: 2019-06-19 09:57:22 -0700 (Wed, 19 Jun 2019)
New Revision: 17549
trunk/configure.ac
Revert r17538
Some of the bots didn't like it
Modified: trunk/configure.ac
--- trunk/configure.ac 2019-06-19 15:26:37 UTC (rev 17548)
+++ trunk/configure.ac 2019-06-19 16:57:22 UTC (rev 17549)
@@ -868,6 +868,18 @@
fi
+dnl Check that we can find the proj_api.h header file
+CPPFLAGS_SAVE="$CPPFLAGS"
+CPPFLAGS="$PROJ_CPPFLAGS"
+AC_CHECK_HEADER([proj_api.h],
+ [AC_CHECK_HEADER([proj.h],
+ [AC_MSG_ERROR([could not find proj.h or proj_api.h - you may need to specify the directory of a PROJ installation using --with-projdir])]
dnl Return the PROJ.4 version number
AC_PROJ_VERSION([POSTGIS_PROJ_VERSION])
AC_DEFINE_UNQUOTED([POSTGIS_PROJ_VERSION], [$POSTGIS_PROJ_VERSION], [PROJ library version])
@@ -879,20 +891,6 @@
AC_MSG_ERROR([PostGIS requires PROJ >= 4.6.0])
fi
-dnl Check that we can find proj headers
-CPPFLAGS_SAVE="$CPPFLAGS"
-CPPFLAGS="$PROJ_CPPFLAGS"
-if test ! "$POSTGIS_PROJ_VERSION" -ge 60; then
- AC_CHECK_HEADER([proj_api.h],
- [AC_MSG_ERROR([could not find proj.h or proj_api.h - you may need to specify the directory of a PROJ installation using --with-projdir])]
-else
- AC_CHECK_HEADER([proj.h],
-fi
AC_SUBST([PROJ_CPPFLAGS])
AC_SUBST([PROJ_LDFLAGS])
