[postgis-tickets] r17554 - Use GEOSPrepare also for Points and Multipoints
Raul
raul at rmr.ninja
Fri Jun 21 03:49:32 PDT 2019
Author: algunenano
Date: 2019-06-21 03:49:32 -0700 (Fri, 21 Jun 2019)
New Revision: 17554
trunk/NEWS
trunk/postgis/lwgeom_geos_prepared.c
This was removed waiting for a fix that was introduced
in GEOS 3.6, which is now the minimum required version.
Basic tests show this makes ST_Intersects with cached
points 30x faster.
Closes #3437
Modified: trunk/NEWS
--- trunk/NEWS 2019-06-20 16:28:41 UTC (rev 17553)
+++ trunk/NEWS 2019-06-21 10:49:32 UTC (rev 17554)
@@ -15,6 +15,7 @@
- #4406, Throw on invalid characters when decoding geohash (Raúl Marín)
- #4429, Avoid resource leaks with PROJ6 (Raúl Marín)
- #4372, PROJ6: Speed improvements (Raúl Marín)
+ - #3437, Speed up ST_Intesects with Points (Raúl Marín)
PostGIS 3.0.0alpha2
2019/06/02
Modified: trunk/postgis/lwgeom_geos_prepared.c
--- trunk/postgis/lwgeom_geos_prepared.c 2019-06-20 16:28:41 UTC (rev 17553)
+++ trunk/postgis/lwgeom_geos_prepared.c 2019-06-21 10:49:32 UTC (rev 17554)
@@ -350,16 +350,6 @@
return LW_FAILURE;
- * Avoid creating a PreparedPoint around a Point or a MultiPoint.
- * Consider changing this behavior in the future if supported GEOS
- * versions correctly handle prepared points and multipoints and
- * provide a performance benefit.
- * See https://trac.osgeo.org/postgis/ticket/3437
- if (lwgeom_get_type(lwgeom) == POINTTYPE || lwgeom_get_type(lwgeom) == MULTIPOINTTYPE)
- return LW_FAILURE;
prepcache->geom = LWGEOM2GEOS( lwgeom , 0);
if ( ! prepcache->geom ) return LW_FAILURE;
prepcache->prepared_geom = GEOSPrepare( prepcache->geom );
