[postgis-tickets] [PostGIS] #3437: ST_Intersects incorrect for MultiPoints
trac at osgeo.org
Fri Jun 21 03:51:04 PDT 2019
Reporter: dbaston | Owner: dbaston
Type: defect | Status: closed
Priority: critical | Milestone: PostGIS 3.0.0
Component: postgis | Version: 2.2.x
Resolution: fixed | Keywords:
Changes (by Algunenano):
* milestone: PostGIS GEOS => PostGIS 3.0.0
Comment:
I've only applied it to trunk. If required it could be backported to
previous stable releases depending on the GEOS release.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3437#comment:8>
