[postgis-tickets] [PostGIS] #4433: Regress Error on Bessie 32-bit tickets full join test
PostGIS trac at osgeo.org
Sat Jun 22 19:40:11 PDT 2019
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 3.0.0
Component:  postgis  |    Version:  trunk
 Keywords:           |
 21:57:45 PostgreSQL 10.5 on i386-portbld-freebsd11.2, compiled by FreeBSD
 clang version 6.0.0 (tags/RELEASE_600/final 326565) (based on LLVM 6.0.0),
 32-bit
 21:57:45   Postgis 3.0.0alpha3dev - r17557 - 2019-06-23 01:51:52
 21:57:45   scripts 3.0.0alpha3dev r17557
 21:57:45   GEOS: 3.6.3-CAPI-1.10.3 80c13047
 21:57:45   PROJ: Rel. 5.1.0, June 1st, 2018
 21:57:45
 21:57:45 Running tests
 21:57:45
 21:57:45  ../loader/Point .............. ok
 21:57:47  ../loader/PointM .............. ok
 21:57:48  ../loader/PointZ .............. ok
 21:57:50  ../loader/MultiPoint .............. ok
 21:57:51  ../loader/MultiPointM .............. ok
 21:57:52  ../loader/MultiPointZ .............. ok
 21:57:53  ../loader/Arc .............. ok
 21:57:55  ../loader/ArcM .............. ok
 21:57:56  ../loader/ArcZ .............. ok
 21:57:57  ../loader/Polygon .............. ok
 21:57:59  ../loader/PolygonM .............. ok
 21:58:00  ../loader/PolygonZ .............. ok
 21:58:02  ../loader/TSTPolygon ......... ok
 21:58:03  ../loader/TSIPolygon ......... ok
 21:58:03  ../loader/TSTIPolygon ......... ok
 21:58:04  ../loader/PointWithSchema ..... ok
 21:58:05  ../loader/NoTransPoint ......... ok
 21:58:06  ../loader/NotReallyMultiPoint ......... ok
 21:58:07  ../loader/MultiToSinglePoint ......... ok
 21:58:07  ../loader/ReprojectPts ........ ok
 21:58:08  ../loader/ReprojectPtsGeog ........ ok
 21:58:09  ../loader/Latin1 .... ok
 21:58:09  ../loader/Latin1-implicit .... ok
 21:58:09  ../loader/mfile .... ok
 21:58:09  ../dumper/literalsrid ....... ok
 21:58:11  ../dumper/realtable ....... ok
 21:58:12  affine .. ok
 21:58:12  bestsrid .. ok
 21:58:12  binary .. ok
 21:58:12  boundary .. ok
 21:58:13  chaikin .. ok
 21:58:13  filterm .. ok
 21:58:13  cluster .. ok
 21:58:13  concave_hull .. ok
 21:58:15  ctors .. ok
 21:58:15  curvetoline .. ok
 21:58:15  dump .. ok
 21:58:15  dumppoints .. ok
 21:58:15  empty .. ok
 21:58:16  estimatedextent .. ok
 21:58:16  forcecurve .. ok
 21:58:16  geography .. ok
 21:58:16  geometric_median .. ok
 21:58:16  hausdorff .. ok
 21:58:17  in_geohash .. ok
 21:58:17  in_gml .. ok
 21:58:17  in_kml .. ok
 21:58:17  in_encodedpolyline .. ok
 21:58:18  iscollection .. ok
 21:58:18  legacy .. ok
 21:58:19  long_xact .. ok
 21:58:19  lwgeom_regress .. ok
 21:58:19  measures .. ok
 21:58:20  minimum_bounding_circle .. ok
 21:58:20  normalize .. ok
 21:58:20  operators .. ok
 21:58:20  orientation .. ok
 21:58:20  out_geometry .. ok
 21:58:21  out_geography .. ok
 21:58:21  polygonize .. ok
 21:58:21  polyhedralsurface .. ok
 21:58:21  postgis_type_name .. ok
 21:58:21  quantize_coordinates .. ok
 21:58:21  regress .. ok
 21:58:22  regress_bdpoly .. ok
 21:58:22  regress_buffer_params .. ok
 21:58:22  regress_gist_index_nd .. ok
 21:58:25  regress_index .. ok
 21:58:29  regress_index_nulls .. ok
 21:58:29  regress_management .. ok
 21:58:29  regress_selectivity .. ok
 21:58:30  regress_lrs .. ok
 21:58:30  regress_ogc .. ok
 21:58:30  regress_ogc_cover .. ok
 21:58:30  regress_ogc_prep .. ok
 21:58:30  regress_proj .. ok
 21:58:32  relate .. ok
 21:58:32  remove_repeated_points .. ok
 21:58:33  removepoint .. ok
 21:58:33  reverse .. ok
 21:58:33  setpoint .. ok
 21:58:33  simplify .. ok
 21:58:33  simplifyvw .. ok
 21:58:33  size .. ok
 21:58:34  snaptogrid .. ok
 21:58:34  split .. ok
 21:58:34  sql-mm-serialize .. ok
 21:58:34  sql-mm-circularstring .. ok
 21:58:34  sql-mm-compoundcurve .. ok
 21:58:35  sql-mm-curvepoly .. ok
 21:58:35  sql-mm-general .. ok
 21:58:35  sql-mm-multicurve .. ok
 21:58:35  sql-mm-multisurface .. ok
 21:58:36  swapordinates .. ok
 21:58:36  summary .. ok
 21:58:36  temporal .. ok
 21:58:36  temporal_knn .. ok
 21:58:36  tickets .. failed (diff expected obtained:
 /home/jenkins/tmp/pgis_reg_f9334cb0058fc5a796335d219109738a0d1e9ae5/test_98_diff)
 21:58:39
 21:58:39 --- tickets_expected   2019-06-22 21:51:32.916336000 -0400
 21:58:39 +++
 /home/jenkins/tmp/pgis_reg_f9334cb0058fc5a796335d219109738a0d1e9ae5/test_98_out
 2019-06-22 21:57:58.244904000 -0400
 21:58:39 @@ -390,3 +390,4 @@
 21:58:39  ERROR:  BOX2D_construct: args can not be empty points
 21:58:39  #4176|t
 21:58:39  #4394
 21:58:39 +#4394
 21:58:39
 21:58:39  twkb .. ok
 21:58:39  typmod .. ok
 21:58:48  wkb .. ok
 21:58:48  wkt .. ok
 21:58:48  wmsservers .. ok
 21:58:49  offsetcurve .. ok
 21:58:49  relatematch .. ok
 21:58:49  isvaliddetail .. ok
 21:58:50  sharedpaths .. ok
 21:58:50  snap .. ok
 21:58:50  node .. ok
 21:58:50  unaryunion .. ok
 21:58:50  clean .. ok
 21:58:51  relate_bnr .. ok
 21:58:52  delaunaytriangles .. ok
 21:58:52  clipbybox2d .. ok
 21:58:52  subdivide .. ok
 21:59:56  voronoi .. ok
 21:59:56  regress_brin_index .. ok
 21:59:57  regress_brin_index_3d .. ok
 21:59:58  regress_brin_index_geography .. ok
 21:59:58  minimum_clearance .. ok
 21:59:58  oriented_envelope .. ok
 21:59:58  in_geojson .. ok
 21:59:59  mvt .. ok
 21:59:59  geobuf .. ok
 21:59:59  mvt_jsonb .. ok
 21:59:59  uninstall .. ok (4663)
 22:00:00
 22:00:00 Run tests: 126
 22:00:00 Failed: 1
 22:00:01 gmake[3]: *** [Makefile:215: check] Error 1
 22:00:01 gmake[3]: Leaving directory
 '/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie32/f9334cb0058fc5a796335d219109738a0d1e9ae5/regress/core'
 22:00:01 gmake[2]: *** [Makefile:43: check] Error 2
 22:00:01 gmake[2]: Leaving directory
 '/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie32/f9334cb0058fc5a796335d219109738a0d1e9ae5/regress'
 22:00:01 gmake[1]: *** [GNUmakefile:20: check] Error 1
 22:00:01 gmake[1]: Leaving directory
 '/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie32/f9334cb0058fc5a796335d219109738a0d1e9ae5'
 22:00:01 *** Error code 2
 22:00:01
 22:00:01 Stop.
 22:00:01 make: stopped in
 22:00:01 Build step 'Execute shell' marked build as failure
 22:00:01 Finished: FAILURE
 This is failing on new test for full join which is a new feature
 introduced in #4394
 It looks like 2 rows are being returned instead of 1 for #4394
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4433>
