[postgis-tickets] [PostGIS] #4433: Regress Error on Bessie 32-bit tickets full join test
trac at osgeo.org
Sat Jun 22 22:16:14 PDT 2019
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
okay this seems to be a 32-bit issue for sure. I turned on one of
winnie's 32-bits (I wasn't testing 32-bit on winnie before and her 64-bits
were passing).
Here 32-bit yields the same issue:
PostgreSQL 10.8, compiled by Visual C++ build 1800, 32-bit
Postgis 3.0.0alpha3dev - r17557 - 2019-06-23 04:57:21
scripts 3.0.0alpha3dev r17557
GEOS: 3.8.0-CAPI-1.11.0
PROJ: Rel. 4.9.3, 15 August 2016
tickets .. failed (diff expected obtained:
/projects/postgis/tmp/3.0.0alpha3dev_pg10_geos3.8_gdal2.2.4w32/test_98_diff)
--- tickets_expected 2019-06-22 19:17:09.794524200 -0400
/projects/postgis/tmp/3.0.0alpha3dev_pg10_geos3.8_gdal2.2.4w32/test_98_out
2019-06-23 01:13:24.185978100 -0400
@@ -390,3 +390,4 @@
ERROR: BOX2D_construct: args can not be empty points
#4176|t
#4394
+#4394
I'll try next with 9.6/32-bit on winnie to rule out PostgreSQL 10/32-bit
issue
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4433#comment:1>
