[postgis-tickets] [PostGIS] #4434: ST_Intersects planning time crash on PG12
trac at osgeo.org
Mon Jun 24 02:53:11 PDT 2019
Reporter: komzpa | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Description changed by komzpa:
Old description:
> Program terminated with signal SIGSEGV, Segmentation fault.
> #0 0x0000000000000000 in ?? ()
> (gdb) ие
> Undefined command: "". Try "help".
> (gdb) bt
> #1 0x0000564420046a99 in CatalogCacheComputeHashValue
> (cache=cache at entry=0x564421ca4b80, nkeys=nkeys at entry=3,
> v1=v1 at entry=96399022, v2=v2 at entry=2, v3=v3 at entry=1, v4=v4 at entry=0) at
> ./build/../src/backend/utils/cache/catcache.c:289
> #2 0x0000564420048669 in SearchCatCacheInternal (v4=0, v3=1, v2=2,
> v1=96399022, nkeys=3, cache=0x564421ca4b80) at
> ./build/../src/backend/utils/cache/catcache.c:1236
> #3 SearchCatCache3 (cache=0x564421ca4b80, v1=v1 at entry=96399022,
> v2=v2 at entry=2, v3=v3 at entry=1) at
> ./build/../src/backend/utils/cache/catcache.c:1183
> #4 0x0000564420059bc3 in SearchSysCache3 (cacheId=cacheId at entry=57,
> key1=key1 at entry=96399022, key2=key2 at entry=2, key3=key3 at entry=1) at
> ./build/../src/backend/utils/cache/syscache.c:1153
> #5 0x00007fc0ebcea6bd in pg_get_nd_stats
> (table_oid=table_oid at entry=96399022, att_num=2, mode=mode at entry=2,
> only_parent=only_parent at entry=false) at gserialized_estimate.c:959
> #6 0x00007fc0ebcedbd3 in gserialized_joinsel_internal (root=<optimized
> out>, args=<optimized out>, jointype=<optimized out>, mode=mode at entry=2)
> at gserialized_estimate.c:1292
> #7 0x00007fc0ebce77b7 in postgis_index_supportfn (fcinfo=<optimized
> out>) at gserialized_supportfn.c:211
> #8 0x000056442006733d in FunctionCall1Coll (flinfo=0x7ffd623f2c00,
> collation=<optimized out>, arg1=<optimized out>) at
> ./build/../src/backend/utils/fmgr/fmgr.c:1140
> #9 0x0000564420067b45 in OidFunctionCall1Coll (functionId=<optimized
> out>, collation=collation at entry=0, arg1=arg1 at entry=140726251760768) at
> ./build/../src/backend/utils/fmgr/fmgr.c:1418
> #10 0x000056441fe97c69 in function_selectivity
> (root=root at entry=0x564421ce0ab0, funcid=<optimized out>,
> args=0x564421d0b338, inputcollid=0, is_join=<optimized out>,
> varRelid=varRelid at entry=0, jointype=JOIN_INNER, sjinfo=0x7ffd623f2ff0) at
> ./build/../src/backend/optimizer/util/plancat.c:1884
> #11 0x000056441fe5551a in clause_selectivity (root=0x564421ce0ab0,
> clause=0x564421d0b278, varRelid=0, jointype=JOIN_INNER, sjinfo=<optimized
> out>) at ./build/../src/backend/optimizer/path/clausesel.c:555
> #12 0x000056441fe55ab5 in clauselist_selectivity_simple
> (root=0x564421ce0ab0, clauses=0x564421d56300, varRelid=0,
> jointype=JOIN_INNER, sjinfo=0x7ffd623f2ff0, estimatedclauses=0x0) at
> ./build/../src/include/nodes/pg_list.h:79
> #13 0x000056441fe55c35 in clauselist_selectivity
> (root=root at entry=0x564421ce0ab0, clauses=clauses at entry=0x564421d56300,
> varRelid=varRelid at entry=0, jointype=jointype at entry=JOIN_INNER,
> sjinfo=sjinfo at entry=0x7ffd623f2ff0) at
> ./build/../src/backend/optimizer/path/clausesel.c:103
> #14 0x000056441fe56b10 in calc_joinrel_size_estimate
> (root=root at entry=0x564421ce0ab0, outer_rows=503, inner_rows=1,
> sjinfo=sjinfo at entry=0x7ffd623f2ff0,
> restrictlist_in=restrictlist_in at entry=0x564421d56300,
> inner_rel=<optimized out>, outer_rel=<optimized out>, joinrel=<optimized
> out>)
> at ./build/../src/backend/optimizer/path/costsize.c:4635
> #15 0x000056441fe5bf2a in set_joinrel_size_estimates
> (root=root at entry=0x564421ce0ab0, rel=rel at entry=0x564421d0fa78,
> outer_rel=outer_rel at entry=0x564421d0c8b0,
> inner_rel=inner_rel at entry=0x564421d0d320,
> restrictlist=restrictlist at entry=0x564421d56300)
> at ./build/../src/backend/optimizer/path/costsize.c:4490
> #16 0x000056441fe9b518 in build_join_rel (root=root at entry=0x564421ce0ab0,
> joinrelids=joinrelids at entry=0x564421d54048,
> inner_rel=inner_rel at entry=0x564421d0d320, sjinfo=0x7ffd623f2ff0,
> restrictlist_ptr=restrictlist_ptr at entry=0x7ffd623f2fe8)
> at ./build/../src/backend/optimizer/util/relnode.c:710
> #17 0x000056441fe67525 in make_join_rel (root=root at entry=0x564421ce0ab0,
> rel1=rel1 at entry=0x564421d0c8b0, rel2=rel2 at entry=0x564421d0d320) at
> ./build/../src/backend/optimizer/path/joinrels.c:724
> #18 0x000056441fe67797 in make_rels_by_clause_joins
> (other_rels=<optimized out>, old_rel=<optimized out>, root=<optimized
> out>) at ./build/../src/backend/optimizer/path/joinrels.c:289
> #19 join_search_one_level (root=root at entry=0x564421ce0ab0,
> level=level at entry=2) at
> ./build/../src/backend/optimizer/path/joinrels.c:111
> #20 0x000056441fe54a2b in standard_join_search (root=0x564421ce0ab0,
> levels_needed=4, initial_rels=<optimized out>) at
> ./build/../src/backend/optimizer/path/allpaths.c:2881
> #21 0x000056441fe54e87 in make_one_rel (root=root at entry=0x564421ce0ab0,
> joinlist=joinlist at entry=0x564421d0b998) at
> ./build/../src/backend/optimizer/path/allpaths.c:227
> #22 0x000056441fe74dac in query_planner (root=root at entry=0x564421ce0ab0,
> qp_callback=qp_callback at entry=0x56441fe762f0 <standard_qp_callback>,
> qp_extra=qp_extra at entry=0x7ffd623f32d0) at
> ./build/../src/backend/optimizer/plan/planmain.c:271
> #23 0x000056441fe791fa in grouping_planner (root=<optimized out>,
> inheritance_update=false, tuple_fraction=<optimized out>) at
> ./build/../src/backend/optimizer/plan/planner.c:2048
> #24 0x000056441fe7bba8 in subquery_planner
> (glob=glob at entry=0x564421ce0350, parse=parse at entry=0x564421cdfe18,
> parent_root=parent_root at entry=0x0, hasRecursion=hasRecursion at entry=false,
> tuple_fraction=tuple_fraction at entry=0) at
> ./build/../src/backend/optimizer/plan/planner.c:1012
> #25 0x000056441fe7ccd5 in standard_planner (parse=0x564421cdfe18,
> cursorOptions=256, boundParams=<optimized out>) at
> ./build/../src/backend/optimizer/plan/planner.c:406
> #26 0x000056441ff32982 in pg_plan_query
> (querytree=querytree at entry=0x564421cdfe18,
> cursorOptions=cursorOptions at entry=256, boundParams=boundParams at entry=0x0)
> at ./build/../src/backend/tcop/postgres.c:878
> #27 0x000056441ff32a56 in pg_plan_queries (querytrees=<optimized out>,
> at ./build/../src/backend/tcop/postgres.c:968
> #28 0x000056441ff32f1f in exec_simple_query (query_string=0x564421bf0bb0
> "select distinct on (ST_FORCE2D(t.geom)) ST_Segmentize(t.geom ::
> geography, 50) :: geometry geom, up.point_index\n", ' ' <repeats 70
> times>, "from spanning_tree"...) at
> ./build/../src/backend/tcop/postgres.c:1143
> #29 0x000056441ff3464e in PostgresMain (argc=<optimized out>,
> argv=argv at entry=0x564421c4a5c0, dbname=<optimized out>,
> username=<optimized out>) at ./build/../src/backend/tcop/postgres.c:4249
> #30 0x000056441feba609 in BackendRun (port=0x564421c40ba0,
> port=0x564421c40ba0) at
> ./build/../src/backend/postmaster/postmaster.c:4431
> #31 BackendStartup (port=0x564421c40ba0) at
> ./build/../src/backend/postmaster/postmaster.c:4122
> #32 ServerLoop () at ./build/../src/backend/postmaster/postmaster.c:1704
> #33 0x000056441febb52f in PostmasterMain (argc=5, argv=0x564421be7c00) at
> ./build/../src/backend/postmaster/postmaster.c:1377
> #34 0x000056441fc23efd in main (argc=5, argv=0x564421be7c00) at
> ./build/../src/backend/main/main.c:228
> (gdb) bt full
> No symbol table info available.
> hashValue = 0
> oneHash = <optimized out>
> cc_hashfunc = 0x564421ca4b98
> __func__ = "CatalogCacheComputeHashValue"
> hashValue = <optimized out>
> iter = <optimized out>
> bucket = <optimized out>
> arguments = {96399022, 2, 1, 0}
> hashIndex = <optimized out>
> ct = <optimized out>
> arguments = <optimized out>
> No locals.
> No locals.
> stats_tuple = 0x0
> nd_stats = <optimized out>
> selectivity = <optimized out>
> relid1 = 96399022
> relid2 = 96399051
> stats1 = <optimized out>
> stats2 = <optimized out>
> arg1 = 0x564421d0b2c8
> arg2 = 0x564421d0b368
> var1 = 0x564421d0b2c8
> var2 = 0x564421d0b368
> __func__ = "gserialized_joinsel_internal"
> req = 0x7ffd623f2c80
> rawreq = 0x7ffd623f2c80
> ret = 0x0
> __func__ = "postgis_index_supportfn"
> fcinfodata = {fcinfo = {flinfo = 0x7ffd623f2c00, context = 0x0,
> resultinfo = 0x0, fncollation = 0, isnull = false, nargs = 1, args =
> 0x7ffd623f2bc0}, fcinfo_data = "\000,?b\375\177", '\000' <repeats 23
> times>, "\253\001\000\200,?b\375\177\000\000\000,?b\375\177\000"}
> fcinfo = 0x7ffd623f2ba0
> result = <optimized out>
> __func__ = "FunctionCall1Coll"
> __errno_location = <optimized out>
> flinfo = {fn_addr = 0x7fc0ebce7480 <postgis_index_supportfn>,
> fn_oid = 164073987, fn_nargs = 1, fn_strict = false, fn_retset = false,
> fn_stats = 1 '\001', fn_extra = 0x0, fn_mcxt = 0x564421bf0aa0, fn_expr =
> 0x0}
> prosupport = <optimized out>
> req = {type = T_SupportRequestSelectivity, root = 0x564421ce0ab0,
> funcid = 17676, args = 0x564421d0b338, inputcollid = 0, is_join = true,
> varRelid = 0, jointype = JOIN_INNER, sjinfo = 0x7ffd623f2ff0, selectivity
> = -1}
> sresult = <optimized out>
> __func__ = "function_selectivity"
> funcclause = 0x564421d0b278
> s1 = 0.5
> rinfo = <optimized out>
> cacheable = true
> s1 = 1
> rqlist = 0x0
> l = <optimized out>
> listidx = <optimized out>
> s1 = 1
> rel = <optimized out>
> estimatedclauses = 0x0
> out>)
> restrictlist = 0x564421d56300
> fkselec = 1
> jselec = <optimized out>
> pselec = <optimized out>
> nrows = <optimized out>
> __func__ = "calc_joinrel_size_estimate"
> No locals.
> joinrel = 0x564421d0fa78
> --Type <RET> for more, q to quit, c to continue without paging--
> joinrelids = 0x564421d54048
> reversed = false
> sjinfo_data = {type = T_SpecialJoinInfo, min_lefthand =
> 0x564421d0cac0, min_righthand = 0x564421d0cf90, syn_lefthand =
> 0x564421d0cac0, syn_righthand = 0x564421d0cf90, jointype = JOIN_INNER,
> lhs_strict = false, delay_upper_joins = false, semi_can_btree = false,
> semi_can_hash = false, semi_operators = 0x0,
> semi_rhs_exprs = 0x0}
> joinrel = <optimized out>
> trel = <optimized out>
> other_rel = 0x564421d0d320
> l = 0x564421d53fd8
> l = <optimized out>
> other_rel = <optimized out>
> other_rels = <optimized out>
> old_rel = 0x564421d0c8b0
> joinrels = 0x564421d53ff8
> r = 0x564421d53fb8
> k = <optimized out>
> __func__ = "join_search_one_level"
> lc = <optimized out>
> lev = 2
> __func__ = "standard_join_search"
> rti = <optimized out>
> total_pages = <optimized out>
> parse = 0x564421cdfe18
> joinlist = 0x564421d0b998
> final_rel = <optimized out>
> __func__ = "query_planner"
> sort_input_targets = 0x0
> sort_input_target_parallel_safe = <optimized out>
> grouping_target = <optimized out>
> scanjoin_target = <optimized out>
> activeWindows = <optimized out>
> qp_extra = {activeWindows = 0x0, groupClause = 0x0}
> sort_input_targets_contain_srfs = 0x7ffd623f3330
> have_grouping = <optimized out>
> wflists = <optimized out>
> gset_data = 0x0
> sort_input_target = <optimized out>
> grouping_targets = 0x56441fe8be91
> <eval_const_expressions_mutator+721>
> grouping_target_parallel_safe = <optimized out>
> scanjoin_targets = 0x564421d0af18
> scanjoin_target_parallel_safe = <optimized out>
> grouping_targets_contain_srfs = 0x564421d0b048
> scanjoin_targets_contain_srfs = 0x564421ce0ab0
> scanjoin_target_same_exprs = <optimized out>
> agg_costs = {numAggs = 0, numOrderedAggs = 0, hasNonPartial =
> false, hasNonSerial = false, transCost = {startup = 0, per_tuple = 0},
> finalCost = {startup = 0, per_tuple = 0}, transitionSpace = 0}
> offset_est = 0
> count_est = 0
> limit_tuples = -1
> have_postponed_srfs = false
> final_target = <optimized out>
> final_targets = 0x56441fe80d14 <process_sublinks_mutator+116>
> final_targets_contain_srfs = 0x7ffd623f3340
> final_target_parallel_safe = <optimized out>
> current_rel = <optimized out>
> extra = {limit_needed = 104, limit_tuples =
> 2.2727019708697341e-322, count_est = 140726251762512, offset_est =
> 94850595203962}
> __func__ = "grouping_planner"
> root = <optimized out>
> newWithCheckOptions = <optimized out>
> newHaving = <optimized out>
> hasOuterJoins = <optimized out>
> hasResultRTEs = <optimized out>
> l = <optimized out>
> glob = 0x564421ce0350
> tuple_fraction = 0
> best_path = <optimized out>
> top_plan = <optimized out>
> lp = <optimized out>
> lr = <optimized out>
> query = 0x564421cdfe18
> stmt = <optimized out>
> stmt_list = 0x0
> query_list = 0x564421cf5e68
> parsetree = 0x564421cdfc88
> portal = <optimized out>
> snapshot_set = true
> commandTag = 0x564420199aa4 "SELECT"
> completionTag =
> "\000\000\000\000\002\000\000\000p6?b\375\177\000\000\000\000\000\000\000\000\000\000\250\244\304!DV\000\000`6?b\375\177\000\000\340\067?b\375\177\000\000\260\v\277!DV\000\000\250\244\304!DV\000"
> querytree_list = <optimized out>
> plantree_list = <optimized out>
> receiver = <optimized out>
> format = 0
> dest = DestRemote
> oldcontext = 0x564421cc0800
> parsetree_list = 0x564421cdfcd8
> parsetree_item = 0x564421cdfcb8
> save_log_statement_stats = false
> was_logged = false
> use_implicit_block = false
> msec_str =
> "\000\000\000\000\002\000\000\000p6?b\375\177\000\000\000\000\000\000\000\000\000\000\250\244\304!DV\000"
> __func__ = "exec_simple_query"
> query_string = 0x564421bf0bb0 "select distinct on
> (ST_FORCE2D(t.geom)) ST_Segmentize(t.geom :: geography, 50) :: geometry
> geom, up.point_index\n", ' ' <repeats 70 times>, "from spanning_tree"...
> firstchar = <optimized out>
> input_message = {data = 0x564421bf0bb0 "select distinct on
> geom, up.point_index\n", ' ' <repeats 70 times>, "from spanning_tree"...,
> len = 1012, maxlen = 1024, cursor = 1012}
> local_sigjmp_buf = {{__jmpbuf = {140726251763712,
> -123453365073212831, 1, 94850624300200, 140726251764576, 94850624261024,
> -123453364964160927, -5964001441627370911}, __mask_was_saved = 1,
> __saved_mask = {__val = {0, 140726251769533, 140726251769498,
> 140726251769810, 0, 139637976727552, 94850624261024,
> 140726251763984, 17413074780819009280, 140726251764144,
> 94850595312895, 206158430256, 140726251764168, 140726251763968,
> 17413074780819009280, 94850623896800}}}}
> send_ready_for_query = false
> disable_idle_in_transaction_timeout = false
> __func__ = "PostgresMain"
> av = 0x564421c4a5c0
> maxac = <optimized out>
> ac = 1
> i = 1
> av = <optimized out>
> i = <optimized out>
> __func__ = "BackendRun"
> bn = <optimized out>
> pid = <optimized out>
> __func__ = "BackendStartup"
> save_errno = <optimized out>
> port = 0x564421c40ba0
> i = <optimized out>
> rmask = {fds_bits = {64, 0 <repeats 15 times>}}
> selres = <optimized out>
> now = <optimized out>
> readmask = {fds_bits = {104, 0 <repeats 15 times>}}
> nSockets = 7
> last_lockfile_recheck_time = 1561369481
> last_touch_time = 1561367346
> __func__ = "ServerLoop"
> opt = <optimized out>
> status = <optimized out>
> userDoption = <optimized out>
> listen_addr_saved = <optimized out>
> i = <optimized out>
> output_config_variable = <optimized out>
> __func__ = "PostmasterMain"
> No locals.
> Offending query:
> from spanning_tree t,
> user_points up
> where t.point_id = up.id
> and t.point_id in
> (select u.id
> from user_points u,
> isochrones i
> where i.id = 'd88492bf-71a3-43c7-a721-af36ab8a6eb0'::uuid
> and st_intersects(u.geom, i.points));
New description:
(gdb) ие
(gdb) bt
#7 0x00007fc0ebce77b7 in postgis_index_supportfn (fcinfo=<optimized out>)
restrictlist_in=restrictlist_in at entry=0x564421d56300, inner_rel=<optimized
out>, outer_rel=<optimized out>, joinrel=<optimized out>)
#18 0x000056441fe67797 in make_rels_by_clause_joins (other_rels=<optimized
out>, old_rel=<optimized out>, root=<optimized out>) at
(gdb) bt full
hashValue = 0
No locals.
No locals.
stats_tuple = 0x0
relid1 = 96399022
relid2 = 96399051
ret = 0x0
0x0}
= -1}
s1 = 0.5
cacheable = true
s1 = 1
rqlist = 0x0
l = <optimized out>
s1 = 1
fkselec = 1
No locals.
reversed = false
l = 0x564421d53fd8
l = <optimized out>
r = 0x564421d53fb8
k = <optimized out>
lev = 2
gset_data = 0x0
offset_est = 0
count_est = 0
limit_tuples = -1
94850595203962}
l = <optimized out>
tuple_fraction = 0
stmt_list = 0x0
snapshot_set = true
completionTag =
format = 0
dest = DestRemote
was_logged = false
msec_str =
av = 0x564421c4a5c0
ac = 1
i = 1
i = <optimized out>
i = <optimized out>
nSockets = 7
i = <optimized out>
No locals.
Offending query:
select distinct on (ST_FORCE2D(t.geom)) ST_Segmentize(t.geom :: geography,
from
spanning_tree t,
user_points up
and t.point_id in
(select u.id
from user_points u,
isochrones i
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4434#comment:1>
