[postgis-tickets] [PostGIS] #4434: ST_Intersects planning time crash on PG12
trac at osgeo.org
Mon Jun 24 02:52:28 PDT 2019
Reporter: komzpa | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Keywords: |
Program terminated with signal SIGSEGV, Segmentation fault.
#0 0x0000000000000000 in ?? ()
(gdb) ие
Undefined command: "". Try "help".
(gdb) bt
#1 0x0000564420046a99 in CatalogCacheComputeHashValue
(cache=cache at entry=0x564421ca4b80, nkeys=nkeys at entry=3,
v1=v1 at entry=96399022, v2=v2 at entry=2, v3=v3 at entry=1, v4=v4 at entry=0) at
./build/../src/backend/utils/cache/catcache.c:289
#2 0x0000564420048669 in SearchCatCacheInternal (v4=0, v3=1, v2=2,
v1=96399022, nkeys=3, cache=0x564421ca4b80) at
./build/../src/backend/utils/cache/catcache.c:1236
#3 SearchCatCache3 (cache=0x564421ca4b80, v1=v1 at entry=96399022,
v2=v2 at entry=2, v3=v3 at entry=1) at
./build/../src/backend/utils/cache/catcache.c:1183
#4 0x0000564420059bc3 in SearchSysCache3 (cacheId=cacheId at entry=57,
key1=key1 at entry=96399022, key2=key2 at entry=2, key3=key3 at entry=1) at
./build/../src/backend/utils/cache/syscache.c:1153
#5 0x00007fc0ebcea6bd in pg_get_nd_stats
(table_oid=table_oid at entry=96399022, att_num=2, mode=mode at entry=2,
only_parent=only_parent at entry=false) at gserialized_estimate.c:959
#6 0x00007fc0ebcedbd3 in gserialized_joinsel_internal (root=<optimized
out>, args=<optimized out>, jointype=<optimized out>, mode=mode at entry=2)
at gserialized_estimate.c:1292
#7 0x00007fc0ebce77b7 in postgis_index_supportfn (fcinfo=<optimized out>)
at gserialized_supportfn.c:211
#8 0x000056442006733d in FunctionCall1Coll (flinfo=0x7ffd623f2c00,
collation=<optimized out>, arg1=<optimized out>) at
./build/../src/backend/utils/fmgr/fmgr.c:1140
#9 0x0000564420067b45 in OidFunctionCall1Coll (functionId=<optimized
out>, collation=collation at entry=0, arg1=arg1 at entry=140726251760768) at
./build/../src/backend/utils/fmgr/fmgr.c:1418
#10 0x000056441fe97c69 in function_selectivity
(root=root at entry=0x564421ce0ab0, funcid=<optimized out>,
args=0x564421d0b338, inputcollid=0, is_join=<optimized out>,
varRelid=varRelid at entry=0, jointype=JOIN_INNER, sjinfo=0x7ffd623f2ff0) at
./build/../src/backend/optimizer/util/plancat.c:1884
#11 0x000056441fe5551a in clause_selectivity (root=0x564421ce0ab0,
clause=0x564421d0b278, varRelid=0, jointype=JOIN_INNER, sjinfo=<optimized
out>) at ./build/../src/backend/optimizer/path/clausesel.c:555
#12 0x000056441fe55ab5 in clauselist_selectivity_simple
(root=0x564421ce0ab0, clauses=0x564421d56300, varRelid=0,
jointype=JOIN_INNER, sjinfo=0x7ffd623f2ff0, estimatedclauses=0x0) at
./build/../src/include/nodes/pg_list.h:79
#13 0x000056441fe55c35 in clauselist_selectivity
(root=root at entry=0x564421ce0ab0, clauses=clauses at entry=0x564421d56300,
varRelid=varRelid at entry=0, jointype=jointype at entry=JOIN_INNER,
sjinfo=sjinfo at entry=0x7ffd623f2ff0) at
./build/../src/backend/optimizer/path/clausesel.c:103
#14 0x000056441fe56b10 in calc_joinrel_size_estimate
(root=root at entry=0x564421ce0ab0, outer_rows=503, inner_rows=1,
sjinfo=sjinfo at entry=0x7ffd623f2ff0,
restrictlist_in=restrictlist_in at entry=0x564421d56300, inner_rel=<optimized
out>, outer_rel=<optimized out>, joinrel=<optimized out>)
at ./build/../src/backend/optimizer/path/costsize.c:4635
#15 0x000056441fe5bf2a in set_joinrel_size_estimates
(root=root at entry=0x564421ce0ab0, rel=rel at entry=0x564421d0fa78,
outer_rel=outer_rel at entry=0x564421d0c8b0,
inner_rel=inner_rel at entry=0x564421d0d320,
restrictlist=restrictlist at entry=0x564421d56300)
at ./build/../src/backend/optimizer/path/costsize.c:4490
#16 0x000056441fe9b518 in build_join_rel (root=root at entry=0x564421ce0ab0,
joinrelids=joinrelids at entry=0x564421d54048,
inner_rel=inner_rel at entry=0x564421d0d320, sjinfo=0x7ffd623f2ff0,
restrictlist_ptr=restrictlist_ptr at entry=0x7ffd623f2fe8)
at ./build/../src/backend/optimizer/util/relnode.c:710
#17 0x000056441fe67525 in make_join_rel (root=root at entry=0x564421ce0ab0,
rel1=rel1 at entry=0x564421d0c8b0, rel2=rel2 at entry=0x564421d0d320) at
./build/../src/backend/optimizer/path/joinrels.c:724
#18 0x000056441fe67797 in make_rels_by_clause_joins (other_rels=<optimized
out>, old_rel=<optimized out>, root=<optimized out>) at
./build/../src/backend/optimizer/path/joinrels.c:289
#19 join_search_one_level (root=root at entry=0x564421ce0ab0,
level=level at entry=2) at
./build/../src/backend/optimizer/path/joinrels.c:111
#20 0x000056441fe54a2b in standard_join_search (root=0x564421ce0ab0,
levels_needed=4, initial_rels=<optimized out>) at
./build/../src/backend/optimizer/path/allpaths.c:2881
#21 0x000056441fe54e87 in make_one_rel (root=root at entry=0x564421ce0ab0,
joinlist=joinlist at entry=0x564421d0b998) at
./build/../src/backend/optimizer/path/allpaths.c:227
#22 0x000056441fe74dac in query_planner (root=root at entry=0x564421ce0ab0,
qp_callback=qp_callback at entry=0x56441fe762f0 <standard_qp_callback>,
qp_extra=qp_extra at entry=0x7ffd623f32d0) at
./build/../src/backend/optimizer/plan/planmain.c:271
#23 0x000056441fe791fa in grouping_planner (root=<optimized out>,
inheritance_update=false, tuple_fraction=<optimized out>) at
./build/../src/backend/optimizer/plan/planner.c:2048
#24 0x000056441fe7bba8 in subquery_planner
(glob=glob at entry=0x564421ce0350, parse=parse at entry=0x564421cdfe18,
parent_root=parent_root at entry=0x0, hasRecursion=hasRecursion at entry=false,
tuple_fraction=tuple_fraction at entry=0) at
./build/../src/backend/optimizer/plan/planner.c:1012
#25 0x000056441fe7ccd5 in standard_planner (parse=0x564421cdfe18,
cursorOptions=256, boundParams=<optimized out>) at
./build/../src/backend/optimizer/plan/planner.c:406
#26 0x000056441ff32982 in pg_plan_query
(querytree=querytree at entry=0x564421cdfe18,
cursorOptions=cursorOptions at entry=256, boundParams=boundParams at entry=0x0)
at ./build/../src/backend/tcop/postgres.c:878
#27 0x000056441ff32a56 in pg_plan_queries (querytrees=<optimized out>,
at ./build/../src/backend/tcop/postgres.c:968
#28 0x000056441ff32f1f in exec_simple_query (query_string=0x564421bf0bb0
"select distinct on (ST_FORCE2D(t.geom)) ST_Segmentize(t.geom ::
geography, 50) :: geometry geom, up.point_index\n", ' ' <repeats 70
times>, "from spanning_tree"...) at
./build/../src/backend/tcop/postgres.c:1143
#29 0x000056441ff3464e in PostgresMain (argc=<optimized out>,
argv=argv at entry=0x564421c4a5c0, dbname=<optimized out>,
username=<optimized out>) at ./build/../src/backend/tcop/postgres.c:4249
#30 0x000056441feba609 in BackendRun (port=0x564421c40ba0,
port=0x564421c40ba0) at
./build/../src/backend/postmaster/postmaster.c:4431
#31 BackendStartup (port=0x564421c40ba0) at
./build/../src/backend/postmaster/postmaster.c:4122
#32 ServerLoop () at ./build/../src/backend/postmaster/postmaster.c:1704
#33 0x000056441febb52f in PostmasterMain (argc=5, argv=0x564421be7c00) at
./build/../src/backend/postmaster/postmaster.c:1377
#34 0x000056441fc23efd in main (argc=5, argv=0x564421be7c00) at
./build/../src/backend/main/main.c:228
(gdb) bt full
No symbol table info available.
hashValue = 0
oneHash = <optimized out>
cc_hashfunc = 0x564421ca4b98
__func__ = "CatalogCacheComputeHashValue"
hashValue = <optimized out>
iter = <optimized out>
bucket = <optimized out>
arguments = {96399022, 2, 1, 0}
hashIndex = <optimized out>
ct = <optimized out>
arguments = <optimized out>
No locals.
No locals.
stats_tuple = 0x0
nd_stats = <optimized out>
selectivity = <optimized out>
relid1 = 96399022
relid2 = 96399051
stats1 = <optimized out>
stats2 = <optimized out>
arg1 = 0x564421d0b2c8
arg2 = 0x564421d0b368
var1 = 0x564421d0b2c8
var2 = 0x564421d0b368
__func__ = "gserialized_joinsel_internal"
req = 0x7ffd623f2c80
rawreq = 0x7ffd623f2c80
ret = 0x0
__func__ = "postgis_index_supportfn"
fcinfodata = {fcinfo = {flinfo = 0x7ffd623f2c00, context = 0x0,
resultinfo = 0x0, fncollation = 0, isnull = false, nargs = 1, args =
0x7ffd623f2bc0}, fcinfo_data = "\000,?b\375\177", '\000' <repeats 23
times>, "\253\001\000\200,?b\375\177\000\000\000,?b\375\177\000"}
fcinfo = 0x7ffd623f2ba0
result = <optimized out>
__func__ = "FunctionCall1Coll"
__errno_location = <optimized out>
flinfo = {fn_addr = 0x7fc0ebce7480 <postgis_index_supportfn>,
fn_oid = 164073987, fn_nargs = 1, fn_strict = false, fn_retset = false,
fn_stats = 1 '\001', fn_extra = 0x0, fn_mcxt = 0x564421bf0aa0, fn_expr =
0x0}
prosupport = <optimized out>
req = {type = T_SupportRequestSelectivity, root = 0x564421ce0ab0,
funcid = 17676, args = 0x564421d0b338, inputcollid = 0, is_join = true,
varRelid = 0, jointype = JOIN_INNER, sjinfo = 0x7ffd623f2ff0, selectivity
= -1}
sresult = <optimized out>
__func__ = "function_selectivity"
funcclause = 0x564421d0b278
s1 = 0.5
rinfo = <optimized out>
cacheable = true
s1 = 1
rqlist = 0x0
l = <optimized out>
listidx = <optimized out>
s1 = 1
rel = <optimized out>
estimatedclauses = 0x0
restrictlist = 0x564421d56300
fkselec = 1
jselec = <optimized out>
pselec = <optimized out>
nrows = <optimized out>
__func__ = "calc_joinrel_size_estimate"
No locals.
joinrel = 0x564421d0fa78
--Type <RET> for more, q to quit, c to continue without paging--
joinrelids = 0x564421d54048
reversed = false
sjinfo_data = {type = T_SpecialJoinInfo, min_lefthand =
0x564421d0cac0, min_righthand = 0x564421d0cf90, syn_lefthand =
0x564421d0cac0, syn_righthand = 0x564421d0cf90, jointype = JOIN_INNER,
lhs_strict = false, delay_upper_joins = false, semi_can_btree = false,
semi_can_hash = false, semi_operators = 0x0,
semi_rhs_exprs = 0x0}
joinrel = <optimized out>
trel = <optimized out>
other_rel = 0x564421d0d320
l = 0x564421d53fd8
l = <optimized out>
other_rel = <optimized out>
other_rels = <optimized out>
old_rel = 0x564421d0c8b0
joinrels = 0x564421d53ff8
r = 0x564421d53fb8
k = <optimized out>
__func__ = "join_search_one_level"
lc = <optimized out>
lev = 2
__func__ = "standard_join_search"
rti = <optimized out>
total_pages = <optimized out>
parse = 0x564421cdfe18
joinlist = 0x564421d0b998
final_rel = <optimized out>
__func__ = "query_planner"
sort_input_targets = 0x0
sort_input_target_parallel_safe = <optimized out>
grouping_target = <optimized out>
scanjoin_target = <optimized out>
activeWindows = <optimized out>
qp_extra = {activeWindows = 0x0, groupClause = 0x0}
sort_input_targets_contain_srfs = 0x7ffd623f3330
have_grouping = <optimized out>
wflists = <optimized out>
gset_data = 0x0
sort_input_target = <optimized out>
grouping_targets = 0x56441fe8be91
<eval_const_expressions_mutator+721>
grouping_target_parallel_safe = <optimized out>
scanjoin_targets = 0x564421d0af18
scanjoin_target_parallel_safe = <optimized out>
grouping_targets_contain_srfs = 0x564421d0b048
scanjoin_targets_contain_srfs = 0x564421ce0ab0
scanjoin_target_same_exprs = <optimized out>
agg_costs = {numAggs = 0, numOrderedAggs = 0, hasNonPartial =
false, hasNonSerial = false, transCost = {startup = 0, per_tuple = 0},
finalCost = {startup = 0, per_tuple = 0}, transitionSpace = 0}
offset_est = 0
count_est = 0
limit_tuples = -1
have_postponed_srfs = false
final_target = <optimized out>
final_targets = 0x56441fe80d14 <process_sublinks_mutator+116>
final_targets_contain_srfs = 0x7ffd623f3340
final_target_parallel_safe = <optimized out>
current_rel = <optimized out>
extra = {limit_needed = 104, limit_tuples =
2.2727019708697341e-322, count_est = 140726251762512, offset_est =
94850595203962}
__func__ = "grouping_planner"
root = <optimized out>
newWithCheckOptions = <optimized out>
newHaving = <optimized out>
hasOuterJoins = <optimized out>
hasResultRTEs = <optimized out>
l = <optimized out>
glob = 0x564421ce0350
tuple_fraction = 0
best_path = <optimized out>
top_plan = <optimized out>
lp = <optimized out>
lr = <optimized out>
query = 0x564421cdfe18
stmt = <optimized out>
stmt_list = 0x0
query_list = 0x564421cf5e68
parsetree = 0x564421cdfc88
portal = <optimized out>
snapshot_set = true
commandTag = 0x564420199aa4 "SELECT"
completionTag =
"\000\000\000\000\002\000\000\000p6?b\375\177\000\000\000\000\000\000\000\000\000\000\250\244\304!DV\000\000`6?b\375\177\000\000\340\067?b\375\177\000\000\260\v\277!DV\000\000\250\244\304!DV\000"
querytree_list = <optimized out>
plantree_list = <optimized out>
receiver = <optimized out>
format = 0
dest = DestRemote
oldcontext = 0x564421cc0800
parsetree_list = 0x564421cdfcd8
parsetree_item = 0x564421cdfcb8
save_log_statement_stats = false
was_logged = false
use_implicit_block = false
msec_str =
"\000\000\000\000\002\000\000\000p6?b\375\177\000\000\000\000\000\000\000\000\000\000\250\244\304!DV\000"
__func__ = "exec_simple_query"
query_string = 0x564421bf0bb0 "select distinct on
(ST_FORCE2D(t.geom)) ST_Segmentize(t.geom :: geography, 50) :: geometry
geom, up.point_index\n", ' ' <repeats 70 times>, "from spanning_tree"...
firstchar = <optimized out>
input_message = {data = 0x564421bf0bb0 "select distinct on
geom, up.point_index\n", ' ' <repeats 70 times>, "from spanning_tree"...,
len = 1012, maxlen = 1024, cursor = 1012}
local_sigjmp_buf = {{__jmpbuf = {140726251763712,
-123453365073212831, 1, 94850624300200, 140726251764576, 94850624261024,
-123453364964160927, -5964001441627370911}, __mask_was_saved = 1,
__saved_mask = {__val = {0, 140726251769533, 140726251769498,
140726251769810, 0, 139637976727552, 94850624261024,
140726251763984, 17413074780819009280, 140726251764144,
94850595312895, 206158430256, 140726251764168, 140726251763968,
17413074780819009280, 94850623896800}}}}
send_ready_for_query = false
disable_idle_in_transaction_timeout = false
__func__ = "PostgresMain"
av = 0x564421c4a5c0
maxac = <optimized out>
ac = 1
i = 1
av = <optimized out>
i = <optimized out>
__func__ = "BackendRun"
bn = <optimized out>
pid = <optimized out>
__func__ = "BackendStartup"
save_errno = <optimized out>
port = 0x564421c40ba0
i = <optimized out>
rmask = {fds_bits = {64, 0 <repeats 15 times>}}
selres = <optimized out>
now = <optimized out>
readmask = {fds_bits = {104, 0 <repeats 15 times>}}
nSockets = 7
last_lockfile_recheck_time = 1561369481
last_touch_time = 1561367346
__func__ = "ServerLoop"
opt = <optimized out>
status = <optimized out>
userDoption = <optimized out>
listen_addr_saved = <optimized out>
i = <optimized out>
output_config_variable = <optimized out>
__func__ = "PostmasterMain"
No locals.
Offending query:
select distinct on (ST_FORCE2D(t.geom)) ST_Segmentize(t.geom :: geography,
from
spanning_tree t,
user_points up
where t.point_id = up.id
and t.point_id in
(select u.id
from user_points u,
isochrones i
where i.id = 'd88492bf-71a3-43c7-a721-af36ab8a6eb0'::uuid
and st_intersects(u.geom, i.points));
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4434>
