[postgis-tickets] [PostGIS] #4433: Regress Error on Bessie/Winnie 32-bit tickets full join test
trac at osgeo.org
Fri Jun 28 15:54:27 PDT 2019
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
based on discussion on irc with Darafei
I did this:
update pg_operator set oprcanhash = false, oprcanmerge = true where
oprname = '=' and oprcode = 'geometry_eq'::regproc;
and then the test on bessie32
with mj as (select 'POINT(0 0)'::geometry geom) select '#4394' from mj a
full join mj b on a.geom = b.geom;
Yielded 1 row as it should.
Both in 3.0 are set to true.
So it seems there is something wrong with our hashing logic on 32-bit.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4433#comment:4>
