[postgis-tickets] r17559 - Improve output of lwgeom_summary
Sandro Santilli
strk at kbt.io
Wed Jun 26 01:04:14 PDT 2019
Author: strk
Date: 2019-06-26 01:04:14 -0700 (Wed, 26 Jun 2019)
New Revision: 17559
trunk/liblwgeom/lwgeom_debug.c
trunk/regress/core/lwgeom_regress_expected
trunk/regress/core/summary_expected
trunk/regress/core/tickets_expected
- Do not print a useless newline
- Use plural/singular correctly
- Prepend a colon to elements listing
Modified: trunk/liblwgeom/lwgeom_debug.c
--- trunk/liblwgeom/lwgeom_debug.c 2019-06-25 21:51:46 UTC (rev 17558)
+++ trunk/liblwgeom/lwgeom_debug.c 2019-06-26 08:04:14 UTC (rev 17559)
@@ -98,10 +98,13 @@
result = (char *)lwalloc(size);
- sprintf(result, "%*.s%s[%s] with %d elements\n",
+ sprintf(result, "%*.s%s[%s] with %d element%s",
offset, pad, lwtype_name(col->type),
zmflags,
- col->ngeoms);
+ col->ngeoms,
+ col->ngeoms ?
+ ( col->ngeoms > 1 ? "s:\n" : ":\n")
+ : "s");
for (i=0; i<col->ngeoms; i++)
@@ -136,10 +139,13 @@
- sprintf(result, "%*.s%s[%s] with %i rings\n",
+ sprintf(result, "%*.s%s[%s] with %i ring%s",
offset, pad, lwtype_name(poly->type),
zmflags,
- poly->nrings);
+ poly->nrings,
+ poly->nrings ?
+ ( poly->nrings > 1 ? "s:\n" : ":\n")
+ : "s");
for (i=0; i<poly->nrings; i++)
Modified: trunk/regress/core/lwgeom_regress_expected
--- trunk/regress/core/lwgeom_regress_expected 2019-06-25 21:51:46 UTC (rev 17558)
+++ trunk/regress/core/lwgeom_regress_expected 2019-06-26 08:04:14 UTC (rev 17559)
@@ -7,15 +7,15 @@
11184
#3069|Point[S]
#3069|LineString[S] with 2 points
-#3069|MultiPoint[S] with 1 elements Point[S]
-#3069|MultiLineString[S] with 1 elements LineString[S] with 2 points
-#3069|Polygon[BS] with 1 rings ring 0 has 5 points
+#3069|MultiPoint[S] with 1 element: Point[S]
+#3069|MultiLineString[S] with 1 element: LineString[S] with 2 points
+#3069|Polygon[BS] with 1 ring: ring 0 has 5 points
#3069|BOX(1 1,1 1)
#3069|BOX(0 0,1 1)
#3069|BOX(0 0,1 1)
#3069|BOX(1 1,1 1)
#3069|BOX(0 0,1 1)
-#2902|GeometryCollection[ZBS] with 3 elements Polygon[ZS] with 1 rings ring 0 has 5 points Point[ZS] MultiLineString[ZS] with 1 elements LineString[ZS] with 2 points
+#2902|GeometryCollection[ZBS] with 3 elements: Polygon[ZS] with 1 ring: ring 0 has 5 points Point[ZS] MultiLineString[ZS] with 1 element: LineString[ZS] with 2 points
BoundingDiagonal1|SRID=4326;LINESTRING(999999986991104 999999986991104,1e+15 1e+15)
BoundingDiagonal2|SRID=4326;LINESTRING(1e+15 1e+15,1e+15 1e+15)
BoundingDiagonal3|SRID=4326;LINESTRING(999999986991104 999999986991104,1e+15 1e+15)
Modified: trunk/regress/core/summary_expected
--- trunk/regress/core/summary_expected 2019-06-25 21:51:46 UTC (rev 17558)
+++ trunk/regress/core/summary_expected 2019-06-26 08:04:14 UTC (rev 17559)
@@ -6,19 +6,19 @@
T1ZM|Point[ZM]
T1ZMB|Point[ZMB]
T1ZMBS|Point[ZMBS]
-T3|MultiPoint[] with 1 elements
+T3|MultiPoint[] with 1 element:
Point[]
-T4|MultiPoint[S] with 1 elements
+T4|MultiPoint[S] with 1 element:
Point[S]
-T5|GeometryCollection[B] with 2 elements
- MultiLineString[] with 2 elements
+T5|GeometryCollection[B] with 2 elements:
+ MultiLineString[] with 2 elements:
LineString[] with 2 points
- MultiPoint[] with 1 elements
+ MultiPoint[] with 1 element:
Point[]
-T6|GeometryCollection[BS] with 2 elements
- MultiLineString[S] with 2 elements
+T6|GeometryCollection[BS] with 2 elements:
+ MultiLineString[S] with 2 elements:
- MultiPoint[S] with 1 elements
+ MultiPoint[S] with 1 element:
Point[S]
Modified: trunk/regress/core/tickets_expected
--- trunk/regress/core/tickets_expected 2019-06-25 21:51:46 UTC (rev 17558)
+++ trunk/regress/core/tickets_expected 2019-06-26 08:04:14 UTC (rev 17559)
@@ -237,15 +237,15 @@
#2145|6792004
#2232|M 0 0 l 0 0 1 0 0 0 1 0 0 0
#2307|MULTIPOLYGON(((-41.1932 -7.3257,-41.1616 -7.3257,-41.1569 -7.3257,-41.1569 -7.3483,-41.1932 -7.3483,-41.1932 -7.3257),(-41.1616 -7.3257,-41.1879 -7.3257,-41.1879 -7.3425,-41.1616 -7.3425,-41.1616 -7.3257)))
-#2409|GeometryCollection[B] with 2 elements
- MultiSurface[] with 2 elements
- Polygon[] with 1 rings
+#2409|GeometryCollection[B] with 2 elements:
+ MultiSurface[] with 2 elements:
+ Polygon[] with 1 ring:
ring 0 has 5 points
- CurvePolygon[] with 1 elements
- CompoundCurve[] with 2 elements
+ CurvePolygon[] with 1 element:
+ CompoundCurve[] with 2 elements:
LineString[] with 5 points
CircularString[] with 5 points
- Tin[] with 1 elements
+ Tin[] with 1 element:
Triangle[] with 4 points
#2415.1|MULTICURVE(COMPOUNDCURVE((0 0,10 0),CIRCULARSTRING(10 0,15 1,20 10)))
#2415.2|MULTISURFACE(CURVEPOLYGON(CIRCULARSTRING(10 0,15 1,20 0,18 5,20 10,10 10,10 0)))
