[postgis-tickets] [PostGIS] #4437: pgsql2shp makes dangerous call to liblwgeom on POINT EMPTY
    trac at osgeo.org
    Wed Jun 26 02:23:06 PDT 2019
 Reporter:  strk           |      Owner:  robe
     Type:  defect         |     Status:  new
 Priority:  critical       |  Milestone:  PostGIS 2.5.3
Component:  loader/dumper  |    Version:  trunk
 Keywords:                 |
 It looks like dumping empty points is doing bad things from dumper:
 $ pgsql2shp pg25 "select 'POINT EMPTY'::geometry"
 Initializing...
 Done (postgis major version: 3).
 Output shape: Point
 Dumping: Xlwgeom_api.c [135] called with n=0 and npoints=0
 I tested this in current trunk (r17559) but I suspect it happens in older
 versions too. BTW, that message was once an ERROR or fatal assertion, and
 only "recently" (?) turned into a notice instead.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4437>
