[postgis-tickets] r17561 - Commit missing file into SVN
Paul Ramsey pramsey at cleverelephant.ca
Wed Jun 26 06:52:33 PDT 2019
Author: pramsey
Date: 2019-06-26 18:52:33 -0700 (Wed, 26 Jun 2019)
New Revision: 17561
Added:
   trunk/liblwgeom/cunit/cu_gserialized2.c
Added: trunk/liblwgeom/cunit/cu_gserialized2.c
--- trunk/liblwgeom/cunit/cu_gserialized2.c	                        (rev 0)
+++ trunk/liblwgeom/cunit/cu_gserialized2.c	2019-06-27 01:52:33 UTC (rev 17561)
@@ -0,0 +1,467 @@
+ * PostGIS - Spatial Types for PostgreSQL
+ * http://postgis.net
+ * Copyright 2019 Paul Ramsey <pramsey at cleverelephant.ca>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU General Public Licence. See the COPYING file.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include "CUnit/Basic.h"
+#include "liblwgeom_internal.h"
+#include "gserialized2.c" /* for gserialized_peek_gbox_p */
+#include "cu_tester.h"
+static void test_g2flags_macros(void)
+	uint8_t flags = 0;
+	CU_ASSERT_EQUAL(0, G2FLAGS_GET_Z(flags));
+	G2FLAGS_SET_Z(flags, 1);
+	CU_ASSERT_EQUAL(1, G2FLAGS_GET_Z(flags));
+	G2FLAGS_SET_Z(flags, 0);
+	CU_ASSERT_EQUAL(0, G2FLAGS_GET_BBOX(flags));
+	CU_ASSERT_EQUAL(0, G2FLAGS_GET_M(flags));
+	G2FLAGS_SET_M(flags, 1);
+	CU_ASSERT_EQUAL(1, G2FLAGS_GET_M(flags));
+	G2FLAGS_SET_BBOX(flags, 1);
+	CU_ASSERT_EQUAL(1, G2FLAGS_GET_BBOX(flags));
+	CU_ASSERT_EQUAL(0, G2FLAGS_GET_GEODETIC(flags));
+	G2FLAGS_SET_GEODETIC(flags, 1);
+	CU_ASSERT_EQUAL(1, G2FLAGS_GET_GEODETIC(flags));
+	flags = g2flags(1, 0, 1); /* z=1, m=0, geodetic=1 */
+	CU_ASSERT_EQUAL(2, G2FLAGS_GET_ZM(flags));
+	flags = g2flags(1, 1, 1); /* z=1, m=1, geodetic=1 */
+	CU_ASSERT_EQUAL(3, G2FLAGS_GET_ZM(flags));
+	flags = g2flags(0, 1, 0); /* z=0, m=1, geodetic=0 */
+	CU_ASSERT_EQUAL(1, G2FLAGS_GET_ZM(flags));
+	flags = 0;
+	G2FLAGS_SET_VERSION(flags, 0);
+	CU_ASSERT_EQUAL(0, G2FLAGS_GET_VERSION(flags));
+	G2FLAGS_SET_VERSION(flags, 1);
+	CU_ASSERT_EQUAL(1, G2FLAGS_GET_VERSION(flags));
+static void test_gserialized2_extended_flags(void)
+	LWGEOM *lwg1, *lwg2;
+	GSERIALIZED *g;
+	size_t size = 0;
+	/* No extended flags, so 32 bytes for a point */
+	lwg1 = lwgeom_from_wkt("POINT(100 100)", LW_PARSER_CHECK_NONE);
+	size = gserialized2_from_lwgeom_size(lwg1);
+	CU_ASSERT_EQUAL(size, 32);
+	/* Add extended flag, we now expect 8 extra bytes */
+	FLAGS_SET_SOLID(lwg1->flags, 1);
+	CU_ASSERT_EQUAL(1, FLAGS_GET_SOLID(lwg1->flags));
+	CU_ASSERT_EQUAL(size, 40);
+	/* We expect that the extended bit will be set on the serialization */
+	g = gserialized2_from_lwgeom(lwg1, &size);
+	CU_ASSERT_EQUAL(1, G2FLAGS_GET_EXTENDED(g->gflags));
+	/* And that the serialization in fact hits 40 bytes */
+	lwgeom_free(lwg1);
+	lwg2 = lwgeom_from_gserialized2(g);
+	lwfree(g);
+	/* And that when deserialized again, the solid flag is still there */
+	CU_ASSERT_EQUAL(1, FLAGS_GET_SOLID(lwg2->flags));
+	lwgeom_free(lwg2);
+static void test_gserialized2_srid(void)
+	GSERIALIZED s;
+	int32_t srid, rv;
+	srid = 4326;
+	gserialized2_set_srid(&s, srid);
+	rv = gserialized2_get_srid(&s);
+	CU_ASSERT_EQUAL(rv, srid);
+	srid = -3005;
+	//printf("srid=%d rv=%d\n",srid,rv);
+	CU_ASSERT_EQUAL(rv, SRID_UNKNOWN);
+	srid = SRID_UNKNOWN;
+	srid = 100000;
+static void test_gserialized2_from_lwgeom_size(void)
+	LWGEOM *g;
+	size_t size = 0;
+	g = lwgeom_from_wkt("POINT(0 0)", LW_PARSER_CHECK_NONE);
+	size = gserialized2_from_lwgeom_size(g);
+	CU_ASSERT_EQUAL( size, 32 );
+	lwgeom_free(g);
+	g = lwgeom_from_wkt("POINT(0 0 0)", LW_PARSER_CHECK_NONE);
+	CU_ASSERT_EQUAL( size, 40 );
+	lwgeom_free(g);
+	g = lwgeom_from_wkt("MULTIPOINT(0 0 0, 1 1 1)", LW_PARSER_CHECK_NONE);
+	CU_ASSERT_EQUAL( size, 80 );
+	lwgeom_free(g);
+	g = lwgeom_from_wkt("LINESTRING(0 0, 1 1)", LW_PARSER_CHECK_NONE);
+	CU_ASSERT_EQUAL( size, 48 );
+	lwgeom_free(g);
+	g = lwgeom_from_wkt("MULTILINESTRING((0 0, 1 1),(0 0, 1 1))", LW_PARSER_CHECK_NONE);
+	CU_ASSERT_EQUAL( size, 96 );
+	lwgeom_free(g);
+	g = lwgeom_from_wkt("POLYGON((0 0, 0 1, 1 1, 1 0, 0 0))", LW_PARSER_CHECK_NONE);
+	CU_ASSERT_EQUAL( size, 104 );
+	lwgeom_free(g);
+	g = lwgeom_from_wkt("POLYGON((-1 -1, -1 2, 2 2, 2 -1, -1 -1), (0 0, 0 1, 1 1, 1 0, 0 0))", LW_PARSER_CHECK_NONE);
+	CU_ASSERT_EQUAL( size, 184 );
+	lwgeom_free(g);
+static void test_lwgeom_from_gserialized2(void)
+	LWGEOM *geom1, *geom2;
+	GSERIALIZED *g1, *g2;
+	char *in_ewkt, *out_ewkt;
+	size_t i = 0;
+	char *ewkt[] =
+		"POINT EMPTY",
+		"POINT(0 0.2)",
+		"LINESTRING EMPTY",
+		"LINESTRING(-1 -1,-1 2.5,2 2,2 -1)",
+		"MULTIPOINT EMPTY",
+		"MULTIPOINT(0.9 0.9,0.9 0.9,0.9 0.9,0.9 0.9,0.9 0.9,0.9 0.9)",
+		"MULTIPOINT(0.9 0.9,0.9 0.9,EMPTY,0.9 0.9,0.9 0.9,0.9 0.9)",
+		"SRID=1;MULTILINESTRING EMPTY",
+		"SRID=1;MULTILINESTRING((-1 -1,-1 2.5,2 2,2 -1),(-1 -1,-1 2.5,2 2,2 -1),(-1 -1,-1 2.5,2 2,2 -1),(-1 -1,-1 2.5,2 2,2 -1))",
+		"POLYGON((-1 -1,-1 2.5,2 2,2 -1,-1 -1),(0 0,0 1,1 1,1 0,0 0))",
+		"POLYGON EMPTY",
+		"SRID=4326;POLYGON((-1 -1,-1 2.5,2 2,2 -1,-1 -1),(0 0,0 1,1 1,1 0,0 0))",
+		"SRID=4326;POLYGON EMPTY",
+		"SRID=4326;POLYGON((-1 -1,-1 2.5,2 2,2 -1,-1 -1),(0 0,0 1,1 1,1 0,0 0),(-0.5 -0.5,-0.5 -0.4,-0.4 -0.4,-0.4 -0.5,-0.5 -0.5))",
+		"SRID=100000;POLYGON((-1 -1 3,-1 2.5 3,2 2 3,2 -1 3,-1 -1 3),(0 0 3,0 1 3,1 1 3,1 0 3,0 0 3),(-0.5 -0.5 3,-0.5 -0.4 3,-0.4 -0.4 3,-0.4 -0.5 3,-0.5 -0.5 3))",
+		"SRID=4326;MULTIPOLYGON(((-1 -1,-1 2.5,2 2,2 -1,-1 -1),(0 0,0 1,1 1,1 0,0 0),(-0.5 -0.5,-0.5 -0.4,-0.4 -0.4,-0.4 -0.5,-0.5 -0.5)),((-1 -1,-1 2.5,2 2,2 -1,-1 -1),(0 0,0 1,1 1,1 0,0 0),(-0.5 -0.5,-0.5 -0.4,-0.4 -0.4,-0.4 -0.5,-0.5 -0.5)))",
+		"SRID=4326;MULTIPOLYGON EMPTY",
+		"SRID=4326;GEOMETRYCOLLECTION(POINT(0 1),POLYGON((-1 -1,-1 2.5,2 2,2 -1,-1 -1),(0 0,0 1,1 1,1 0,0 0)),MULTIPOLYGON(((-1 -1,-1 2.5,2 2,2 -1,-1 -1),(0 0,0 1,1 1,1 0,0 0),(-0.5 -0.5,-0.5 -0.4,-0.4 -0.4,-0.4 -0.5,-0.5 -0.5))))",
+		"SRID=4326;GEOMETRYCOLLECTION EMPTY",
+		"SRID=4326;GEOMETRYCOLLECTION(POINT EMPTY,MULTIPOLYGON EMPTY)",
+		"SRID=4326;GEOMETRYCOLLECTION(POINT(0 0.2),POINT EMPTY,POINT(0 0.2))",
+		"MULTICURVE((5 5 1 3,3 5 2 2,3 3 3 1,0 3 1 1),CIRCULARSTRING(0 0 0 0,0.26794 1 3 -2,0.5857864 1.414213 1 2))",
+		"MULTISURFACE(CURVEPOLYGON(CIRCULARSTRING(-2 0,-1 -1,0 0,1 -1,2 0,0 2,-2 0),(-1 0,0 0.5,1 0,0 1,-1 0)),((7 8,10 10,6 14,4 11,7 8)))",
+		"MULTISURFACE(CURVEPOLYGON(CIRCULARSTRING EMPTY))",
+		"POLYHEDRALSURFACE(((0 0 0,0 1 0,1 1 0,1 0 0,0 0 0)),((0 0 1,1 0 1,1 1 1,0 1 1,0 0 1)),((0 0 0,0 0 1,0 1 1,0 1 0,0 0 0)),((1 0 0,1 1 0,1 1 1,1 0 1,1 0 0)),((0 0 0,1 0 0,1 0 1,0 0 1,0 0 0)),((0 1 0,0 1 1,1 1 1,1 1 0,0 1 0)))",
+	for ( i = 0; i < (sizeof ewkt/sizeof(char*)); i++ )
+		size_t size1, size2;
+		in_ewkt = ewkt[i];
+		geom1 = lwgeom_from_wkt(in_ewkt, LW_PARSER_CHECK_NONE);
+		lwgeom_add_bbox(geom1);
+		if (geom1->bbox) gbox_float_round(geom1->bbox);
+		size1 = gserialized2_from_lwgeom_size(geom1);
+		g1 = gserialized2_from_lwgeom(geom1, &size2);
+		CU_ASSERT_EQUAL(size1, size2);
+		geom2 = lwgeom_from_gserialized2(g1);
+		out_ewkt = lwgeom_to_ewkt(geom2);
+		/* printf("\n in = %s\nout = %s\n", in_ewkt, out_ewkt); */
+		CU_ASSERT_STRING_EQUAL(in_ewkt, out_ewkt);
+		g2 = gserialized2_from_lwgeom(geom2, &size2);
+		CU_ASSERT_EQUAL(g1->gflags, g2->gflags);
+		/* either both or none of the bboxes are null */
+		CU_ASSERT(geom1->bbox != NULL || geom2->bbox == NULL);
+		/* either both are null or they are the same */
+		CU_ASSERT(geom1->bbox == NULL || gbox_same(geom1->bbox, geom2->bbox));
+		lwfree(out_ewkt);
+		lwfree(g1);
+		lwfree(g2);
+		lwgeom_free(geom1);
+		lwgeom_free(geom2);
+		/* SOLID / BOX INTERACTION */
+		FLAGS_SET_SOLID(geom1->flags, 1);
+		CU_ASSERT_EQUAL(SIZE_GET(g1->size), size2);
+		CU_ASSERT_EQUAL(geom1->flags, geom2->flags);
+		CU_ASSERT_EQUAL(SIZE_GET(g2->size), size2);
+		CU_ASSERT_EQUAL(FLAGS_GET_SOLID(geom2->flags), 1);
+		lwfree(g1);
+		lwfree(g2);
+static void test_gserialized2_is_empty(void)
+	int i = 0;
+	struct gserialized_empty_cases {
+		const char* wkt;
+		int isempty;
+	struct gserialized_empty_cases cases[] = {
+		{ "POINT EMPTY", 1 },
+		{ "POINT(1 1)", 0 },
+		{ "LINESTRING EMPTY", 1 },
+		{ "MULTILINESTRING EMPTY", 1 },
+		{ "MULTILINESTRING(EMPTY)", 1 },
+		{ "MULTILINESTRING(EMPTY,EMPTY)", 1 },
+		{ "MULTILINESTRING(EMPTY,(0 0,1 1))", 0 },
+		{ "MULTILINESTRING((0 0,1 1),EMPTY)", 0 },
+		{ "MULTILINESTRING(EMPTY,(0 0,1 1),EMPTY)", 0 },
+		{ "MULTILINESTRING(EMPTY,EMPTY,EMPTY)", 1 },
+		{ "GEOMETRYCOLLECTION(POINT EMPTY,MULTILINESTRING(EMPTY,EMPTY,EMPTY))", 1 },
+		{ "GEOMETRYCOLLECTION(POINT EMPTY,MULTILINESTRING(EMPTY),POINT(1 1))", 0 },
+		{ "GEOMETRYCOLLECTION(POINT EMPTY,MULTILINESTRING(EMPTY, (0 0)),POINT EMPTY)", 0 },
+		{ "GEOMETRYCOLLECTION(POLYGON EMPTY,POINT EMPTY,MULTILINESTRING(EMPTY,EMPTY),POINT EMPTY)", 1 },
+		{ "GEOMETRYCOLLECTION(POLYGON EMPTY,GEOMETRYCOLLECTION(POINT EMPTY),MULTILINESTRING(EMPTY,EMPTY),POINT EMPTY)", 1 },
+		{ NULL, 0 }
+	while( cases[i].wkt )
+		// i = 11;
+		LWGEOM *lw = lwgeom_from_wkt(cases[i].wkt, LW_PARSER_CHECK_NONE);
+		GSERIALIZED *g = gserialized2_from_lwgeom(lw, 0);
+		int ie = gserialized2_is_empty(g);
+		// printf("%s: we say %d, they say %d\n", cases[i].wkt, cases[i].isempty, ie);
+		CU_ASSERT_EQUAL(ie, cases[i].isempty);
+		lwgeom_free(lw);
+		lwfree(g);
+		i++;
+static void test_on_gser2_lwgeom_count_vertices(void)
+	LWGEOM *lwgeom;
+	GSERIALIZED *g_ser1;
+	size_t ret_size;
+	lwgeom = lwgeom_from_wkt("MULTIPOINT(-1 -1,-1 2.5,2 2,2 -1,1 1,2 2,4 5)", LW_PARSER_CHECK_NONE);
+	CU_ASSERT_EQUAL(lwgeom_count_vertices(lwgeom),7);
+	g_ser1 = gserialized2_from_lwgeom(lwgeom, &ret_size);
+	lwgeom_free(lwgeom);
+	lwgeom = lwgeom_from_gserialized2(g_ser1);
+	lwfree(g_ser1);
+static void test_gserialized2_peek_gbox_p_no_box_when_empty(void)
+	uint32_t i;
+	char *ewkt[] =
+		"POINT EMPTY",
+		"MULTIPOINT (EMPTY)",
+		"MULTILINESTRING EMPTY",
+		"MULTILINESTRING (EMPTY)"
+		LWGEOM* geom = lwgeom_from_wkt(ewkt[i], LW_PARSER_CHECK_NONE);
+		GBOX box;
+		gbox_init(&box);
+		GSERIALIZED* gser = gserialized2_from_lwgeom(geom, NULL);
+		CU_ASSERT_FALSE(gserialized2_has_bbox(gser));
+		CU_ASSERT_EQUAL(LW_FAILURE, gserialized2_peek_gbox_p(gser, &box));
+		lwgeom_free(geom);
+		lwfree(gser);
+static void test_gserialized2_peek_gbox_p_gets_correct_box(void)
+	uint32_t i;
+	char *ewkt[] =
+		"POINT (2.2945672355 48.85822923236)",
+		"POINTZ (2.2945672355 48.85822923236 15)",
+		"POINTM (2.2945672355 48.85822923236 12)",
+		"POINT ZM (2.2945672355 48.85822923236 12 2)",
+		"MULTIPOINT ((-76.45402132523 44.225406213532))",
+		"MULTIPOINT Z ((-76.45402132523 44.225406213532 112))",
+		"MULTIPOINT ZM ((-76.45402132523 44.225406213532 112 44))",
+		"LINESTRING (2.2945672355 48.85822923236, -76.45402132523 44.225406213532)",
+		"LINESTRING Z (2.2945672355 48.85822923236 6, -76.45402132523 44.225406213532 8)",
+		"LINESTRING ZM (2.2945672355 48.85822923236 3 2, -76.45402132523 44.225406213532 9 4)",
+		"MULTILINESTRING ((2.2945672355 48.85822923236, -76.45402132523 44.225406213532))",
+		"MULTILINESTRING Z ((2.2945672355 48.85822923236 4, -76.45402132523 44.225406213532 3))"
+		GBOX box_from_peek;
+		GBOX box_from_lwgeom;
+		gbox_init(&box_from_peek);
+		gbox_init(&box_from_lwgeom);
+		lwgeom_calculate_gbox(geom, &box_from_lwgeom);
+		gserialized2_peek_gbox_p(gser, &box_from_peek);
+		gbox_float_round(&box_from_lwgeom);
+		CU_ASSERT_TRUE(gbox_same(&box_from_peek, &box_from_lwgeom));
+		lwfree(gser);
+static void test_gserialized2_peek_gbox_p_fails_for_unsupported_cases(void)
+	uint32_t i;
+	char *ewkt[] =
+		"MULTIPOINT ((-76.45402132523 44.225406213532), (-72 33))",
+		"LINESTRING (2.2945672355 48.85822923236, -76.45402132523 44.225406213532, -72 33)",
+		"MULTILINESTRING ((2.2945672355 48.85822923236, -76.45402132523 44.225406213532, -72 33))",
+		"MULTILINESTRING ((2.2945672355 48.85822923236, -76.45402132523 44.225406213532), (-72 33, -71 32))"
+		GBOX box;
+		gbox_init(&box);
+		lwgeom_drop_bbox(geom);
+		/* Construct a GSERIALIZED* that doesn't have a box, so that we can test the
+		 * actual logic of the peek function */
+		size_t expected_size = gserialized2_from_lwgeom_size(geom);
+		GSERIALIZED* gser = lwalloc(expected_size);
+		uint8_t* ptr = (uint8_t*) gser;
+		ptr += 8; // Skip header
+		gserialized2_from_lwgeom_any(geom, ptr);
+		gser->gflags = lwflags_get_g2flags(geom->flags);
+		lwfree(gser);
+** Used by test harness to register the tests in this file.
+void gserialized2_suite_setup(void);
+	CU_pSuite suite = CU_add_suite("serialization/deserialization v2", NULL, NULL);
+	PG_ADD_TEST(suite, test_g2flags_macros);
+	PG_ADD_TEST(suite, test_gserialized2_srid);
+	PG_ADD_TEST(suite, test_gserialized2_from_lwgeom_size);
+	PG_ADD_TEST(suite, test_lwgeom_from_gserialized2);
+	PG_ADD_TEST(suite, test_on_gser2_lwgeom_count_vertices);
+	PG_ADD_TEST(suite, test_gserialized2_is_empty);
+	PG_ADD_TEST(suite, test_gserialized2_peek_gbox_p_no_box_when_empty);
+	PG_ADD_TEST(suite, test_gserialized2_peek_gbox_p_gets_correct_box);
+	PG_ADD_TEST(suite, test_gserialized2_peek_gbox_p_fails_for_unsupported_cases);
+	PG_ADD_TEST(suite, test_gserialized2_extended_flags);
