[postgis-tickets] [PostGIS] #4407: Test failure on 32bit: tickets ... #3719
PostGIS trac at osgeo.org
Fri Jun 28 09:43:48 PDT 2019
  Reporter:  myon     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.0.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by pramsey):
 Looking at the #3719 ticket, that ticket is all about linearization, which
 for close-to-tolerance cases can produce invalid output from valid (in a
 curvey sense) input. So this is probably something in linearization, which
 seems to be a constantly churning part of the code base (everyone has
 their own defn of what a "correct" linearization (or de-linearization)
 looks like).
 That said, blame shows no changes since 8 months ago when dbaston took a
 run at #3719. We haven't had 32 bit issues all this time, right?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4407#comment:6>
