[postgis-tickets] [PostGIS] #4407: Test failure on 32bit:	tickets ... #3719
    trac at osgeo.org
    Fri Jun 28 12:42:26 PDT 2019
  Reporter:  myon     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.0.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by robe):
 Well this is a new test that Darafei introduced to test FULL JOIN.
 and you know how much of a master he is at putting together tests that
 break everything you thought was working :)/
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4407#comment:7>
