[postgis-tickets] [PostGIS] #4406: Undefined behavior in decode_geohash_bbox with invalid input
trac at osgeo.org
Fri May 31 01:27:14 PDT 2019
Reporter: mentin | Owner: strk
Type: defect | Status: new
Priority: low | Milestone: PostGIS 2.5.3
Component: liblwgeom | Version: trunk
Keywords: geohash |
decode_geohash_bbox uses this code to convert geohash version of base32 to
integer:
721 for (i = 0; i < precision; i++)
722 {
723 c = tolower(geohash[i]);
724 cd = strchr(base32, c) - base32;
725
If the input is not a valid geohash, the strchr returns NULL,
the result is a constant that depends of how linker loaded 'base32'
field.
There is no security vulnerability here, since NULL is never dereferenced,
and only 5 bits of 'cd' are used, but the result is undefined (even though
it
is constant for any specific build).
E.g. in my PostgreSQL build, I'm getting
ST_PointFromGeoHash("@@@@@@") equal to ST_PointFromGeoHash("gggggg"),
meaning my 'base32' was at some offset representable as 32*n + 16.
Should this query fail in PostGIS?
Should this return something well defined?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4406>
